07-24-2012, 05:06 PM | #15 | |
Drives: Subaru BRZ WRB
07-24-2012, 05:17 PM | #16 | |
Drives: Scion fr-s
07-24-2012, 05:52 PM | #18 |
Drives: Black BRZ
I plan on winter driving here in Edmonton. Quick question for some of you though I plan on buying winter tires and throwing them on the stock rims as I will be purchasing new aftermarket rims come summer. Would it make more sense to buy smaller winter rims with larger tires? Thanks for any suggestions, was planning on buying some form of Nokian studded tires.
2000 Honda Civic Ek Hatch
1991 Skyline Gts-T Type M (RIP) 1991 Toyota MR2 USDM (RIP) 2001 Lexus is300 (RIP) 2013 Subaru BRZ |
07-24-2012, 06:36 PM | #19 |
Boostin'
Drives: FRS-T
100% sure its not touching the snow
07-24-2012, 07:16 PM | #20 |
Drives: 2013 Firestorm Scion FRS
Drive it all year that's what the rustproofing was for, unless the snow is like 2 feet high then I'll just stay home. haha
07-24-2012, 07:35 PM | #21 |
Drives: Whiteout FR-S MT
This car may look like a $100,000 car but in reality its only $30,000. Drive it people!! quit being those anal garage queen guys
Anyway gonna drive it with proper winter tires in the winter and ONR the car every week or so, to keep salt build up minimum and coin op the underside frequently. |
07-24-2012, 09:43 PM | #22 |
Boostin'
Drives: FRS-T
The frs is a fourth car so i wont bother
07-24-2012, 09:46 PM | #23 | |
Drives: '13 Ultramarine
I'm going to use a 205/55/16 on mine. If a 15" wheel will clear the brakes, I might even try a 195/65/15. A smaller wheel with more tire sidewall for the same overall diameter will give better grip in the snow. There is a tradeoff on dry roads, though. The steering and handling will be off somewhat. Are studs legal where you are? |
07-24-2012, 10:08 PM | #24 |
Going to storebit. Still have my 97 cl as a beater.
Sent from my iPad using Tapatalk HD |
07-24-2012, 10:13 PM | #25 | |
Just before storing the car, I'd fill the fuel tank (be sure to add some fuel stabilizer), and do an oil/filter change. If you don't need to start the engine over the winter, don't. You'll just pollute that nice fresh oil. If you're in a heated garage, don't worry about disconnecting or removing the battery. Get a cheap "trickle" charger (1-2 amp) at Crappy Tire, and hook it up to the battery for a day or so every couple of weeks. Park the car in gear and don't use the parking brake unless you need to start the car. I've seen them stick on after a few months of sitting still. Airing up the tires a few lbs isn't a bad idea, either. Just remember to check them in the spring. rolling the car ahead or back once in a while will be good for the tires too. |
The Following User Says Thank You to roddy For This Useful Post: | Jlturner (07-24-2012) |
07-24-2012, 11:04 PM | #26 | |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
I don't think 15s will clear brakes. 16s are standard on the base model in Japan. Narrower is better for winter, studs are ok but we have a lot of chinooks so lots of cold pavement driving. I had blizzaks on the Jetta and it was insanely good. I have cheap korean snows on the SUV and it works fine too (but awd). I'd have studs out east where the snow/ice is on the ground for months at a time. |
07-24-2012, 11:11 PM | #27 |
Drives: Audi A3 2012
Store!
07-25-2012, 02:44 AM | #28 | ||
Drives: Black BRZ
http://www.nokiantires.com/tyre?id=1...akkapeliitta+7 From what I understand they are a little pricey, but the studs wear at the same pace as the tread and I have heard nothing but rave reviews.
Similar Threads | ||||
MR2 winter progress | NESW20 | Other Vehicles & General Automotive Discussions | 35 | 04-01-2013 10:43 PM |
After this last winter is RWD such a bad idea | Nate219BRZ | Great Lakes | 3 | 03-14-2012 05:03 PM |
Winter drivers... How moron it can get? | ichitaka05 | Off-Topic Lounge [WARNING: NO POLITICS] | 54 | 01-28-2012 04:34 PM |
Winter Sucks | OldSkoolToys | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-19-2010 12:02 PM |
Whats your favorite parts provider Store??? | Vonmadthane | Other Vehicles & General Automotive Discussions | 6 | 02-10-2010 07:20 PM |
