Old 06-11-2014, 04:48 PM   #1
Namuna
Namuna's Avatar
ST Coils, 1" Drop: 17x9 will +35 poke?
I think I'm finally coming into the home stretch as to what wheels I'm going to get. I recently got ST Coils and dropped my car 1" (would've gone more, but NJ potholes are NASTY).
Now I'm considering the RPF1 17x9 in +35 offset, this should sit pretty flush with my setup right? Or am I looking at some poke and need a bigger offset?
I checked the tire/wheel calculator page and it -looks- like the +35 should be fine, but I was hoping for some confirmation.
Thanks.
Namuna is offline   Reply With Quote
Old 06-11-2014, 04:54 PM   #2
Krispeee
you should be fine as long as you dial in some negative camber.
Krispeee is offline   Reply With Quote
The Following User Says Thank You to Krispeee For This Useful Post:
BRZZZZZZZZZZ (06-11-2014)
Old 06-11-2014, 04:59 PM   #3
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
+1
BRZZZZZZZZZZ is offline   Reply With Quote
Old 06-11-2014, 05:15 PM   #4
Namuna
Namuna's Avatar
Ok, here comes the newb question...I only got the coils, no camber/caster plates or LCAs.
Am I able to adjust the camber without those items? Should I just go with a bigger offset?
Sorry for my lack of knowledge, I'm still filling in gaps.
Thanks.
Old 06-11-2014, 05:20 PM   #5
frslee
Just drive it
Drives: 13' FR-S
Thanks.
Front should be adjustable, but if you want to go more, install the camber bolt. Either OEM or SPC. Rear is not adjustable, you need LCA.
I lowered my car 1 inch on springs and my rear cambers are 1.9.
frslee is offline   Reply With Quote
The Following User Says Thank You to frslee For This Useful Post:
Namuna (06-11-2014)
Old 06-11-2014, 05:21 PM   #6
DAEMANO
Time Traveller
Thanks.
You can adjust the front camber around -.7 to -1.4 degrees (or so) with inexpensive crash bolts or camber bolts.
The rears you cannot adjust, but after a 1" drop will get about -1 to -1.5 degrees of "natural" negative camber so they should tuck nicely.
Use the calculator here to check.
http://www.frsproject.com/tire_size.php
The Following User Says Thank You to DAEMANO For This Useful Post:
Namuna (06-11-2014)
Old 06-11-2014, 05:23 PM   #7
Krispeee
Thanks.
ST coils have slotted holes for your bolts in the front, so no need for camber plates. Ask the shop to give you negative camber in the front when getting an alignment.
Your rear should see between -1.8 to -2.1 degrees of camber with a 1 inch drop.
Hope this helps.
Namuna (06-11-2014)
Old 06-11-2014, 05:32 PM   #8
Namuna
Namuna's Avatar
Thanks for the info folks.
I did before. I plugged in the numbers (17x9, +35 offset, -1 ride height, 0 camber) and the tire size I plan to use (245/40r17) and according to the calculator the rears should actually be just a slight bit sunken in, while the fronts are about dead flush.
So I wanted to check-in to make sure.
Old 06-11-2014, 05:34 PM   #9
Krispeee
I'm on the exact same rim/tire size with you with the same 1" drop. You should be good.
Namuna (06-11-2014)
Old 06-11-2014, 05:39 PM   #10
8R6
8R6's Avatar
Drives: FRS
i have 17x9 +38 with 245/40/17 tires. 1" drop with hotchkis springs.
rear camber (non-adjustable) came to -2.0 degrees.
front camber with whiteline adjustable camber bolts maxed out at only -1.3 degrees.
from the top view (looking down at the wheel from fender), my wheel is aaaaaalmost flush (pokes about 1mm). with a +35 wheel, you'll be poking just a tiny bit more unless you can get more camber dialed in.
8R6 is offline   Reply With Quote
Old 06-12-2014, 09:38 PM   #11
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I'm curious to learn from all that are running this setup as well since I want to run this exact configuration with either Volk TE37Vs, Weds TC105ns, or Enkei RPF1s. With "natural" camber maxed with the assistance of camber bolts, seems to be close to flush but curious if you rub if you hit a dip on the freeway (esp in front) seems like rolling of the fenders may be a good idea. To me 17x8.5 +35mm square may be the more perfect size (from a performance perspective) since you probably won't rub at all.
mit_peid is offline   Reply With Quote
Old 06-12-2014, 10:06 PM   #12
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
I'm running 18x9 +35 and no issues at all. Overall tire diameter is the same, only difference is the tire is closer to the perch on the 17" setup whereas the 18" wheelrim is closer on mine.
My camber settings are -2.2 front and -2.0 rear with Eibach ProKits lowered by 1".
No LCA's in the rear but crash bolts in the front (hole widened for a bit extra camber).
To the OP, you won't rub at all. With the 1" drop, you'll gain enough camber to tuck those tires in. Great tire & wheel combo, will be my track setup shortly.
Slick is offline   Reply With Quote
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 17x9.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 10-31-2019 04:22 PM
* Axis OG SAN Wheel - 17x8", 17x9" - SALE * GuerillaRacing Wheels and Tires 105 07-31-2014 06:01 PM
Poke's BRZ build Pokeguyjai Member's Car Journals 5 03-15-2014 11:10 AM
Is there a 17x9 no poke option? Amadeus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 07-04-2013 09:23 AM
What is the "best" drop in filter? Osiris Engine, Exhaust, Transmission 10 04-04-2013 04:39 AM
