05-16-2019, 09:46 AM | #1163 |
Drives: 2013 Ultramarine FR-S
Trying to Kill the drone at 2000 rpm. Should help quite a bit. Just going to have to get creative with a brace for the end to make sure I don't break the welds or anything.
This way, or possibly one right behind the other one:
05-17-2019, 01:55 PM | #1164 |
More partial projects:
A/C Condenser acquired. It has an odd twist to it that I may try fixing, but besides that everything looks decent. I just need to figure out the mounting and get some lines made. I also need to figure out wiring. Seems Colin no longer works for MRS, which is probably the reason I haven't seen anything from him in a while; but that also means there probably isn't any hope of product updates. Can't even find them on their website any more.
05-17-2019, 02:10 PM | #1165 | |
Drives: 2015 FRS - FFR GTM
Saw a thread earlier this week that implied this. This isn't good. What are you thinking about for wiring???
2015 FR-S - One Day I'll Finish The Swap |
05-17-2019, 02:27 PM | #1166 | |
If the MRS device doesn't work with A/C I am going to have to look into switching canbus/going standalone
05-17-2019, 04:40 PM | #1167 |
Drives: 14 BSP Edelbrock BRZ
What happened to your hood vents?
05-17-2019, 04:45 PM | #1168 |
Printed in PLA as a test print. Has a very low tolerance for heat/uv light. I have PETG which will withstand the heat and UV much better. I just need to get them printed.
The Following User Says Thank You to DustinS For This Useful Post: | zeal86 (05-17-2019) |
05-17-2019, 04:48 PM | #1169 |
Drives: 2015 frs
Swap time makes a canbus module for gm swaps. You may look into contacting Mitch he is the one who made my harness. Gerald also may have a solution for you he is on this forum.
05-17-2019, 09:22 PM | #1170 | |
Drives: LS Swapped Scion FRS = 440HP
I see him about once every other week or so at car meetups.
05-24-2019, 02:09 PM | #1171 |
Fitting and hose came in, I will need a few more fittings, mainly ones for the factory pressure switch, and with fill ports.
Also need the fittings for the condenser:
05-24-2019, 02:38 PM | #1172 | |
Drives: Red BRZ
Sent from my SM-G950U using Tapatalk |
05-24-2019, 02:47 PM | #1173 |
$70 from ebay. and I will take it to a shop to get crimped. Though I don't think the crimp tools are too crazy to buy from amazon or ebay.
05-24-2019, 02:49 PM | #1174 |
Drives: Red BRZ
05-24-2019, 02:50 PM | #1175 | |
05-24-2019, 02:54 PM | #1176 | |
Drives: Red BRZ
Similar Threads | ||||
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
Ls or 2jz swap? | sgoldberg01 | BRZ First-Gen (2012+) -- General Topics | 13 | 03-22-2016 03:07 PM |
Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-21-2015 11:38 PM |
AT-->MT swap | AlwaysSideways | Want-To-Buy Requests | 3 | 12-15-2014 11:14 AM |
Should I swap? | michaelahess | BRZ First-Gen (2012+) -- General Topics | 8 | 06-12-2012 07:32 PM |
