Old 07-12-2019, 01:16 AM   #253
AllThePeat
Drives: 2019 Autox BRZ & 2021 GTI (Daily)
First autocross event — any pointers appreciated! Video posted was the last and best run of the day. Had a better time each run out except for the fourth where I forgot to turn off traction control and it bogged off the start. Event was at Road America’s go-kart track.
Had a blast!! Hoping to do a couple more this season and go bigger for next year when I do some suspension mods over winter.
Mods:
K&N Drop-in | Perrin Intake Tube | Invidia Catless/Resonated Front Pipe | Corsa Catback | 17x9 Rays 57CR | RE-71R 245/40 | Stock Suspension (for now)
[ame]https://www.youtube.com/watch?v=e-tGEOdeEJE[/ame]
2019 BRZ | Autocross focused, CSG tuned w/Jackson racing C38 & PTuning flex fuel kit
2021 GTI | Daily
AllThePeat is offline   Reply With Quote
Old 07-30-2019, 04:51 PM   #254
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Here's my fastest left and right runs from the Packwood ProSolo a couple weeks ago. Constructive criticism is always welcome, thanks guys.
[ame="https://www.youtube.com/watch?v=8qyb5-hWJlI"]https://www.youtube.com/watch?v=8qyb5-hWJlI[/ame]
[ame="https://www.youtube.com/watch?v=R1z0VwxscI4"]https://www.youtube.com/watch?v=R1z0VwxscI4[/ame]
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 07-31-2019, 01:02 PM   #255
MoarTorqs
***** Lurker
Drives: 2015 BRZ
Overall the runs look good, but one place that hurt you a little was when you lifted to make the right turn (left course) just after the start. That lift creates a slight loss of acceleration that penalizes you until the end of the slalom. If you initiate the first and second turn smoothly, the car can do it without the lift.
It may only be the difference of a 1/10th through there, but every 1/10th matters. It might also be interesting to see what the data says about the difference in your runs vs Glen's from the start to the end of the slalom.
MoarTorqs is offline   Reply With Quote
Old 10-10-2019, 10:47 AM   #256
MX-5RACER
Drives: 1999 Miata
Here are my first two runs in my newly set-up STX BRZ (Could not get the GoPro to connect to the head unit and thanks to the iOS 13 update the GoPro app no longer works on my phone).
Current set-up:
Feal 441+ coil-overs, swift springs
Megan Front sway bar
SPC rear lower control arm
Momentum Intake
Perrin Crank pulley
HKS EL Header
Custom 2.5" exhaust from the header back
OFT Stage 2+ tune (Optimized by me)
Rota Grid 17x9 +35 wheels
RE-71r's (First event on these tires, love Rivals, these are MEH. Too noisy)
Front Pressure(Starting): 30psi
Rear Pressure (Starting): 28psi
Alignment is as follows:
Front:
Camber:-2.1 degrees negative
Caster: +6.5
Toe: 1/16" Toe-out
Rear:
Camber: -1.5 degrees negative
Toe: 1/16" Toe-in
Car was pushy and would transition to oversteer. Between these runs I adjusted the front struts which made the push a little better, but not cured. This made the second run very loose, I adjusted the rear shocks and dialed the car in as much as I could, but I think I need front camber bolts to get more front camber. With more front camber, I can then dial in more rear camber (Limited because of front camber).
Thoughts?
[ame]https://www.youtube.com/watch?v=778Zq28iozs[/ame]
[ame]https://www.youtube.com/watch?v=TcsFZsUgAWc[/ame]
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
Old 10-10-2019, 11:03 AM   #257
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yes more camber, wouldn't go any less than -3F/-2R, if the stones are fresh they need to scrub in a bit so they'll get better imho, looks like you've got a good starting point.
ineedyourdiddly
MX-5RACER (10-11-2019)
Old 10-11-2019, 09:43 AM   #258
MX-5RACER
Drives: 1999 Miata
I am hoping I can get closer to -3.2 in the front with the camber bolts and be able to back off the camber plates between events. Any idea how adjusting the camber plates affects toe?
I also plan to remove the camber plate bolts and replace them with studs and a nut. I think this will be more reliable when I start adjusting them before and after events.
DJ
Old 10-11-2019, 10:02 AM   #259
strat61caster
Not sure the magnitude of toe change, it certainly happens I just haven't measured in years, but I've been dailying -4 for the past year, you can grab some toe plates to check.
ineedyourdiddly
Old 10-11-2019, 07:29 PM   #260
cueball89
Drives: 23 BRZ 15 Impreza
Originally Posted by MX-5RACER View Post
I am hoping I can closer to -3.2 in the front with the camber bolts and be able to back off the camber plates between events. Any idea how adjusting the camber plates affects toe?
I've measured a 2mm gain of toe in going from camber plates at zero and ~ -2.2 of camber to maxing out the camber plates and getting up to ~ -3.2 of camber. YMMV.
cueball89 is offline   Reply With Quote
The Following User Says Thank You to cueball89 For This Useful Post:
strat61caster (10-11-2019)
Old 10-12-2019, 08:32 PM   #261
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
I just learned about track addict last autocross so here is my first video with it. It helped me see corners i could take faster, but it clearly didnt help my terrible line.
[ame]https://www.youtube.com/watch?v=FBqm3nACxA0[/ame]
[ame]https://www.youtube.com/watch?v=_9pGn8dxVxE[/ame]
honestly i think i just need to grow more balls and work on better lines. i knocked a second and a half off just noticing i wasnt on the gas or brakes a ton
The Following User Says Thank You to Breadman For This Useful Post:
strat61caster (10-15-2019)
Old 10-15-2019, 10:43 AM   #262
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Lots of rust. SSC car.
[ame]http://youtu.be/7GVfPOyeB48[/ame]
iLuveKetchup is offline   Reply With Quote
The Following User Says Thank You to iLuveKetchup For This Useful Post:
Old 01-26-2020, 02:32 PM   #263
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
This with -.9 degrees of camber up front...need moar camber...and seat time. Always seat time.
[ame]https://www.youtube.com/watch?v=7eMmUa9h6tU[/ame]
BlueWhelan is offline   Reply With Quote
Old 01-26-2020, 05:30 PM   #264
strat61caster
Weird 'not slalom' at 18s or were the cones wrong?
ineedyourdiddly
Old 01-26-2020, 05:47 PM   #265
BlueWhelan
BlueWhelan's Avatar
Yeah the last cone got reset incorrectly sometime during the morning. It wasn't a competition day so everyone just ignored it I guess.
The Following User Says Thank You to BlueWhelan For This Useful Post:
strat61caster (01-26-2020)
Old 08-04-2020, 10:59 AM   #266
iLuveKetchup
Drives: EFF JAY
The new SSC Falken RT660 tires feel great!
Track Videos - Directory and Discussion Dave-ROR Tracking / Autocross / HPDE / Drifting 697 04-13-2024 07:46 AM
*Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* 86SPEED Groupbuys 74 11-09-2016 01:45 PM
Feldys Autocross videos feldy Tracking / Autocross / HPDE / Drifting 25 06-13-2013 02:58 PM
Need help with some tips for autocross Toyota GT 86 Tracking / Autocross / HPDE / Drifting 10 04-30-2013 06:43 AM
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
