05-26-2016, 02:07 AM | #7225 |
Drives: 2013 Scion FRS
You using the 210? What pulley?
ScreamingElectron - SnakeShit |
05-26-2016, 06:44 AM | #7226 |
Y u do dis?
Sprintex 335 Supercharger upgrade kit
75mm drive pulley Sprintex Intercooler ID1000 Fuel Injectors DW 300c Fuel Pump ACT Heavy duty clutch ACT Streetlite flywheel Tomei Equal length header Perrin 2.5" Resonated catback exhaust Tanabe 60mm Overpipe Tanabe 60mm Catless Frontpipe Manley I beam rods Wiseco Forged Pistons 9:1 Compression with Armor Coating Custom Wrist Pins Race Engine Bearings (Mains and rods) Killer B oil pick up tube ARP FA20 Head studs In the future: 600 HP Axles Custom AZ6 Gear set FBM Stage 1 cams
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
The Following User Says Thank You to Dream20b For This Useful Post: | riboyster (05-26-2016) |
05-26-2016, 11:29 AM | #7227 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Check my build thread for what I've done to my exhaust if you'd like. I have JDL uncatted and went through a couple setups before settling on the resonated Q300 with resonated front pipe with hi flow cat.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
The Following User Says Thank You to stockysnail For This Useful Post: | CarzCarzCarz (05-26-2016) |
05-26-2016, 02:32 PM | #7228 | |
The Following User Says Thank You to riboyster For This Useful Post: | Dream20b (05-26-2016) |
05-26-2016, 03:06 PM | #7229 |
Drives: 2014 WRB BRZ
What front pipe are you running that has a resonator and hi-flow cat? I'm running the JDL UEL catless header, their Ultra-quiet front pipe with cat, and stock catback exhaust and I'm not digging the sound on start up, and low RPMs. Does the Q300 make it any quieter than stock exhaust, or give a different tone?
05-26-2016, 06:56 PM | #7230 |
Y u do dis?
dropped a bolt into the head.
Dat Hot Lava Doe
05-26-2016, 08:16 PM | #7231 | |
Just the tip
The Q300 won't make it quieter, but it will sound much nicer. To make it quieter than what you have, you'll need to get a catted header instead. Startups are a bit rough as far as loudness for the catless cars.
The Following User Says Thank You to stockysnail For This Useful Post: | CarzCarzCarz (05-27-2016) |
05-26-2016, 11:34 PM | #7232 | |
DrivinginDreams...Cloud86
Drives: Toyota GT86
overpipe frontpipe with cat and resonator catback with Magnaflow resonators
05-27-2016, 01:09 AM | #7233 |
Fuuuuck. If there's one thing everybody dreads doing....
On the bright side, you won't make that mistake twice! If it's any consolation, I once sucked a wad of electrical tape into my vacuum port.
The Following User Says Thank You to riboyster For This Useful Post: | Dream20b (05-27-2016) |
05-27-2016, 06:24 PM | #7234 |
Drives: pinto power
05-28-2016, 12:36 AM | #7235 |
Drives: 2017 Camaro 1SS
Dumb question: I installed a DW65 fuel pump. I was sitting at a red light just now with the ac on and my break pedal started sinking... Then a few moments later it raised back up.
I know this has nothing to do with a fuel pump but I mentioned it because that's all I changed. I've felt the break pedal sink before when stopped bit never raise back up like that. I'm assuming it's going up and down due to the change in vacuum pressure? Is it normal? Sent from my LG-D851 using Tapatalk |
05-28-2016, 04:46 PM | #7236 | |
The Following User Says Thank You to riboyster For This Useful Post: | brianhj (05-28-2016) |
05-28-2016, 04:48 PM | #7237 |
Also I think there's a thermostat that turns off the compressor once you reach a certain cool temp. That's probably more likely. I've heard it turning on and off multiple times in a minute while sitting at idle with the ac on
05-29-2016, 01:42 PM | #7238 |
Drives: 2014
I have. Squeaky alternator, it just started so I going to replace alternator to be safe
The Following User Says Thank You to walletsr For This Useful Post: | brianhj (05-29-2016) |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
