05-17-2018, 11:43 PM | #267 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Looking to confirm ECU part number on a q3 BRZ limited 6 speed?
05-18-2018, 12:00 AM | #268 |
So I got my car back today. I filed a formal complaint to Toyota Corporate three weeks ago when this issue occured & they help tremendously with lowering the price of the repair. I greatly appreciate their customer service.
Overall, the dealership only replaced ONE cam sprocket, and they did a bad job of re-sealing the front end of the engine. I was able to drive no more than 5 miles away when my TCS, CEL & battery lights came on. I then noticed a considerable amount of smoke from behind the car & flowing up under the hood. I immediately pulled over & shut the car off. I got on the ground & it was pouring oil. After some phone calls, I had it towed back to the dealership & they gave me another rental. At this point, I can't trust these mechanics at this dealership anymore. I'll be making calls to the service manager & Toyota Corporate. I believe I need a new engine, or a new car, or some sort of money to cover the value of my FRS.
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
05-20-2018, 11:45 AM | #269 |
I purchased two of 22765AG511 from ebay to use in my 2013 MT BRZ. Both came out of wrecked cars with about 30k miles. I used Techstream to change the VIN numbers. Theres a good write up on the swap on here.
05-23-2018, 01:40 PM | #270 |
Drives: 2013 Subaru BRZ
Any reason I'd still get the P0016 code even after replacing the cam gear sprockets? I've swapped OCVs and Sensors around in the past. Or does it take some mileage for the ECU to remove this code permanently?
Sent from my Pixel 2 XL using Tapatalk |
05-23-2018, 01:43 PM | #271 |
From what I've read & experienced, you'll need to replace the ECU.
05-23-2018, 01:43 PM | #272 |
05-23-2018, 01:56 PM | #273 |
義理チョコ
Hmmm... This is where techstream and the manual slew function would come in handy. The servos can individually be toggled to check them. It's really handy.
BTW, I heard from my friend that moved. He went back to driving it and hasn't had any issues since we last exercised the spool valve.
05-23-2018, 07:22 PM | #274 | |
05-23-2018, 08:53 PM | #275 | |
P0016 on a 60k mile car
Techstream can’t fix your problem, it’s simply for diagnostics. What Techstream allows you to do is manually advance or retard the timing for testing purposes. There is a TSB around here somehwhere that basically tells you to advance the cams until the car stalls which proves that they are at least working. You can get an OBD2 adapter that is compatible with Techstream on amazon for $18. Some of these cables come with Techstream but normally older releases. It’s not had at all to locate the latest release with google. The software is easy to use and is a great tool to have. The Tactrix cable works with Techstream if you happen to have their cable. Last edited by ermax; 05-23-2018 at 10:40 PM. |
The Following User Says Thank You to ermax For This Useful Post: | Ultramaroon (05-23-2018) |
05-23-2018, 10:29 PM | #276 |
義理チョコ
^^^ Exactly. It has become an essential diagnostic tool. I was stupid. I already had the Tactrix and bought another j2534 device before I learned any better.
05-23-2018, 11:10 PM | #277 |
Techstream work with a BRZ? I was hearing otherwise from local guys.
05-24-2018, 12:19 AM | #278 |
義理チョコ
Yes, it does. My friend's is a 2013 BRZ with EcuTek.
05-27-2018, 01:38 AM | #279 |
Drives: BlueBurz
It will take many(as many as 5K per Subaru Tech line) for the ECU to relearn. You'll continue to throw the code and the ECU will use a fixed value for the cam gears(loss of power). This happens even before the code is thrown(CEL), as long as it's a pending code. Experienced this first hand and finally changed the ECU. No issues since.
05-29-2018, 03:39 PM | #280 | |
At this point, I don't want to buy ANOTHER ECU. Should I just buy new Sensor(s)? OCV(s)? Or rub my magic Genie bottle for a few more wishes? |
Similar Threads | ||||
P0016 fixable without new ECU? | Mr.Jay | Issues | Warranty | Recalls / TSB | 8 | 02-06-2022 05:15 AM |
P0016/P0017 cause | AVOturboworld | Issues | Warranty | Recalls / TSB | 18 | 04-16-2021 11:09 PM |
P0016 Code | Shady195 | Engine, Exhaust, Transmission | 30 | 02-21-2019 02:31 PM |
p0016 need help asap | lol | Issues | Warranty | Recalls / TSB | 25 | 10-30-2018 03:49 PM |
OFT P0016 and TSB question | mmmcambelsoup | Software Tuning | 10 | 05-24-2017 09:24 AM |
