Old 03-28-2013, 02:21 PM   #29
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I'll be venturing into this waters tomorrow... wish me luck!!!
Old 03-28-2013, 02:37 PM   #30
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The key is stopping the engine from moving by jacking it up. Hit me up if you run into problems.
The Following User Says Thank You to King Tut For This Useful Post:
YouShallKnow (12-13-2014)
Old 03-28-2013, 02:42 PM   #31
Sportsguy83
Drives: Limited BRZ
Will definitely do! Thanks for always helping with tips!
Old 03-28-2013, 02:51 PM   #32
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
I'd like to see that write up with some pics from 1point4...
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
Sportsguy83 (03-28-2013)
Old 04-05-2013, 06:57 PM   #33
NickFRS
Drives: 2013 Asphalt FRS
I'm installing my ACT clutch/flywheel at the end of the month. Is it necessary to drain the transmission? Mines currently full of Redline good stuff oil and only 4k miles on it....
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 04-05-2013, 08:21 PM   #34
Supermassive
Supermassive's Avatar
You will have to replace the oil. When you pull the drive shaft out oil will leak from the back of the tranny. Also you will have to tilt the tranny a bit to get it out. So yes you will need to replace the oil.
Supermassive is offline   Reply With Quote
Old 04-05-2013, 10:10 PM   #35
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You will need to REMOVE the transmission oil, but you can put it back in if you want. By the way I didn't drain mine, and I spilled a ton of fluid in the process on my buddy's garage floor, haha.
NickFRS (04-05-2013)
Old 04-05-2013, 10:38 PM   #36
NickFRS
Guess i'll have to wash out some milk cartons!
P.s THX for the DIY!!!
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 07-07-2013, 08:07 AM   #37
jdm-az-fuk
Drives: 2013 Fr-S
Once again, you pulled threw. Props man, props.
jdm-az-fuk is offline   Reply With Quote
Old 08-08-2013, 10:27 PM   #38
InvalidJohnny5
The Based God
InvalidJohnny5's Avatar
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
Ok so I'm installing my clutch tomorrow, is it necessary to remove the shifter and center consul? Cause I have a self-auto shop on base with a 2 & 4 post lift and all the essential tools.
InvalidJohnny5 is offline   Reply With Quote
Old 08-11-2013, 10:02 PM   #39
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Cant wait to try this out tomorrow, Ugh.....fought with this for over an hour trying to get tranny back on....finally pulled it off, 1 little dab of ky, bam! slid right on first try.... Do lightly, LIGHTLY lubricate the spline.
gdrider77 is offline   Reply With Quote
Old 08-13-2013, 06:39 PM   #40
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Subscribed..
Scooby South is offline   Reply With Quote
Old 12-05-2013, 11:57 AM   #41
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I think I might do this today. If I start it today, I want to finish today. Hmmm...
Well put together DIY though. Thanks!
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 02-23-2014, 09:31 PM   #42
stueck9356
Drives: 2015 VW GTI SE
Necro posting, but I really really want to thank you for the write up. I stripped the passenger side spring bolt (was installing mtec springs) and had to pull the transmission to get a buddy to attempt to re-thread it. The little hints, like tapping on the diff side of the driveshaft really worked.
Me and a lady friend did this in about 5 hours. Had her tagging and bagging bolts, handing me sockets and assisted with small things. 2 people can really cut down the time.
stueck9356 is offline   Reply With Quote
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Chase Bays Clutch Line, Full Replacement Chase Bays Transmission and Driveline 1 02-11-2013 02:57 PM
Clutch/flywheel replacement? bucket BRZ First-Gen (2012+) -- General Topics 1 11-19-2012 12:25 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
