Old 11-25-2013, 09:02 PM   #6343
djliquidsteele
Drives: Scion FR-S
I do have a couple questions though. On your tunes, where does the majority of the power lie? Do you tend to go low end grunt or top end speed. I have no other reference so I don't know how yours is different. My thought is, at least for my driving, is it possible to have second gear with a ton of low end grunt, 3/4/5 all high end (Like where the RPM would fall on each successive gear change to redline) and then 6th all mid range grunt for highway driving?
djliquidsteele is offline
Old 11-25-2013, 09:02 PM   #6344
mikalem
mikalem's Avatar
Drives: 2013 WRB BRZ Limited
Sent.
Gave it a shot, the older map suits me better - the car seems to want to move starting about half throttle, the newer throttle map made me feel like I had to stand on it to get the same feeling - guess I can kinda explain it in that the two maps to me feel like the difference between a new and worn rubber band - very snappy on the older throttle map, the new seems a little looser in normal daily driving. My .02.
Sent from my SGH-M919 using Tapatalk
mikalem is offline
Old 11-25-2013, 09:06 PM   #6345
JiB
JiB's Avatar
Drives: GT86
Ive been really happy with my tune and maps, dont think i will bother updating. Auto blip is so good
JiB is offline
Old 11-25-2013, 09:19 PM   #6346
Visconti
Drives: 05 STi
If this was a turbo car we would adjust the boost ramp in etc since this isn't all you really can do is play with the throttle table, some tuners make it so when you barley touching the gas pedal the car actually has the throttle opened up all the way.
So I dont limit the power in any way or have a way to deliver the power in a different more effective way
I've made some changes to the throttle mapping mostly because of comments from some people, my original throttle mapping is very similar to stock. The newer mapping seemed very nice on a turbo car I did in-house a few weeks ago.
John
Visconti is offline
Old 11-26-2013, 02:59 AM   #6347
Fast_Freddy
Drives: Passat
Hey John, I have your stage 2 tune and keep getting a P2096. I suspect that's because of the mini-cat I installed before getting the tune but was wondering how you correct for the primary cat deletion. Do you raise the rich threshold for the secondary O2 sensor or do you skew it's results to mimic the presence of a primary cat?
Great tune and thanks also to Pure Automotive for making it so easy.
Fast_Freddy is offline
Old 11-26-2013, 07:50 AM   #6348
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
I love the new throttle mapping. Power is everywhere now with the new tune. She screams louder up top and rev-match is quicker now for some reason
Sent you a log, hope it helps, coz I never tried logging before
Loay
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline
Old 11-26-2013, 08:20 AM   #6349
Visconti
Drives: 05 STi
Loay
Thanks for the feedback
Let me know how it is as the throttle body performs it's learn
Thanks
Do you have your own flash cable ?
John
Visconti is offline
Old 11-26-2013, 08:49 AM   #6350
mikalem
mikalem's Avatar
John is it normal to see the advance multiplier fall during learning? Car sat overnight after the logging where that looked okay, logs this morning on the drive in and during freeway cruise I watched it drop from 1 to .54, then slowly start to climb up. Its currently sitting at .67, and sticking on shut down/restart. Plan on keeping an eye on it, I'll submit the logs tonight for you to look at. Logs showed 4 instances of -1 correction, at different points.
mikalem is offline
Old 11-26-2013, 08:56 AM   #6351
Visconti
Drives: 05 STi
With less than good gas, yes.
If the advance multiplier settings are setup correctly in the rom the multiplier should jump down if the car can't consistently run full ignition advance.
FYI- the advance multiplier has a few strange settings that basically make t disabled on the stock tune. I've changed that.
Send a log in
John
Visconti is offline
Old 11-26-2013, 09:08 AM   #6352
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
What's up with the startup on flex fuel running around E30? It fires up and idles at a crazy high 2,000 rpm for a bit then seems to get louder at 1,500 rpm. It doesn't seem to do this on a higher ethanol level. Is that something you fixed with the 2.0 update?
post_break is offline
Old 11-26-2013, 09:10 AM   #6353
Visconti
Drives: 05 STi
No change..
The loud noise is the OEM emission maps kicking in, retards the ignition timing to warm up the cats. It's a bunch of messy maps, trying to disable it causes more problems than it's worth
John
Visconti is offline
Old 11-26-2013, 09:14 AM   #6354
Yruyur
Yruyur's Avatar
@Visconti is map switching available on flex fuel yet? Still running the dyno tune we did and loving it but miss the launch control.
E73 starts are getting harder now that it's getting to be winter.
Also noticed what seems to be a fuel cut once in a while wot in first gear around 6k. Was fearing it was ethanol doing bad things to the system. I'll try and log an event.
Sent from my SCH-I545 using Tapatalk 2
Yruyur is offline
Old 11-26-2013, 09:18 AM   #6355
post_break
post_break's Avatar
I have launch control in flex fuel. It appears I don't have flat foot shifting though. Found out the hard way.
Old 11-26-2013, 09:18 AM   #6356
Visconti
Drives: 05 STi
What's your dongle ID?
I'll have a look at what's enabled / disabled.
Yeah get me that log and I'll see what's going on
Hard starts ? These cars are such a pain! If you only knew the things I have to do to make this car start with ethanol..
I have a few local flex fuel cars I'll have to ask them how it's starting and see if I can grab the car for the day or something
John
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
Yruyur (11-26-2013)
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 10:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) -- General Topics 130 09-01-2011 01:42 PM
