Old 07-31-2012, 09:00 AM   #29
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by JohnATL View Post
How about the TRD filter?
Good call. We'll add it to the list.
FT-86 SpeedFactory is offline
Old 07-31-2012, 09:03 AM   #30
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Originally Posted by FT-86 SpeedFactory View Post
Currently we are only missing the APEXi, and the aFe Dry Element. We should have those done in a week or so. Those two filters were a bit behind on the UPS truck.
As more come out we'll keep this thread updated with their data.
Thanx, i think i might pick up the hks since its the cheapest and yielded the same results as the rest. Cant go wrong with a better throttle for 35 bucks
brichard0625 is offline
The Following User Says Thank You to brichard0625 For This Useful Post:
FT-86 SpeedFactory (07-31-2012)
Old 07-31-2012, 09:14 AM   #31
xwd
Do you mean the aFE oiled filter? I'll be interested to see the results since it is supposed to flow quite a bit more than their dry one.
The K&N actually looks like it has the best overall curve out of these 3, the others have the quick torque hit after the dip but at 5K the K&N looks to make slightly more torque and it makes more peak HP. But all within the margin of error so it's hard to really pick any kind of "winner"
xwd is offline
Old 07-31-2012, 09:17 AM   #32
FT-86 SpeedFactory
You're correct, Oiled aFe to be tested yet. Have a couple sitting on the shelf just waiting on the APEXi to arrive.
I was a bit surprised myself by the K&N, and to be honest all 4 of us there that day expected 0 gains across the board. So the results to us were interesting as well.
Old 07-31-2012, 09:32 AM   #33
YoKeutla
Drives: Scion FRS
Originally Posted by ahausheer View Post
Other tuners saw zero gains without any filter. I dont think 5 is reasonable at all.
You can take the results anyway you want. As stated before, we have nothing to gain here and were looking for cut and dry dyno results. We got the car strapped down, up to operating temperature, and started doing pulls. In-between runs, the only thing changed were the filters. Cut, dry, and really simple.
Here is some food for thought, as well. Do you think other tuners would have you buy a $60 drop-in filter or a $350 intake system?? (rhetorical, not looking for a discussion here)
These are just independent tests that we hope to benefit the community.
Sponsored By: FT-86 SpeedFactory - http://ft86speedfactory.com
Cheers!:happy0180:
YO
YoKeutla is offline
The Following 2 Users Say Thank You to YoKeutla For This Useful Post:
kombatlion (05-03-2013), uptown (08-19-2012)
Old 07-31-2012, 09:35 AM   #34
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Is this 5 wheel hp?
Hanzo is offline
Old 07-31-2012, 09:37 AM   #35
brichard0625
i placed my order : D...now to find some parts for my custom intake and some paint so that i can make everything look purdy
The Following 3 Users Say Thank You to brichard0625 For This Useful Post:
FT-86 SpeedFactory (07-31-2012), tripjammer (07-31-2012), YoKeutla (07-31-2012)
Old 07-31-2012, 09:44 AM   #36
FT-86 SpeedFactory
Originally Posted by Hanzo View Post
Is this 5 wheel hp?
Allegedly, yes.
Each dyno, each car, and each days temperatures / humidity are different and different results will likely occur.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Hanzo (07-31-2012)
Old 07-31-2012, 09:50 AM   #37
Hanzo
Hanzo's Avatar
Does these filter make the car run any smoother in the higher rpms?
Hanzo is offline
Old 07-31-2012, 09:52 AM   #38
YoKeutla
Drives: Scion FRS
Allegedly, yes.
Also, to add to that, this is PEAK hp. The point in which maximum hp was reached, which is high in the rpm range where the engine is needing the most air. Not a 5hp increase across the powerband.
Cheers!:happy0180:
YO
YoKeutla is offline
Old 07-31-2012, 10:02 AM   #39
UncleFester
How about a run with no filter?
UncleFester is offline
Old 07-31-2012, 10:17 AM   #40
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
If you go ahead and read the thread about the tuners that ran without filter for no gain, you would find that one of them, found there was gain with a drop in filter even though there was no gain without a filter.
Sportsguy83 is offline
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
ahausheer (07-31-2012), YoKeutla (07-31-2012)
Old 07-31-2012, 10:20 AM   #41
knapper
knapper's Avatar
Drives: '13 Scion FR-S - Whiteout
Are you serious?
knapper is offline
Old 07-31-2012, 10:20 AM   #42
Hanzo
Hanzo's Avatar
Sometimes it's better to have some restriction to increase the speed of flow. It's like if you pinch the tip of a water hose the water flows faster.
Hanzo is offline
AT/MT Dyno Results with/without Mods blackfireball5 Engine, Exhaust, Transmission 0 07-04-2012 02:34 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
K&N Drop-In Filter for BRZ/FR-S in stock! Mach V Dan Engine, Exhaust, Bolt-Ons 0 06-27-2012 02:41 PM
Dyno results for the Nameless Performance street package! John@Nameless Announcements, Contests, Giveaways 31 06-26-2012 04:37 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
