Forced Induction Turbo, Supercharger, Methanol, Nitrous |
11-22-2018, 11:24 PM | #1 |
Drives: 2013 brz limited / galaxy blue
Jrsc squeak and squeal that is hard to Locate . Any info would be appreciated !!
I have a squeak or squeal and not sure where it is coming from . I have the jrsc as fi and was wondering if anyone else has had the same issue . After driving the car for a bit the squeal reduces but on cold starts or starts after it's sitting for a few hours it will do again . I have added belt dressing and also have tried adding oil as lube on the older pulley where there is like a rubber type seal . Here is how it sounds and my apologies on the angle . Is there a way to add video ?
12-03-2018, 03:33 PM | #3 |
If you add oil on a pulley, its gonna fling it. It will get on the belt. The belt will make noise. Make sure the belt is clean, and idler pulleys are ok.
12-03-2018, 09:54 PM | #4 |
I had a slight oil leak from the oil cooler filter mount that happened to get on the belt . After several attempts of cleaning the belt I was able to isolate the sound by adding a bit of water to the belt as the car was running . When I would spray the belt it would stop squeaking and omitted the chance of the pulleys squeaking . I bought a new serpentine belt as the one on the jrsc was pushing 3 years old and it was slightly glazed looking , after the belt change the squeak is gone and had not returned . Lame we can't post vids on here unless via you tube link . Thought I would follow up with y'all
12-03-2018, 10:23 PM | #5 |
Drives: 13 Brz Jrsc
Nice. My belt does the same thing. It’s super annoying
12-03-2018, 11:09 PM | #6 |
12-04-2018, 03:07 AM | #8 |
Similar Threads | ||||
Low speed squeal / squeak noise | highway7 | Issues | Warranty | Recalls / TSB | 16 | 08-02-2021 05:42 AM |
Difficult to search for and locate specific text in forum. | Darth Khan | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 09-27-2017 07:37 AM |
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) | DarkSunrise | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 03-30-2017 11:39 PM |
My 14' FRS Appreciated In Value!!! | Phantobe | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 01-18-2017 07:13 AM |
Trying to locate GReddy or 6666 to buy the Rocket Bunny kit direct | FT-86GOD | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 11-13-2012 02:38 AM |
