Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-15-2018, 04:15 AM | #1 |
Drives: Boosted
Breaking in clutch questions.
Hi everyone, just picked up a fx300 and I had a few questions about breaking it in.
1) How high of an RPM should I rev to get into 1st? 2) How would I downshift? i.e 6th cruising down to 30mph need to go into 4th, do I set it into 4th and just ease out the clutch without gas? Or do I use a bit of gas and rev match to 4th? 3) If I mainly have to go towards the highway, any speeds I shouldn't pass? 4) RPM's to shift at? 5) How long can I hold a clutch at the engagement point before it starts burning? 6) Any other tips? Concerns? Thanks everyone! *P.S this is for a different car, but the other car community sucks **** and hasn't answered this question so figured I'd go back to my original fr-s community* |
06-15-2018, 08:42 AM | #2 | |
06-15-2018, 09:16 AM | #3 |
Yeah, just don't slip the crap out of it and you are fine. TBO I've never altered my driving style on a new clutch. But I also don't slip my clutch even after break in. I've seen people use the clutch to hold the car on a hill (which is bad even on a broken in clutch). Don't do anything like that.
06-15-2018, 10:39 AM | #4 |
Drives: 2014 GT86
Actually imho mentioned in forums specific rpms or techniques to shift will only confuse & endanger you, if you'll divert lot of your attention trying to follow any.
Just drive. |
06-15-2018, 12:41 PM | #5 |
Drives: Boosted
Such a fast reply ;_:. Joined the civicx community and don't think anyone knows what a clutch or flywheel is.. The engagement of the 10th gen civics engages stupidly high and the pedals are so soft so it's pretty hard to not slip it into gear while shifting up in the rears(probably due to a CDV). Not sure if the FR-S has this, only had an auto fr-s.
06-15-2018, 01:03 PM | #6 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (06-17-2018) |
06-15-2018, 01:05 PM | #7 |
Drives: Boosted
Yeah I'm only very concerned for the fx350(not 300 sorry) because everyone on the other forums are saying they have been slipping super quick and some are slipping on the dynos.
06-15-2018, 06:58 PM | #8 | |
humfrz |
06-17-2018, 04:05 AM | #9 |
Drives: Boosted
How would I move into first gear without slipping the clutch? I never got how people blipped the throttle and got going. I've always had to move my foot to the friction point and just gas it while letting the clutch out slowly. Isn't this slipping it? Also, my other car has a delay valve that shoots the rpms up a bit every time i push the clutch in, if I don't give it some gas while letting the clutch out into the next gear, the car jerks a little. Are these a problem or will I have to live with it?
06-17-2018, 03:23 PM | #10 |
義理チョコ
Overthinking it. It sounds like you just need practice in coordinating between what your left and right foot are doing.
The standing throttle blip is just a way to use the kinetic energy of the flywheel to start the car rolling. It's nice because it reduces the time spent slipping the clutch. Try forgetting about the tach. Don't even watch it. 1. In a parking lot away from others, practice starting out in first gear without applying any throttle. 2. When you have that mastered, really mastered, start adding a little throttle to get rolling. You'll notice that if you engage the clutch while the engine is slowing down, there's a rhythm where it falls into place and there's no jerk. Smooth upshifts and downshifts are all about controlling engine speed to match what the rest of the car expects it to be. Just takes feel and can be mastered no matter what the RPM. It is more difficult at higher RPM because the difference in engine speed is much wider than when shifting at lower RPM. Therefore, the rhythm is different.
06-17-2018, 05:08 PM | #11 | |
Drives: Boosted
06-17-2018, 05:43 PM | #12 |
義理チョコ
We can still discuss your cool new clutch.
06-17-2018, 06:42 PM | #13 |
Drives: Boosted
I just never really though about how much I can slip a clutch on a fx350 while breaking it in. Normally I slip the clutch a little going up to next gear for a smooth transition but when people say don't slip the clutch, do they actually mean at all? Or like revving to 3k and slipping it? This is why I'm super confused about all this. I need to slip the clutch going into first. I mean I get going in less than a second at 1500 rpm or so.
06-17-2018, 07:48 PM | #14 | |
義理チョコ
The object is to minimize the total amount of heat energy transferred through the clutch with each operation so that, as it's operated over time, the amount of heat dumped into it doesn't exceed its ability to shed it through the pressure plate and flywheel. This rate of heat over time is called power. Horsepower, KiloWatts, Joules per second, whatever. If hands are rubbed together lightly enough, they never get too hot no matter how long they are rubbed. Next, rub them together with medium force 20 times, stop, and hold. How long does it take for your hands to cool down. Rub them together again but this time really hard. See where I'm going? You can launch but give your clutch a chance to cool. That's why I cringe whenever I hear the sound of throttle being applied before clutch is fully engaged. Sloppy upshift is a horrible waste.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (06-17-2018) |
Similar Threads | ||||
Brake and Clutch fluid questions | ducky106 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 03-04-2019 08:58 AM |
I keep breaking lug studs!!! | Guff | Issues | Warranty | Recalls / TSB | 59 | 12-30-2015 12:34 AM |
Clutch install questions | wootwoot | Engine, Exhaust, Transmission | 25 | 12-29-2014 04:18 PM |
Breaking-Bad SWP Build | mwjcyber | Member's Car Journals | 7 | 02-17-2014 08:12 PM |
exedy clutch questions | ft86me | Engine, Exhaust, Transmission | 8 | 02-13-2014 09:58 PM |
