Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
09-08-2016, 08:19 PM | #29 | |
Drives: WORKS CARB Legal Turbo BRZ
Couple of things first. These particular Ohlins (SUS-MI20) were recently discontinued (good reminder for us to close this thread). What is now available is the SUS MP20. They are still Road & Tracks, but now use 40 N/mm front springs and 30 N/mm rear. And they do not come with camber plates/top hats. You can check out the complete product details here: http://www.roadandtrackbyohlins.com/...oyota_GT86.pdf We've never tried adjusting Ohlins to the stock height, but we imagine you at least can get pretty close. We're actually installing the new SUS-MP20 on a customer vehicle in the next couple weeks. We'll set them all the way up at first and see where the car sits.
The Following User Says Thank You to WORKS For This Useful Post: | 7 skulls (09-10-2016) |
09-09-2016, 08:48 AM | #30 | |
Drives: Silver Coupe with a Boxer
I think that @BigFatFlip can help out with this question. |
The Following User Says Thank You to driggity For This Useful Post: | WORKS (09-09-2016) |
09-09-2016, 01:31 PM | #31 | ||
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
I'm currently set-up near stock, but ride slightly higher than stock due to my 225 tires. |
09-09-2016, 02:04 PM | #32 |
Drives: 2014 GT86
One thing is ride height. One can up that with any coilovers by simply using lift spacers (eg. from subtle-solutions) above tophats or camplates. That won't change bumpless travel of shocks though. Best possible way would be to both lift car for extra ground clearance & have more shock travel, but most of aftermarket coilovers are targeted at lowering crowd with minimum drop being below stock and paired with reduced travel. IIRC only billstein B6 were for of stock height. Above - only TRD rally coilovers (+10mm). Many suggested KWs or RCE Tarmacs based on them, as while having less then stock height, they have more travel, so that + spacers imho might make up sensible combo. I omitted custom built to order rally suspension options, as $5-15K probably is out of budget for most.
09-10-2016, 08:11 PM | #33 |
Drives: 2014 scion frs
Great info. Sadly, I do not think there is an alignment shop in this area which I would trust to get it all right.
10-10-2016, 03:14 PM | #34 | |
The Following 4 Users Say Thank You to WORKS For This Useful Post: |
10-11-2016, 06:11 AM | #35 |
Drives: fr-s
10-11-2016, 06:16 AM | #36 | |
Drives: fr-s
10-11-2016, 08:28 AM | #37 |
Drives: 2014 GT86
Please, don't write in all-caps. It's considered as shouting in forums.
As for hitting bumpstops, sounds more then possible, given such soft spring rates. Looks like in new version these became only Road, not Track anymore . |
10-11-2016, 04:00 PM | #38 | |
Did you set them up according Ohlins specifications? Are you sure it is the damper bottoming out or could it be just a harsh bump? Or the chassis itself contacting the road? If they are set to Ohlins specifications, trying adjusting the damping to a harder setting (in the 1-7 clicks range for example). We are working on a Stage 2+ kit that will be more track oriented for the weekend warriors, stay tuned!
10-11-2016, 04:30 PM | #39 |
Drives: 2014 GT86
WORKS: what rates are planned for that kit?
10-11-2016, 07:32 PM | #40 |
We have a little more testing to do before we are set on the spring rates. We can offer any valving and spring rate now with the stage 2 kit, at a price... We are also working on camber plates for the kit.
03-20-2017, 12:23 AM | #42 |
Drives: t
update on stage2?
Similar Threads | ||||
Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
Coilover choice, Tein SRC or Ohlins R&T | Teo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 72 | 11-23-2015 01:48 AM |
Ohlins Coilover Install | Factory Tour and Interview | Video | Dezoris | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 40 | 04-09-2015 12:10 AM |
FS: Ohlins Road And Track DFV Coilover in Socal | mtsui | Brakes, Suspension, Chassis | 5 | 03-27-2014 11:02 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
