06-13-2014, 12:11 AM | #631 |
Drives: '13 GBS Subaru BRZ
So doing some more testing tonight I encountered a problem I was worried about. As the compressor nears top speed there is a slight imbalance in the impeller wheel. It's a balanced wheel but it's almost impossible to make it perfectly balanced.
This shouldn't be that big of an issue, but the 6mm shaft on the KDE outrunner motor just isn't enough to fight the oscillation at that speed and it's flexing slightly allowing the wheel to come into contact with the compressor housing. Sadly I just don't thing that motor is going to work which really sucks because otherwise it has performed amazingly well. I'm hoping he 8mm shaft on my AquaStar T20 will do the job. I've already mounted it to the compressor, and I just need to wire it up and see how it works.
06-13-2014, 12:14 AM | #632 |
Drives: 2010 MX-5
Bummer ... It did cross my mind at one time ... thats a pretty heavy wheel ...
I hope the 8mm shaft is more stable. |
The Following User Says Thank You to AN For This Useful Post: | neutron256 (06-13-2014) |
06-13-2014, 07:40 AM | #633 |
Drives: 2013 FR-S whiteout
Hope it works out. I really want to see this thing make boost.
The Following User Says Thank You to SloS14 For This Useful Post: | neutron256 (06-13-2014) |
06-13-2014, 07:59 PM | #634 |
Village Idiot
Drives: '13 FR-S Ultramarine Manual
Just came to say, coolest thread on here. I have been reading like 2 days straight. Are you guys going to put together a kit and market it or just for your own cars? If you plan on selling... Sign me up. Ha
The Following User Says Thank You to jebuwh For This Useful Post: | neutron256 (06-13-2014) |
06-13-2014, 08:06 PM | #635 |
Drives: 2010 MX-5
well .. vision is to have a diy pdf or something so that people can put it together themselves.
The Following 2 Users Say Thank You to AN For This Useful Post: | jebuwh (06-13-2014), neutron256 (06-13-2014) |
06-13-2014, 09:05 PM | #636 | |
I appreciate the interest, and stay tuned I'm making some great progress.
The Following User Says Thank You to neutron256 For This Useful Post: | jebuwh (06-13-2014) |
06-13-2014, 09:10 PM | #637 |
I've swapped out the KDE out runner motor with the AquaStar T20 in the Delta 1280kv configuration. It's working great! The 8mm shaft is stiff enough to resist the imbalance in the impeller wheel and it's running fast and smooth.
I'm really impressed with this setup. I can't wait to actually try it on the car.
06-13-2014, 09:10 PM | #638 | |
Village Idiot
Super cool stuff guys! |
06-14-2014, 01:33 AM | #639 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
I love how the controller even says electric supercharger on it (okay... it just says esc but still).
The Following User Says Thank You to Luckrider For This Useful Post: | neutron256 (06-14-2014) |
06-16-2014, 11:55 AM | #640 |
Drives: 2010 MX-5
Great progress Neutron ... How much did you push the T20 ? full 30k rpm ? Would love to see a view of t20 revving while off the car for a comparison with the KDE ...
06-16-2014, 12:13 PM | #641 | |
I'm working on getting the controller mounted today. I think I've found a great spot on the side of the fuse box. Then I need to get serious about building my controller. The first version will be very simple, if it all works well I might build a more advanced controller with a display.
06-16-2014, 12:45 PM | #642 |
Drives: 2010 MX-5
You can look in getting a motor fan ... they are fairly inexpensive and come for motors of all diameters ... I have seen some at castle creations for a motors that size.
06-16-2014, 02:54 PM | #643 | |
On the plus side my butt dyno indicates that the compressor isn't causing too bad a restriction when not running. Maybe drag reduction isn't needed which would simplify the system.
06-16-2014, 04:15 PM | #644 | |
Drives: 2010 MX-5
Also, how does the water cycles through ... does the the motor spinning action push the water along ? Will you have to install a heat exchanger of some sort ? Do the Hobby ESCs have some kind of motor temp. monitor ? Basically, can the motor temp. be monitored to avoid over heating ? |
Tags |
hairdyerperformance, only pulls hard one gear |
Similar Threads | ||||
Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11295 | 02-19-2024 03:42 PM |
DUP THREAD MODZ PLZ DELETE KTHX | SloS14 | Forced Induction | 0 | 07-09-2013 05:41 PM |
Electric Turbocharger | Shankenstein | Forced Induction | 91 | 06-24-2013 02:47 PM |
Electric 86 | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-10-2012 02:16 PM |
WRX Electric turbo | Neilus | Engine, Exhaust, Transmission | 42 | 05-03-2012 09:20 PM |
