Old 08-18-2023, 04:45 PM   #267
dynarun55
Drives: 2015 midnight blue limited edition.
Originally Posted by Ignore Your Doctor View Post
2015 BRZ
JRSC C38 w/ HBP
Walbro 450 pump
ID1050x
Delicious tuning e85 kit 68-70% ethanol
JDL 4-2-1 EL headers w/ Nameless combo pipe and perrin 3" CBE
Nice! Did you measure on pump gas as well ?
Sent from my Pixel 6 Pro using Tapatalk
dynarun55 is offline   Reply With Quote
Old 08-19-2023, 11:54 PM   #268
tomm.brz
Drives: brz 2017 hksv2
e85 coul give you a lot more gain than +20hp peak
Old 08-21-2023, 11:05 PM   #269
Ignore Your Doctor
Ignore Your Doctor's Avatar
Drives: 2015 BRZ WRB
not with the hbp, new injectors, and pump. it was making around 290 with the c38 and headers + exhaust
Ignore Your Doctor is offline   Reply With Quote
Old 08-22-2023, 07:56 AM   #270
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
either something is wrong with your car or the dyno
Old 08-22-2023, 09:22 AM   #271
Ignore Your Doctor
mustang dyno so these numbers are at the wheels not the crank. I promise its accurate lol. I have dynos from every time I got it tuned. From 168hp stock all the way to this most recent one.
The Following User Says Thank You to Ignore Your Doctor For This Useful Post:
Breadman (08-24-2023)
Old 08-24-2023, 10:03 AM   #272
Breadman
Breadman's Avatar
Missed the mustang dyno part. Makes sense when you add 5-10% to get dynojet numbers. Taking the base run numbers and doing back of the napkin fast and furious math also pretty much matches
Old 09-12-2023, 10:00 PM   #273
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
JRSC, low boost pulley, E85 on DynoJet.
JRSC, low boost pulley, E85.
canyons is offline   Reply With Quote
Old 09-12-2023, 10:04 PM   #274
dynarun55
Attachment 222349
Nice!! Time for HBP
Old 03-26-2024, 09:41 AM   #275
Eaton PSI
Drives: 2013 86
Harrop supercharged
-Rod/Eaton PSI
-Harrop SC
-98ron
-9psi
-85mm pulley, billet 90mm 11.5:1 pistons (2.2L), custom LAsleeve liners, forged rods, lightened OEM valves, lightened OEM flywheel, WRX oil pump, minor head porting, fully balanced.
Stock exhaust, airbox/filter, injectors. ECUtek tune.
Eaton PSI is offline   Reply With Quote
The Following User Says Thank You to Eaton PSI For This Useful Post:
tomm.brz (03-26-2024)
Old 03-26-2024, 11:57 AM   #276
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
IAG Closed Deck Block
Cometic Head Gasket (lowering compression to 12.2:1)
Edelbrock Supercharger with 2.70" pulley
E80 Fuel with Ptuning flex kit
Radium in tank pump with Warlbro 450
Radium parallel feed fuel rails
IDX1050 injectors
JDL 4-2-1 headers
CSG 70mm exhaust
Built heads with Ferrea oversize valves and springs, ported/polished/radiused
Fluidampr Harmonic balancer
ACT clutch/flywheel
3.7 Final Drive
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 10:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
