Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
03-18-2019, 05:52 PM | #1 |
Drives: 2014 Scion FR-S
Spacers and Track Days
I'm thinking of purchasing 17x9 Enkei RPF1 wheels with a +45 offset. My understanding is that I will need a 3mm for the wheel to clear the strut tower. My question is, are spacers okay for track/autocross use? I've never used spacers before and I worry that adding this part will slightly decrease the stability of the wheel.
Thanks! |
03-18-2019, 06:06 PM | #2 | |
Country Boy 4 Life
Tons of track guys are running a much thicker spacer to be able to clear big brakes. You will be fine with a 3mm. Additionally, with stock springs (or lowering springs) you would need a thicker spacer (or coilovers) to be able to add negative camber.
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | Jordanwolf (03-19-2019) |
03-18-2019, 06:45 PM | #3 |
Rust bucket enthusiast
If not using a bolt on spacer, I'd get extended lugs for peace of mind. 3mm may not be much, but you want every thread you can get holding your wheels on.
03-18-2019, 06:47 PM | #4 | |
Drives: 13 SWP BRZ
I know multiple people who run them in autox even if brake clearance is not an issue to get the track width closer front to rear. If you are worried about spring perch clearance, get the +35 or some other wheel with a +42 or lower offset. |
The Following User Says Thank You to cactus For This Useful Post: | AFRichZC6 (03-18-2019) |
03-18-2019, 07:04 PM | #5 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
ARP extended studs and slip on spacers would be my reccomendation
03-18-2019, 07:12 PM | #6 |
I expect to get some hate for this but I run 16mm (front) and 50mm (rear) adapter spacer on my TEs. Around 5ish auto X and 3 track events
03-18-2019, 08:52 PM | #7 |
I will look for the much harder to find +35, which currently is not even advertised on Enkei's website (or I just suck at interwebs :p), but barring that I am less worried about using spacers now. Thanks to all who replied!
03-19-2019, 08:38 AM | #8 | |
Rice King
????żżż https://www.ft86speedfactory.com/whe...nufacturer=478
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
The Following User Says Thank You to Jordanwolf For This Useful Post: | Leonardo (03-19-2019) |
03-19-2019, 09:55 AM | #9 |
Drives: Track preped NA FRS
3mm is fine, stop freaking out people. I ran several seasons with 5mm spacers on on semi-slicks if that makes you feel any better (have yet to strip a single thread or have any problem related to it and I change tires several times at each track event).
Similar Threads | ||||
Track Days With GPS Track Time! | Guff | Great Lakes | 2 | 03-11-2016 10:47 PM |
Oct Track Days | Lunatic | Tracking / Autocross / HPDE / Drifting | 0 | 09-22-2014 11:46 PM |
chicagoland track days | sickmint79 | Great Lakes | 0 | 09-01-2014 04:40 PM |
Track Days... anybody going here? | chjno86 | Southern California | 1 | 05-31-2013 04:45 AM |
