ACE Headers
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission
Old 07-30-2017, 07:16 PM   #1
Asus
Drives: 2013 Scion FRS
Which problem parts should be replaced while engine is out of the car?
My engine developed a bad knock so it's coming out. Don't know if it's getting repaired or replaced with another oem engine yet but my question is are there known issues that should be addressed while the engine is out of the car? I know older Subaru engines had issues with head gaskets and water pumps, is that still and issue with the FA20? Any other recommendations on how to take advantage of the engine being out of the car?
Thanks
Asus is offline   Reply With Quote
Old 07-30-2017, 07:47 PM   #2
bromatic train injury
Remove and thoroughly clean clutch fork, throwout bearing, and transmission front cover.
If there are signs of wear on the front cover, replace both it and the throwout bearing.
Reassemble, ensuring all pivoting and sliding joints are properly lubricated.
Ultramaroon is online now   Reply With Quote
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
Cole (07-31-2017), DAEMANO (08-01-2017), smg1138 (07-31-2017), Teseo (07-30-2017)
Old 07-30-2017, 07:58 PM   #3
Turdinator
Seņor Member
Turdinator's Avatar
Thanks
When I was in the same situation as you I put a light flywheel, heavier duty clutch and a header on while the motor was out. You could maybe do the rear cam plate as some people have had leaks there but I didn't bother. I don't believe there is any part easily replaced that is considered a weakness.
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
Drakiv (07-31-2017), why? (07-31-2017)
Old 07-30-2017, 08:31 PM   #4
Asus
I'll look into the rear cam plate, even if it doesn't need replacing ma as well check it out. Probably throw in a new clutch kit too since it's there. Thanks
Good call, my throwout bearing is definitely messed up and the clutch fork squeaks like crazy
The Following User Says Thank You to Asus For This Useful Post:
Turdinator (07-30-2017)
Old 07-31-2017, 03:30 AM   #5
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
I say the cam plate, easy if the motor is out.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 07-31-2017, 03:39 AM   #6
Captain Snooze
Because compromise
Captain Snooze's Avatar
Drives: Red Herring
From all accounts you should do this:
http://www.ft86club.com/forums/showt...highlight=fork
Unfortunately many pics have been deleted by Photofuckit but some pics are here:
http://www.ft86speedfactory.com/velo...2013-ft86.html
Old 07-31-2017, 05:57 AM   #7
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
lots of other transmission parts can go in too, the mtec springs maybe stronger mounts if you are interested, etc.
why? is offline   Reply With Quote
Old 07-31-2017, 11:26 AM   #8
Timmy_Jones
Spun
Drives: 13' FR-S/MT
Spark plugs?
Timmy_Jones is offline   Reply With Quote
The Following User Says Thank You to Timmy_Jones For This Useful Post:
Old 07-31-2017, 11:33 AM   #9
Somerandom18
Drives: 2017 manual BRZ
Rods.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
The Following User Says Thank You to Somerandom18 For This Useful Post:
Cole (07-31-2017)
Old 07-31-2017, 01:00 PM   #10
All accounts except mine. I'm still not convinced, for the stock clutch at least, that the fork is too weak. I have personally experienced the TOB bind up against the snout (front cover). I'll continue to clean and lube the stock parts while waiting for some long term feedback on the Velox unit.
Old 07-31-2017, 03:41 PM   #11
Thanks
I reckon that depends on what you are going to do with the car when it gets put back together.....??
FI, track it, DD .....other ......??
Old 07-31-2017, 05:11 PM   #12
Captain Snooze
Because compromise
Drives: Red Herring
A I'm still not convinced, for the stock clutch at least, that the fork is too weak.
I'm not suggesting for the stock clutch that the oem fork is too weak but given the engine is already out I think it is a nice/easy mod and you know, because racecar*.
*I don't mean that literally but the Velox fork (and knife and spoon if they're available) is my list of things to do when the clutch needs replacing.
Ultramaroon (07-31-2017)
Old 07-31-2017, 06:31 PM   #13
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
Anyone have the subaru part number for that transmission front cover (snout)? I might get it while I'm replacing the TOB and clutch fork anyways.
Jidonsu is offline   Reply With Quote
Old 07-31-2017, 06:57 PM   #14
Ah. Gotcha.
Replaced transmission fluid, now it's causing problem frslee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 11-02-2016 05:35 PM
Buying BRZ with replaced engine PSim Engine, Exhaust, Transmission 14 10-21-2016 03:06 PM
Reliability of engine with short block replaced ShadowTS Issues | Warranty | Recalls / TSB 4 08-22-2014 11:49 PM
What do you do with the stock parts you've replaced? qtwre Engine, Exhaust, Transmission 23 05-11-2014 02:52 PM
Low Idle/Cam gear - Anyone request to inspect your old/replaced parts? ahausheer Issues | Warranty | Recalls / TSB 7 08-26-2012 03:31 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
