Old 11-12-2016, 04:17 PM   #1
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
MCA Suspension "Traction Mod"
Hi All,
Just thought I'd bring these to your attention now that they are released for general consumption.
Our club has been trialling this part in our local series and we are all in agreement they make the car safer and give more drive (traction).
It simply bolts in to change the mounting point of the rear trailing arms and reduces rear anti-squat. It doesn't mess with the alignment at all.
It allows you put more throttle in earlier on corner exit and the car powers forward rather than spitting sideways when you don't want it to. It just puts power to the ground. It also tamed some more than I usually wanted high speed lift off over steer at a particular local track and the car is more confidently adjustable mid corner after a damper and ride height adjustment to get the balance bang on. I raised the rear 5-10mm, adjusted the dampers a little and am very happy with more controlled lift off over steer and better power down.
have a look here: http://mcasuspension.com/traction-mod
I am not affiliated with MCA, I just wanted to raise awareness of these as they're a great cheap mod that will actually help you on track, certainly a better spend than a pair of strut braces for similar money.
86•BRZ is offline   Reply With Quote
The Following 9 Users Say Thank You to 86•BRZ For This Useful Post:
DustinS (11-14-2016), JMon85 (05-15-2017), kevaughan (01-07-2022), pooch (11-12-2016), smg1138 (11-12-2016), SPCorBUST (03-30-2017), TofuJoe (03-31-2017), Tristor (10-28-2018), whataboutbob (04-15-2017)
Old 11-12-2016, 05:20 PM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
@Racecomp Engineering
@CSG Mike
Old 11-12-2016, 08:44 PM   #3
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I just logged on to post about this new item. Looks like you beat me to it. Looks like it relocates the pickup point for the trailing link a good 2" lower. Very interesting looking new product.
How has this effected the balance of the car? Curious if it would have an effect at entry or does it mainly effect behavior on the exit and mid corner as you described above.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
malubawla (06-06-2017)
Old 11-12-2016, 10:03 PM   #4
wparsons
wparsons's Avatar
If it's just adjusting anti-squat (which looks correct), it shouldn't do much except when you're feeding in throttle.
The only side effect I would suspect is that since it'll squat more you'll have a potential for more lift over steer if you lift mid corner after getting on the gas. Not really how you want to be driving ideally, but still something to be aware of.
flickr
CSG Mike (11-13-2016)
Old 11-12-2016, 10:12 PM   #5
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Just curious, what's your ride height? Also, what offset are those RPF1's?
smg1138 is offline   Reply With Quote
Old 11-12-2016, 11:10 PM   #6
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
It's actually the exact opposite in practice.
The rear of the car is more planted at all points of the corner, but this balance is easily changed to suit what you want with any adjustments you make. I had my car set up the way I liked and with a few small tweaks the balance is where I want it but the car is more planted.
The Following 2 Users Say Thank You to 86•BRZ For This Useful Post:
Tokay444 (04-27-2017), whataboutbob (04-15-2017)
Old 11-12-2016, 11:14 PM   #7
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Guard to bottom lip of 17 inch +35 RPF1
Front 578mm
Rear 568mm
The Following User Says Thank You to 86•BRZ For This Useful Post:
Old 11-13-2016, 12:50 AM   #8
CSG Mike
CSG Mike's Avatar
So... it affects bumpsteer; zero bumpsteer can be useful for those that prefer it.
SPL also has made a part like this for years, for those that are stateside.
http://www.splparts.com/products/spl...-fr-s-brz.html
http://counterspacegarage.com/spl-pr...preza-wrx.html
Old 11-13-2016, 12:58 AM   #9
smg1138
smg1138's Avatar
Front 578mm
Rear 568mm
So, that's 10mm of reverse rake, correct?
Old 11-13-2016, 01:30 AM   #10
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
The MCA product relocates the pick up point.
The SPL product is an adjustable arm.
Two different things.
The Following 4 Users Say Thank You to 86•BRZ For This Useful Post:
DocWalt (03-25-2023), jeepmor (04-05-2022), justint5387 (08-25-2017), Racecomp Engineering (11-13-2016)
Old 11-13-2016, 02:16 AM   #11
Captain Snooze
Drives: Red Herring
Does one have to raise the rear spring perches to keep the same ride height?
Old 11-13-2016, 04:41 AM   #12
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
One does not
Ride hangs hangs off the lower control arm, literally.
Old 11-13-2016, 06:52 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, doesn't slight toe-in rear do almost same results wise as this mod? As in more self-stabilizing of rear, less oversteer-ish, less traction loss under throttle, one can sooner open throttle out of curve ..
Old 11-13-2016, 08:08 AM   #14
Northwest86
Drives: Velocity Orange 86 GT
They work well for me too. Definitely a positive part to add to the list of those you may want. Get a set of Reds while you are there too and you'll be very happy. As for allignment, everyone has their preference. I like 0 Toe everywhere. Some like it different. An additional Geometry aid can't hurt.
Northwest86 is offline   Reply With Quote
The Following User Says Thank You to Northwest86 For This Useful Post:
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) -- General Topics 48 08-09-2013 06:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 02:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 09:14 PM
