Tracking / Autocross / HPDE / Drifting What these cars were built for! |
07-12-2017, 09:40 AM | #15 | |
Drives: Track preped NA FRS
Edit: before people start jumping on details, this is a gross over simplification of how things work for the sake of explaining, I know there is more involved (sway bars, geometrie, camber, toe, tire, track width, and more). |
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post: | ApexEight (07-12-2017), strat61caster (07-12-2017) |
07-12-2017, 10:17 AM | #16 |
Drives: 2013 Raven FR-S
I think it's mostly a matter of personal preference and driving style. Generally speaking though, even spring rates or stiffer fronts seem to be more preferred in Autocross applications due to the fast transitions.
The Following User Says Thank You to smg1138 For This Useful Post: | ApexEight (07-12-2017) |
07-12-2017, 01:49 PM | #17 | |
I think over time a stiffer rear rate (not spring rate, wheel rate) will emerge as successful on this car once people work it out and make their setups public, but like oinojo mentions it's not just springs+dampers=win, you need sway bars, alignment, ride heights, tires, dampers, driving style will all come into play to make a setup work, and very few people are able to hand you a good starting point right now. I'm starting to think even spring rates have become so common because once you go stiffer than street rates you need to fully understand the sway bars, tires, geometry, dynamics etc. and potentially tweak all of them while the 'soft rear, stock-ish sways, any tire works ok' is much more appealing to move a few thousand coilover kits off the shelves. But I'm just armchair quarterbacking until I do the math, I've got a few texts on the way to help me out with that (waiting until I get through the lighter stuff before I order the real textbooks). Just want to counterpoint since you got 2 people saying that the softer rear is good. Last edited by strat61caster; 07-12-2017 at 02:03 PM. |
The Following 3 Users Say Thank You to strat61caster For This Useful Post: |
07-13-2017, 02:51 AM | #18 | |
The Stig's German cousin
I will say I run a stiffer rear spring than in the front, and my setup started at 400 lbs/in front and 500 lbs/in rear. Motion ratio is one part of the reason I selected those, but even at those rates (if my math is right) I still ended up with a faster natural frequency in the rear. The short answer is you get excessive chassis pitch or roll with equal or higher front rates; by making the rear slightly faster, when you go over a bump the front wheel will compress and rebound first followed by the rear, and the slightly faster rate allows the rear to catch up and finish its rebound motion the same time the front is. You can run a higher NF in the front and still overcome this with good shock tuning, but the higher rear NF will naturally make the car better over bumps.
I will admit I followed the rule of thumb as fiat without totally understanding it, but I've seen it in more than one place and I personally like the car better this way (I have tried a square setup). Here is a guy from an FSAE forum. http://www.fsae.com/forums/archive/i...p/t-5177.html? Quote:
The Following 3 Users Say Thank You to renfield90 For This Useful Post: |
07-13-2017, 02:55 AM | #19 | |
Also part of the reason I left Street class. |
The Following User Says Thank You to renfield90 For This Useful Post: | strat61caster (07-13-2017) |
07-14-2017, 12:22 PM | #20 |
Suspension Nerd
Drives: 2019 Mazda MX-5
My co-driver daily drives his car. So I set it up as such. Also setting the car up for flat ride helps with the knarly bumps even though we are using Triple Adjustables. Never had to worry about bumps. Luckily the aftermarket supports a lot of different swaybars so I don't have to heavily rely on spring rates.
OS Giken / Bridgestone / Lot-USA BRIDE
The Following 2 Users Say Thank You to oinojo For This Useful Post: | 2superblus (07-17-2017), strat61caster (07-14-2017) |
09-09-2017, 08:15 AM | #21 |
APEXHNTR
Drives: 10 Series FR-S #1867
I wanna go slightly off tangent but still on topic here...
Trying to fix a situation; 2013 FR-S STX car KWv3 with off the shelf springs With no preload the car sits far too low and I feel roll center comes into play. So I adjusted preload to get the car at what I feel is a good ride height but now it rides like shit (duh.) So my question is; how do I raise the ride height without crushing my springs with preload?
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
09-18-2017, 10:56 PM | #22 | |
09-19-2017, 02:09 AM | #23 | |
I'm actually dealing with this on a set of KWs for another car, it's actually coilbinding now. We had to make a spacer between the helper and main and compress the helper all the way to get enough ride height so the tires wouldn't rub. Removing the helpers wasn't an option as there was not enough threads on the strut body for just the main spring. I believe we will be swapping to a stiffer spring from hyperco or eibach that will be longer and have better travel on top of the extra stiffness be compared to the spring kw ships with their kit. Hopefully we can take the spacer out when we do that. Totally different platform so no specifics that can carry over but we just made the discovery a week or two ago. Typically companies will ship a decent spring to begin with but I haven't been too impressed with KWs off the shelf hardware. It's similar to the weight of an 86 and the spring is stiffer than the one I ran on my coilovers (7k to 6k) so I'm inclined to believe the spring is of subpar quality, it's obviously not long enough nor does it have enough travel to do what it should. 2020 Edit: KW spring was trash on that chassis, swapped to a ~400# Eibach Race Spring, got the ride height we needed, ride quality improved dramatically with the stiffer spring that wasn't coilbinding, surprise surprise. Looks like KW V3's come with a 6k spring up front, you shouldn't have to preload that spring much at all to get a decent ride height imho since that's what I have on my car we actually have the spring loose at full droop right now. Last edited by strat61caster; 03-27-2020 at 06:57 PM. |
03-27-2020, 05:57 PM | #24 |
Forgive me for reviving my old thread from the dead, but all this self-isolating has got me super bored. Just curious what kind of ride heights are you guys running this season? That is if the season ever gets started
03-27-2020, 09:00 PM | #25 |
Drives: Many
I got an event in and a school (and a track day!) before the lockdown started.
I feel like my car is pretty tall compared to most, but it seems to work alright and I'm still rubbing through the fender liners. |
The Following User Says Thank You to e1_griego For This Useful Post: | smg1138 (03-27-2020) |
03-27-2020, 09:43 PM | #26 |
@e1_griego That looks pretty close to what I'm running. I'm measuring about 13.5" from hub center to fender right now. Feel like I'm always trying to find the perfect balance between daily driving and racing. What suspension setup do you have? I've been running RCE T2's with 400/400 springs since 2016.
03-28-2020, 01:05 AM | #27 |
Drives: Many
MCS 2WR, 400/400.
I've had it lower in the past but I mostly run in Packwood which isn't particularly smooth. |
The Following User Says Thank You to e1_griego For This Useful Post: | smg1138 (03-28-2020) |
03-28-2020, 09:48 AM | #28 | |
Drives: 2017 BRZ w/PP
im about 1" lower maybe a hair lower and i already cant get in my friends driveway. i dont know how anyone can daily drive while running lower |
The Following User Says Thank You to Breadman For This Useful Post: | smg1138 (03-28-2020) |
Similar Threads | ||||
How does adjusting ride height affect toe? | smg1138 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 01-10-2016 11:28 PM |
Stock Ride Height? | JimmyMac | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 03-10-2015 11:46 AM |
Coilover to Raise Ride Height | Furtive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 07-28-2014 12:57 PM |
BRZ vs 86 stock ride height | Moe | AFRICA | 2 | 11-21-2013 08:35 AM |
Lower ride height in NYC? | blur | NY / NJ / CT / PA | 9 | 01-19-2012 06:31 PM |
