Old 05-09-2018, 11:30 AM   #85
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I re-purposed my sound generator tubing to run wires through the firewall :P
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 9 Users Say Thank You to Stang70Fastback For This Useful Post:
ermax (12-11-2018), gravitylover (05-26-2018), jcw99 (10-03-2020), JimmyMac (05-09-2018), Leonardo (05-09-2018), PerCompLLC (08-09-2022), Pointmutation (05-18-2018), slizoth (05-13-2019), theneptune86 (08-19-2020)
Old 12-11-2018, 12:49 AM   #86
suzyj
Drives: 2018 86 GTS
Thanks!
Picked up my shiny new Apollo Blue 86 GTS yesterday, and drove it home (400km). The mwaap mwaap noises got to be annoying, so this morning the sound tube fell out, and was replaced by a pair of plugs turned from black delrin (40mm dia by 20mm long at the intake, and 18mm dia by 20mm long at the firewall).
Much better!
suzyj is offline   Reply With Quote
Old 12-11-2018, 01:04 AM   #87
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I tried to do this when I was working on the spark plugs ... the darn sound tube was stuck too well on the darn intake tube :/
Old 01-19-2019, 07:45 PM   #88
jflogerzi
jflogerzi's Avatar
Just did this. My home Depot did not have a single 3/4 pex plug but they had 5 packs... Still cheaper then then the online kits. Everything works perfectly. Added a new hks dry filter while I was doing everything.
2013 Series 10 FRS #553
Old 01-27-2019, 07:41 PM   #89
austinvojta
Drives: 2016 Subaru BRZ Limited
Got my tube out today, used the standard plug and cap. Very happy with the aesthetic difference under the hood. What have y'all done with the zip ties? I was in a hurry (dark + mosquitoes) and couldn't remove them easily. Do they pull out of their little mounts if you just tug with some pliers?
austinvojta is offline   Reply With Quote
Old 01-27-2019, 08:57 PM   #90
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Originally Posted by austinvojta View Post
.. I was in a hurry (dark + mosquitoes) and couldn't remove them easily. Do they pull out of their little mounts if you just tug with some pliers?
I've never been able to grab the mosquitos around here with pliers. I usually just smash them, or use those fun electric badminton-style rackets. Wasn't aware they had mounts.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following User Says Thank You to MuseChaser For This Useful Post:
maslin (05-12-2019)
Old 05-11-2019, 06:26 PM   #91
Lav
Drives: Frs
How do you disconnect the zip tie closer to the firewall? Just rip it out?
bibbity boppity give me the zoppity
Lav is offline   Reply With Quote
Old 05-11-2019, 07:11 PM   #92
Lav
Drives: Frs
Just sack up and yank it out son. Use your flathead for leverage to loosen it if you got noodle arms. Youre damaging the zip tie which is easily replaceable
Old 05-13-2019, 12:41 AM   #93
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Are you high?
Did you just respond to yourself?
I also had a very hard time with the firewall connection way back when. The TRD intake required removal of the sound tube and included a cap, hardest damn part was how to cut the zip tie or even yank it out but it eventually came free.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Impureclient (05-13-2019)
Old 05-13-2019, 08:35 PM   #94
Impureclient
Drives: 2015 FR-S
Yes, he did.
Impureclient is offline   Reply With Quote
Old 05-13-2019, 08:35 PM   #95
Impureclient
Drives: 2015 FR-S
Originally Posted by Impureclient View Post
Yes, he did.
Are you sure?
Old 09-26-2020, 08:56 PM   #96
zippee
Guest
Posts: n/a
If you're looking for the easiest solution... pull the plug in the footwell, shove a bit of paper towel or tissue into it snug and put the stock plug back in. Stealth delete. I haven't tried this as my car arrives tomorrow =
Update: I plugged with a plastic end cap usually used for lawn irrigation piping. Secured with silicon.
Old 09-27-2020, 10:12 PM   #97
mrhemi
I deleted my sound tube with a Jackson Racing Supercharger Kit. Sounds much better.
mrhemi is offline   Reply With Quote
Old 11-17-2020, 02:17 AM   #98
ALVWKS
barebones86
ALVWKS's Avatar
Drives: ice silver
To those still attempting this on your car. Just sharing some stuff I’ve learned while removing the sound tube. The 2 grey zip tie looking clips can be removed without breaking it, use a small plyer to squeeze the clip to release it. The one plugged into the chassis, just yank it straight up holding on to the plastic L joint for leverage. For the plugging of holes at the intake pipe as well as at the firewall, I was able to use black rubber boots normally meant for furniture leg base, to my surprise it was a snug fit.
ALVWKS is offline   Reply With Quote
Sound Generator to keep or not to keep? FRS86edition#3 Scion FR-S / Toyota 86 GT86 General Forum 73 11-24-2013 01:26 AM
Sound generator delete for $1.06 PineappleFriedRice Engine, Exhaust, Transmission 13 11-10-2013 12:28 PM
Sound Generator Tube Delete Anthony Engine, Exhaust, Transmission 8 09-01-2013 04:25 AM
WTB: OEM snorkle (not sound generator) Laika Engine, Exhaust, Bolt-Ons 2 11-08-2012 11:31 AM
