Tracking / Autocross / HPDE / Drifting What these cars were built for! |
07-22-2012, 11:44 PM | #15 |
Drives: Legacy GT
In that case you will get it figured out. But starting with a good amount more camber up front will save you some work.
The Following User Says Thank You to jamal For This Useful Post: | track_warrior (07-22-2012) |
07-23-2012, 01:24 AM | #16 | |
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Also remember this is a vehicle that gets it's speed by carrying momentum. Always try to break, and accelerate while the steering wheel is straight (read not in the middle of a turn). G |
07-23-2012, 11:48 AM | #17 |
Drives: RX8
It also depends quite a bit on the course you're running. The best solution would be to get some camber plates up front and use a laser or probe pyrometer at the track after a couple laps and adjust accordingly to even out the tire temperatures. The rears you can't really change on the fly but you should have less problems there because it's multi-link.
Of course, running quite a bit of negative camber for the track will cause the inside of the tires to wear faster while driving on the street. Getting an alignment before and after each track event might not be too practical lol |
07-23-2012, 03:05 PM | #18 | |
I am going to need to re-learn the track with the new car. My old car could not go in fast, but I could put the power down very well coming out of the corners. I suspect I will be going in to corners faster and carrying more speed with the BRZ. Pat |
07-24-2012, 12:15 AM | #19 | |
Drives: 2013 FR-S Asphalt
07-24-2012, 12:50 AM | #20 | |
Track Junkie
Drives: Faster than the Stig!
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
07-24-2012, 01:16 PM | #21 |
Yes you will wear the outside of your front tires on a completely stock car at the track.
The stock alignment is junk and don't even bother. Really. I'm ALL for taking the car to the track or to an auto-x once completely stock to get a feel for things but a good alignment is something I recommend right off the showroom floor. We've seen a variety of toe settings from the factory over the years from Subaru and it's just not worth it to see what happens. You can dial in some camber safely (with the right parts) without affecting day to day driveability, often while improving tire longevity/wear. A little bit of camber can help depending on driving habits. Even up to -1.75 front or so is fine for most street cars if you don't sit on the highway for hours on end on your commute. And you'll want more for a track car. No need for -2.5 in the rear. The big tire killer is a lot of toe. A little toe-in is fine, but nothing too crazy. - Andrew |
Similar Threads | ||||
Need advice on tire size for track duty?? | track_warrior | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 02-05-2013 07:50 PM |
Element Tuning Track Tested and Track Proven FRS Video | Element Tuning | Tracking / Autocross / HPDE / Drifting | 47 | 07-17-2012 04:12 PM |
Clutch wear? | Pakjk89 | Engine, Exhaust, Transmission | 102 | 04-12-2012 07:21 PM |
$110 Track day at Willow Springs- Big Track -March24 in SoCal | Louie | Southern California | 1 | 03-10-2012 01:31 AM |
wear your seatbelt... | bofa | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 07-16-2011 04:25 AM |
