11-13-2015, 07:50 PM | #183 | |
Engineering Student
Drives: Scion FR-S 2015
There’s no time to stop for gas, we’re already late
12-06-2015, 11:56 PM | #184 |
Drives: '13 FR-S Raven Black
Just did this today and wanted to say a quick thanks for the write-up. Went smoothly, only hiccup was getting the oil through those Motul nozzles. Not exactly a lot of room to get the container higher than the fill holes (mainly on the diff), unless I'm missing something.
46k miles and this is the first time it's been changed I'm assuming (bought used @ 30k), shifts are much smoother now. |
12-14-2015, 08:24 PM | #185 | |
Drives: '13 Hot-Lava FR-S
12-24-2015, 05:00 PM | #186 |
Drives: frs
Drained my tranny and diff today and noticed that the longer, magnetic bolt was on my tranny's fill hole instead of drain. Did I install it wrong last time? It still had gunk on it so doing its job, but I want to install it correctly this time. Longer magnetic bolt goes on the drain (bottom) hole of the tranny, right? Similar to the diff.
The Following User Says Thank You to gonzo For This Useful Post: | Astroboy (12-31-2015) |
12-31-2015, 06:46 PM | #187 |
Drives: None
I started my car today. Is anybody having a rattling noise with the exedy stg 1? My car's making a grinding noise when decelerating
Sent from my LG-D850 using Tapatalk Last edited by Astroboy; 01-01-2016 at 08:15 PM. |
12-31-2015, 07:10 PM | #189 | |
Drives: None
Sent from my LG-D850 using Tapatalk |
04-12-2016, 03:35 PM | #191 | |
Drives: 2015 ISM BRZ Premium
You're going to want to use auto transmission fluid as well, not gear oil. |
04-13-2016, 01:49 AM | #192 |
Drives: Subaru BRZ
04-13-2016, 10:08 AM | #193 |
Drives: Scion FR-S
I just changed my tranny fluid this past weekend, and I only put exactly 2 liters of Motul 300. Some oil oozed out and felt it right away when I put my pinky finger in the fill hole. The car was on a level ground, and sitting on four levelled jack stands (with hockey pucks).
Would that be an issue if it's less than 2.2 liters? Also, any suggestions what else I could visually inspect while I'm under the car? Thanks, fellas. Lupayn3 |
04-21-2016, 05:51 PM | #194 |
Drives: FRS
@Lupayn3 I just did mine too today, I used motul 300 so the bottle indicated how much fluid was left. After I did the transmission, I ended up "using" and "about" 2.2 litres and that is with some dripping here and there.. I just eyeballed it.. lol
Not saying it's okay but just saying I wouldn't lose sleep over it
'14 Scion FRS
Tein Flex TE37 |
05-11-2016, 12:23 AM | #195 |
Drives: GT86 GTS
I picked up some Motul Gear 300 for mine, hope it smooths out the gearbox
06-16-2016, 11:33 PM | #196 |
Drives: 2014 BRZ Limited 6MT
The diagram for this dif is cut short. Can someone please give me the torque specs for the Dif fill plug?
Tags |
differential, diy, fluid, transmission |
Similar Threads | ||||
Transmission fluid swap? | flawedchemical | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 48 | 09-12-2014 02:23 PM |
What Differential fluid is in your BRZ/FRS? | ft86Fan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 11-12-2012 08:57 PM |
Anyone change transmission lube yet? | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 08-21-2012 05:47 AM |
FR-S quick reference and warranty / maintenance guide is up | pkny | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 06-20-2012 11:33 PM |
topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) -- General Topics | 51 | 05-04-2012 07:54 PM |
