Old 04-03-2014, 10:59 AM   #43
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I think i've been experiencing this as well. I just bought a car from a member on here and it was worrying me a little since it is turbod. I was hoping it wasn't overheating something near the hot end of the turbo.
I'm glad it isn't something turbo related. I'll check the alternator area next time I smell it.
blackfireball5 is offline   Reply With Quote
Old 04-03-2014, 11:46 AM   #44
FR-Slide
Drives: 13 Whiteout 6MT
Same for me, very intermittent. Almost smells like hot electronics sometimes, or hot clutch.
Still, worried me though, since I've recently added on foglights (new wires/electronics) and adjusted my clutch, and thought perhaps it was related. No signs of ridden clutch, and all wires are fine, so I guess it must be the same as everyone else.
Hooray for "character".
FR-Slide is offline   Reply With Quote
Old 04-03-2014, 12:45 PM   #45
samisons
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
Originally Posted by Wilso View Post
Hey guys,
Since about 1-2 weeks ago I've been noticing this hot rubbery like smell coming through the vents. I pop the hood sniff around and I finally figure out that it's the alternator (saving you the long version of the story). Do you think it's a faulty alternator? Or because I'm using rear-defrost and using the heat it's just putting more stress on it?
Any help could be appreciated
My "hot smell" turned out to be 3 oil leaks, Just sayin.
samisons is offline   Reply With Quote
Old 04-04-2014, 07:13 PM   #46
exE36M3
Yep, the hot oil is pretty common too.
I got that when they spilled oil from the oil change.
The rubbery one is a pretty easy one to hunt down. It smells like the drive belts.
exE36M3 is offline   Reply With Quote
Old 12-20-2023, 12:08 PM   #47
BlaqkHavok
Drives: 2014 DGM BRZ
Originally Posted by Area86 View Post
Started noticing a weird smell coming through my vents and my battery light was randomly flickering so I took a look under the hood and found this
sorry to necro this, but i just had the same thing happen to my 2017!!!!
your picture is shows the same thing, the rubber it self is completely fried, and sort of a burnt dome on the inside of the rubber cap. the copper terminal looks pretty burnt too..
i took the alt off and if i give it a shake you can hear something rattling around inside. im going to replace the alt, but at aprox $250 per i don't want this to keep happening if the alt is not the cause..
im probably going to upgrade the alt positives wire too while im at it, do the two leads going from the Alt to the fuse box and then to the starter.
did you ever find out what the source was for ur burnt terminal/alternator? did you have issues after?
BlaqkHavok is offline   Reply With Quote
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) -- General Topics 48 08-09-2013 06:34 PM
Smell of burnt plastic" DaNBrZ BRZ First-Gen (2012+) -- General Topics 14 07-15-2013 02:54 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
