12-28-2021, 08:24 PM | #29 |
Drives: 2022 BRZ WRB
12-28-2021, 08:36 PM | #30 | |
Drives: 2022 GR86
Exactly, hence my interest in lowering the seat.
The Following User Says Thank You to timurrrr For This Useful Post: | Ultramaroon (12-28-2021) |
12-29-2021, 01:26 PM | #31 |
Drives: '22 Tacoma, '19 Macan, '22 BRZ
Yeah Timurrr, for long torso folk it can have a bad effect if you're pushing the seat further back and hitting the slope with your head. But for the long legged tall folk, it's a great help.
The Following User Says Thank You to Re_Invention For This Useful Post: | timurrrr (12-29-2021) |
12-29-2021, 01:55 PM | #32 |
Drives: 2022 GR86
btw I think the shape of the ceiling in the 2022 has been simplified, so that slope might be less of an issue.
12-29-2021, 09:23 PM | #33 | |
Drives: 2022 BRZ Limited
I will buy for the BRZ too. I don't need 2in with the telescoping steering wheel all the way out, but I can slide it back in a bit if need be. Very cool. NC part already ordered! I would also take an inch lower seat on the BRZ. I have about an inch above my helmet, but I would like more. Blackbird or 949 can have more of my money if they make something. |
The Following 2 Users Say Thank You to Scubadriver For This Useful Post: | PBR (01-01-2022), Re_Invention (12-30-2021) |
12-30-2021, 03:01 PM | #34 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Lots of good comments. I’m a tall torso guy so that’s my issue. Haven’t ruled it out yet (mostly because with the car market these days I literally just don’t see anything good to buy) but will keep an eye out for updates and continue thrashing my 13 for now.
12-30-2021, 09:11 PM | #35 |
Drives: Previously evo x
So for taller guys, what about a seat replacement? I normally don't mess with that stuff do to all the safety things you can change but it seems for this car I will prob need a bucket being that I'm 6'2" and like to go racing so will need room for a helmet!
12-30-2021, 09:31 PM | #36 |
Drives: 2022 BRZ
I'm 6'2, I brought a helmet along on my test drive to see how well I Fit. The helmet just touches the headliner. So yeah, it will depend on your specific anthropometry. You won't know without sitting in one to find out for yourself.
The Following User Says Thank You to mpg9999 For This Useful Post: | BRZZZZZZZZZZ (12-31-2021) |
01-01-2022, 12:13 AM | #37 | |||
Drives: 2022 GR86
For starters, you lose side airbags. Well, ok, you might be lucky if you live in Europe, or willing to pay ~$6k to import these seats into the US: Quote:
If you get a fixed-back bucket seat like most do, some would argue that it's unsafe to use them at the track without at least a half cage; and some orgs/techs might not let you out on track. There's probably 15 existing threads on this forum where people discuss whether it's safe or not. Getting a proper half-cage will also cost you a few thousand dollars if you decide to do it. |
The Following 2 Users Say Thank You to timurrrr For This Useful Post: | Midnightsky (01-01-2022), PBR (01-01-2022) |
01-01-2022, 03:41 AM | #38 | |
01-01-2022, 04:45 AM | #39 | ||
Meow
Drives: GT86, Volvo 996
Isn't there a spring mod that can be done like on gen. 1s? Otherwise, a cheaper way to get Recaro CSs is to look up gen. 3 FL Renault Clio RS used seats from Europe, as they could be fitted with optional Recaro CSs with airbags. However, I have no idea whether the airbag would connect to our wiring harness, whether it would actually help safety in the 86's interior, and whether the seat would bring any headroom improvement. |
01-01-2022, 09:28 AM | #40 |
Grey Man
Drives: 22 MT BRZ
I'm 6'4.5" (35" inseam) and I ordered the 22 BRZ in July and picked it up in late November. I took a gamble on whether the car would fit me or not and whether the prior performance issues would be corrected. That gamble paid off. It fits me ok, barely. The seat is slid back to it's limit and reclined to the point of leaning against the back seat platform. I could not wear a helmet in this or most other cars. The seating position is ok; it's comfortable; I'm used to it. I have to recline the seat in every car I get into.
A racing seat could mount directly to the floor and sit lower and be mounted back a bit. I don't particularly want to go that route. I would not recommend the car to someone my size and risk being blamed if they decided to whine and moan about the fit, However, I would absolutely buy the car again and will likely keep this one a very long time. |
The Following 4 Users Say Thank You to *Axel For This Useful Post: |
01-01-2022, 11:11 AM | #41 |
Returned home from the holidays and took a closer look at the seat. The back of the seat rail is held up off the floor by an approximately 1cm spacer. I pulled the bolt and it did not separate from the rail easily. It doesn't feel like metal so I can't expect it is too permanently attached. I will see if I can pull the seat this weekend and get them off. That's may be the 1/2in I was looking for.
The Following 3 Users Say Thank You to Scubadriver For This Useful Post: |
01-01-2022, 12:44 PM | #42 |
I took a closer look at the spacer. They do appear to be welded in place but they could probably.be taken off with a bit of effort. That's the back.
The front could also be lowered a similar amount. The front section of the rail holds it about 1 cm off the hump in the floor. This front section could be replaced by a flat piece. Hard to understand why the elevated the seat like this... |
The Following 2 Users Say Thank You to Scubadriver For This Useful Post: | BRZZZZZZZZZZ (01-01-2022), Ohio Enthusiast (01-03-2022) |
Similar Threads | ||||
I finally found seats for big and tall people! | arkanist | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 11-26-2019 05:31 PM |
How tall are you | djmm | Scion FR-S / Toyota 86 GT86 General Forum | 122 | 12-26-2013 04:05 PM |
Portland people meet with Seattle area people before going into ForumFest 2013? | stockysnail | Northwest | 24 | 06-18-2013 06:19 PM |
Seat fit for tall people? | clubraf | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 06-29-2012 10:51 AM |
How tall are you? | ichitaka05 | Off-Topic Lounge [WARNING: NO POLITICS] | 111 | 11-14-2011 03:32 AM |
