05-06-2014, 03:01 AM | #113 |
Drives: Stock frs
I just test fitted mine today, they barely rub at full lock. No fender work done either. But ill be getting my fenders rolled this week. Take a look at my thread i just posted.
05-06-2014, 05:35 AM | #114 |
Drives: Ultramarine '13 FR-S
i have 18x9.5 with 255/35/18's and very very little camber (if any) and they fit with out rub
05-06-2014, 07:43 AM | #115 |
Kouki-Monster
Do they clear the control arm at lock? I have 18x9.5 +43 RS05RR'S sitting in my living room and don't want to install them if the fit sucks
Sent from my SGH-I337M using Tapatalk
Rich Anderson
EMPOWER AUTO |
05-06-2014, 08:50 AM | #116 |
Drives: '13 BRZ
There is another thread for 18x9.5 xD. Maybe there are more people on that threat that have that spec than on this thread where they are mainly 18x8.5 :P
Probably better to post your questions and answers there so that people with the same issue and that spec rim will be looking in the right area |
The Following User Says Thank You to tinma For This Useful Post: | livert (05-06-2014) |
05-06-2014, 09:20 AM | #117 | |
Drives: FR-S 10 series
05-06-2014, 01:56 PM | #118 |
Drives: Ultramarine Blue FR-S
I have 9.5 with 255/35 up front. Only rubs a little at full lock. Camber is at about -2.
05-23-2014, 08:13 AM | #119 |
Ok, everything fits PERFECT with no rubbing issues. Just put them on yesterday.
18x8.5 and 18x9.5. (235/40/18, 255/35/18 respectivley) Lowerd on TRD springs No rubbing at any moment, miles of clearance in the rear from the suspension... I MIGHT be able to sneak in 265, but im scared it will rub the sheet metal as the 255's JUST sit behind the metal. I woul be worried in heavy cornering were the wheel digs into the well that the rubber would contact the metal with 265. My only problem with 255 on a 9.5 is that the leave a little bit of a lip and i prefer rubber to be perfectly flush with rim... It looks awesome anyways. In front i dont think i can go bigger than 235. I can barley wedge my finger between spring and rubber... Its that tight, but absolutley no contact in full lock and extreme cornering. All in all i am extremeley happy. Havent done alignment yet, ill post up the results when i do Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Pablitomarrero For This Useful Post: | Bimble Bamble (10-30-2016) |
05-23-2014, 08:16 AM | #120 |
The Following 5 Users Say Thank You to Pablitomarrero For This Useful Post: | chas3wba0 (07-11-2014), JonAvalon (05-23-2014), lamune (10-30-2014), UltraMarine86 (05-23-2014), Zaku (05-29-2014) |
05-23-2014, 09:49 AM | #121 | |
Sent from my SCH-I605 using Tapatalk |
05-23-2014, 09:51 AM | #122 | |
The Following User Says Thank You to Pablitomarrero For This Useful Post: | RD1428 (03-24-2015) |
05-23-2014, 09:52 AM | #123 |
Im going to switch tire sizes today in the rear... Gonna try 265. I dont think it will rub, i just think that there is too much exposed lip...
05-23-2014, 12:25 PM | #124 |
Yeah that's what I'm gonna try next. My 255/35's are very slightly stretched
05-23-2014, 02:21 PM | #125 | |
05-23-2014, 02:43 PM | #126 |
So your doing 255/35 front and 265/35 rear?
Similar Threads | ||||
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 10:30 AM |
Gauging interest Enkei RS05RR 18x9+40/18x8.5+50/18x8.5+42 | THMotorsports.com | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 09-19-2013 04:33 PM |
Wheel Directory: BBS LM 18x8.0 +50 | stoneman155 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 07-08-2013 07:55 PM |
Wheel Directory: BBS RE 18x8.0 +50 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 06-25-2013 08:49 PM |
