Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
09-02-2017, 10:34 PM | #1 |
Drives: 2014 BRZ
Clunk noise no power
I was driving to work all of a sudden lost power heard a rattling noise so I pulled over before I even stopped the car died and would not turn on.. towed back home ob2 tester says nothing wrong but wont crank and all check lights are on. i charged the battery and still won't crank.
Not sure what to do next. I don't see any external damage |
09-02-2017, 11:08 PM | #2 |
義理チョコ
Have it trailered to the shop. Time for expensive engine parts.
09-02-2017, 11:28 PM | #3 |
Drives: 2014 BRZ
I live in SanDiego does anyone have any recommendation on a shop to take it to?
If i have to rebuild the motor might as well make it fast. |
09-02-2017, 11:34 PM | #4 |
義理チョコ
Making it fast just makes it more expensive, especially if you aren't up for doing the work yourself. Not judging, just how it is.
Get it checked out to see what's up and go from there, IMO. Try posting in the SoCal regional area. I bet you get some solid leads. Or this.
09-02-2017, 11:45 PM | #5 | |
Drives: brz
buy used engine with low mileage if you want to drop it in one day. cause buying new part might take some time if out of stock or to ship and you might need to take the head and block to a machine shop. |
09-03-2017, 01:23 AM | #6 | |
Any power mods ..... ?? What's the last thing you did to the engine .. ?? Are you sure it's not out of gas .. ?? You say it won't crank ...... do you mean the engine won't not turn over or it just won't fire .. ?? Come back. humfrz |
09-03-2017, 02:28 AM | #7 |
Maybe I misread but why would you possibly need to take a new engine to a machine shop?
09-03-2017, 04:41 AM | #8 | |
Drives: brz
not a new engine i mean if he will rebuild the engine he might need to resurface the heads and the block will need to be bored to fit new piston. im not sure if Subaru sells oversize piston or if he will have to change the sleeve. if he is gonna buy a whole new engine or short block he wont need to rebuild it |
The Following User Says Thank You to QTR FMS For This Useful Post: | Tcoat (09-03-2017) |
09-03-2017, 07:24 AM | #9 |
Drives: 2014 BRZ
When I go to turn it on it won't even turn likes its struggling really bad. I just changed the oil sunday and I only mods ive done to the car are cold air and exhaust cat back 😢😢.
09-03-2017, 08:24 AM | #10 |
86
money on it is your CAI blocked
09-03-2017, 11:47 AM | #11 |
Drives: 2014 BRZ
09-03-2017, 01:37 PM | #12 | |
Will the key turn in the cylinder ..?? If so, do you hear a "click" ... ?? Again, does the starter turn the engine over ... ?? Have you checked the oil level ... ?? humfrz |
09-03-2017, 01:40 PM | #13 |
I doubt the CAI is blocked ( @Boomerang - how in the heck to you figure that is keeping the engine from starting ...... ) ........ however, to test that theory, just remove the CAI and try to start the engine.
humfrz |
09-03-2017, 04:26 PM | #14 |
Drives: 2014 BRZ
Changed they battery turns over and starts but sound like something is banging around in there on the right side.
https://instagram.com/p/BYl5mrBAyN9/ |
Similar Threads | ||||
Clunk noise at 24mph only once... | Mikem53 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 10-27-2014 05:22 PM |
Loud clunk noise when i pull E-Brake | Deagle50 | Issues | Warranty | Recalls / TSB | 28 | 09-20-2014 01:01 AM |
Clunk noise when put into park | ButtonMasher | Issues | Warranty | Recalls / TSB | 4 | 03-17-2014 02:13 PM |
2,000-3,500k bogging power brapp noise. | MaXimus | Issues | Warranty | Recalls / TSB | 29 | 03-13-2014 08:03 AM |
Cold Start Clunk Noise | Luckrider | Issues | Warranty | Recalls / TSB | 6 | 11-28-2013 05:02 PM |
