Old 02-20-2018, 10:56 AM   #15
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
Originally Posted by mistople View Post
Long weekend = lots of great seat time in the car. Learning a ton. Does anyone have experience with larger throttle pedals? I agree with many that it is much too far away from the brake. I can heel toe fine, but it took some getting used to.
@mjanmohammad has a bigger throttle pedal I believe
spicyricecake is offline   Reply With Quote
Old 02-20-2018, 11:10 AM   #16
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Originally Posted by SkyeHack View Post
What are you shooting with?
Leica Q. Fixed 28mm focal length. Amazing camera, but definitely more difficult to use for car photography compared to your standard 50/85/70-200 lengths.
mistople is offline   Reply With Quote
Old 02-21-2018, 01:59 PM   #17
Racecomp Engineering
The cusco throttle pedal is nice.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
mistople (02-21-2018)
Old 02-23-2018, 03:21 PM   #18
mistople
mistople's Avatar
EcuTek + Delicious Tuning Stage 2. This won't get put to use quite yet, but who doesn't love a good stockpile? Thanks to @CSG Mike for getting me all set here.
This of course means I have another package coming as well. Stay tuned
The Following 2 Users Say Thank You to mistople For This Useful Post:
CSG Mike (02-23-2018), Lococholo84 (02-27-2018)
Old 02-23-2018, 04:06 PM   #19
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Nice to see fellow Seattle BRZ!
Elliotw is offline   Reply With Quote
Old 02-23-2018, 04:14 PM   #20
mistople
mistople's Avatar
We are the needles in a haystack of Outbacks and WRXs!
Any meets around the area I should know about?
Old 02-23-2018, 04:34 PM   #21
Hurricanehank
Drives: Oceanic 86
There is a meet this Sunday. Look up 86 sessions on facebook.
Hurricanehank is offline   Reply With Quote
The Following User Says Thank You to Hurricanehank For This Useful Post:
mistople (02-23-2018)
Old 02-23-2018, 06:07 PM   #22
GrantedTaken
But even so, I'd still royally mess up starts and 1->2 shifts at an alarmingly high rate.
3rd->2nd is far and away the hardest shift to nail on the BRZ, and is met with the most resistance. .
I love your photos and enthusiasm.
I think you shouldn't even add HP until after a few track events.
About shifting, something does not add up.
I have never owned a car that is easier to shift.
Issues with 1->2 are probably not about the spring.
Are you trying to downshift into 2nd with too high RPMs ?
GrantedTaken is offline   Reply With Quote
Old 02-23-2018, 06:50 PM   #23
mistople
mistople's Avatar
Thanks, loving the car!
The tune won't be used for a while. The first few months are all about getting to know the car on the limit.
1->2 was a clutch pedal issue, not the shifter. Very common around here.
3->2 is definitely not a rev-matching issue. I can match just fine, even though that gear is a bit on the short side. The shifter itself is simply a bit clunkier doing 3->2 compared to 5->4. Even since writing that post, its gotten a bit better.
Old 03-17-2018, 09:21 PM   #24
mistople
mistople's Avatar
JDL Catless UEL Header & Delicious Stage 2 Tune
Been a bit MIA as work has had me very busy lately. Today was my first day off in a while, and I celebrated by installing this little titanium-coated beauty.
I originally wanted to wait till after my first track day of the season, but the event was cancelled, so I decided to just go for it. The install wasn't as easy as I would have liked (one of the bolts on the JDL is almost impossible to properly reach), but overall it went smoothly.
I'll wait to do a proper review once Zack at Delicious has looked at my logs and gives me the OK to go WOT. All I can say is the header is of fantastic quality. I'm really impressed by the construction and obvious attention to detail.
The sound on startup is much more intense than the stock headers. Even with the stock catback, you can hear a more aggressive tone at idle, and under load. I've only gone up to around 4k so far, but even then it lets through some of the rumbles. I will say that I am shocked at how quiet the setup is as 4k and under. I expected a big volume jump. Cold starts are still somewhat loud, but really nothing that would turn any heads. I'm sure a catback will change that story.
Flashing the ECU with the Delicious Stage 2 tune was painless. Despite EcuTek's ancient UI (I ran it on Bootcamp with a '16 MBP), I had no issues and both the application setup and reflash were quick and easy. No complaints. Stay tuned for videos/soundclips and an in-depth review
I didn't think to grab a picture of the headers before re-attaching the skid plate. Here's a little peak of them through the top of the bay.
derekbrz24 (03-18-2018), Ganthrithor (03-17-2018)
Old 03-17-2018, 10:11 PM   #25
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
That's some nice hardware-porn
Ganthrithor is offline   Reply With Quote
The Following 2 Users Say Thank You to Ganthrithor For This Useful Post:
mistople (03-17-2018), spike021 (03-17-2018)
Old 03-17-2018, 11:05 PM   #26
spicyricecake
That bolt is a pain...
Old 03-18-2018, 08:57 AM   #27
jmark
Drives: '97 NSX-T, '18 Type R
Where did you purchase the header from?
jmark is offline   Reply With Quote
Old 03-18-2018, 01:52 PM   #28
mistople
mistople's Avatar
FT86 Speed Factory. I think CSG sells JDL stuff now too. You can also buy directly from JDL.
2017 BRZ Performance Package DD Build mjanmohammad Member's Car Journals 230 11-01-2023 12:31 PM
QueenBRZ's 17' BRZ performance package DD / track build QueenBRZ Member's Car Journals 125 06-29-2021 01:34 PM
Spicy.Ricecake's 2017 CWP BRZ PP Build spicyricecake Member's Car Journals 115 12-15-2019 07:42 PM
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
MVP Track Time 2014 Road Atlanta Track Dates Feffman Southeast 2 03-27-2014 06:51 AM
