03-11-2017, 09:32 AM | #3375 |
Drives: gt86
17x8 45 offset -2 camber up front, stock struts.
Anyone with this set up experiencing rubbing? |
03-11-2017, 11:26 AM | #3376 |
Drives: '13 Whiteout
03-11-2017, 12:22 PM | #3377 |
Drives: gt86
03-12-2017, 09:58 PM | #3378 |
Drives: Whiteout FR-S
Hi, I'm looking at 18x8.5 +35 in the front and 18x9.5 +25 in the rear. I am lowered on Eibach springs, and have no camber adjustments. Gonna run 225/35 all round. Will the 9.5 fit? or should I just get 8.5 and get spacers?
03-13-2017, 12:25 PM | #3379 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
I would strongly recommend to run at least a 245 on a 9.5". 225 tire on a 9.5" is very streched and in some countrys not even legal to drive due to safety concerns. 18x8.5 +35 all around is a very good Setup and pretty much flush. If you run a 245/35/18 tire Setup on it you will not Need any spacers. I run myself a 18x8.75 +35 with 245 tires, feel free to check my car Journal (link below in my signature) to see how it Looks. If you insist on 8.5 / 9.5 staggered, rather go for 8.5 +35 and 9.5+35, the wheel is alreay 1" wider, so will be 0.5" more "outside" than the front. But please Mount at least a 225 in the front and a 245 in the rear then
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
03-13-2017, 12:29 PM | #3380 | |
What tires do you want to mount?
03-13-2017, 03:24 PM | #3381 |
Drives: gt86
03-13-2017, 04:25 PM | #3382 |
17x8 +48 245/40r17. Stock everything. Anyone have that?
03-14-2017, 04:33 AM | #3383 |
http://www.ft86club.com/forums/showthread.php?t=10257 Its very very tight, but it seems to work, maybe get in contact with the guy in the thread to reconfirm he had no camber or anything done http://www.ft86club.com/forums/showthread.php?t=11493 Not sure if it will fit with 245 tires, as it is Ultra tight in the front to the inner struits, but it seems to fit with 215 tires. Maybe ask the guy in the thread obove for some Pictures from the inner struits to be sure
The Following User Says Thank You to Killerbee For This Useful Post: | FujiwaraTofu86 (03-14-2017) |
03-16-2017, 01:56 PM | #3384 |
Drives: 2015 Scion FR-S Release 1.0
Hey, I'm looking at going with a staggered setup. 18x8 +40 in front, 18x9.5 +40 in the rear. I'm lowered 1" on TRD springs. What tire sizes would be best for these? I was told 235/35 in front and 255/35 in the rear, but I want to make sure that's correct. Thanks.
03-16-2017, 04:14 PM | #3385 | |
Front 225/40 or 235/40 Rear 245/35 or 255/35 Staggered setup isn't a good idea for this car, you can search for peoples opinions. It's mostly because of understeer and can't rotate tires. |
03-16-2017, 06:10 PM | #3386 |
Well I'm boosted so I need the wide wheels/tires in the back. I think 18x9.5 would be overkill up front, if it would even fit.
03-17-2017, 12:15 AM | #3387 |
Wes
Getting Varrstoen ES1 rims 18x8.5. I don't like the stretched look, and the rims have a bit of dish to them. So what tire size would look normal? 235? Thank you!
03-17-2017, 05:30 AM | #3388 | |
245/35/18 is what you should look for
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
