Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
12-31-2019, 04:33 PM | #29 |
Drives: '13 Whiteout
The Following User Says Thank You to TommyW For This Useful Post: | Ultramaroon (01-02-2020) |
12-31-2019, 05:16 PM | #30 |
Drives: 2013 Scion FRS white
Sure you can get the back out with almost any tire on this car but you have to be either pushing a corner really hard or purposely trying to get it sideways by exaggerating steering input. Point is, when you ditch the primacy's and go with most HP tires, the car doesn't have enough power for that "rear end twitch" as you're coming out of a corner and that is something that is really missed. Sad to say, but I think its a choice: do you want good corner grip or do you want playfulness out of the rear end? Its hard to get both on a 200 hp car. I'm kinda dealing with the same thing as you but don't want to give up the grip that comes with HP tires. Oh and I would never buy shit Chinese tires. They will be good from the start and after 10k miles it will sound like you are riding on cinder blocks and you will have less grip then a MPSS in the wet.
Or you could just do as others on here imply and put on super sports and drive as fast as you can around a corner to obtain the playfulness; you'll lose the rear eventually.... Last edited by mrhayes1; 12-31-2019 at 05:51 PM. |
The Following User Says Thank You to mrhayes1 For This Useful Post: | why? (01-11-2020) |
01-02-2020, 10:06 AM | #31 |
Drives: Scion 86 tS
When I had some Walmart branded tire on the car (bought it like that), the tail would slide under any fast cornering. But the sketchiest thing was rain puddles. It was impossible to drive straight.
The Michelin pilot sport as 3+ are overkill in grip. That's what I have and I cannot get the tail to slip with nannies on. |
01-02-2020, 11:18 AM | #32 |
Drives: 2014 GT86
"impossible to drive straight" - i'd also check alignment. Having it well evened out side to side with slight toe-in should ease a lot tracking straight even in low grip/with overcame traction. If it worked for me easing handling on ice/snow in winter, should work for wet/rain.
01-07-2020, 07:02 PM | #33 | |
Drives: Blue 2014 FRS Limited
If I must, then I choose grip because it makes driving hard in sketchy canyons less scary. Thanks for all the suggestions as well. |
01-07-2020, 07:53 PM | #34 |
義理チョコ
Or just drive appropriately for the conditions.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
01-07-2020, 09:58 PM | #35 |
Drives: jrsc_brz
^^^this is bob^^^
bob didnt moan and groan about salt and grime on his sports car in the winter. be like bob #fullscrotum |
The Following 3 Users Say Thank You to HaXx For This Useful Post: |
01-07-2020, 10:24 PM | #36 |
Weight Weenie
Drives: 15 FR-S
The Following 2 Users Say Thank You to new2subaru For This Useful Post: | bradyhuutch (02-05-2020), soundman98 (01-07-2020) |
01-10-2020, 11:12 PM | #37 | |
Drives: 2019 BMW ///M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
01-11-2020, 01:37 AM | #38 |
Drives: 2013 FRS
Lol
This thread has been pretty funny so far Got my car stock with indy 500s. Left all aids on. Car would slide out under a moderately hard turn, or quick shifting into 2nd around a bend. UEL header, stage2 OFT, and Eibach rear sway bar and the back end is "on ice skates" as someone else said. Definitely wasn't expecting it to break loose so easily first time I drove it after the sway bar |
01-11-2020, 08:57 AM | #39 | |
Drives: Scion 86 tS
I run 35-40 psi now and there's 1 or 2 freeway change ramps that will make my light turn on if I take the wrong line at like 70+. The wheel wobbles a little but it's not gonna slip if I'm not being stupid bout it lol. I miss my Walmart tires when I first bought the car. Accidentally lost the rear quite a few times |
01-11-2020, 11:35 AM | #40 |
Only happy when it rains.
Drives: series.blue
if the stock tires scare you learn their limits and learn how to go past them. They are awesomely predictable and you can overdrive them without worrying about spinning or crashing.
Being able to know exactly what the stock tires will give you and what their limits are will make you a better driver. |
The Following 3 Users Say Thank You to why? For This Useful Post: |
01-11-2020, 02:01 PM | #41 | |
Drives: 2017 BRZ w/PP
i dont know what tires you have but that seems way too high. the chart starts on page 13 of this link https://www.toyotires.com/media/2125...s_20170203.pdf for example i have 255/40/17 and to get aproximately the same load rating as a stock setup i need to have about 25psi in my indys cold. if you are putting 40lbs cold into a stock size or a larger size your contact patch is going to be all jacked up |
The Following 2 Users Say Thank You to Breadman For This Useful Post: | PulsarBeeerz (01-11-2020), Ultramaroon (01-11-2020) |
01-14-2020, 07:08 AM | #42 | |
Drives: series.blue
I bet this is the same in many tires that have weaker sidewalls. |
The Following User Says Thank You to why? For This Useful Post: | soundman98 (01-14-2020) |
Similar Threads | ||||
OFT Keep plugged in without killing battery? | Axion | Software Tuning | 19 | 06-06-2020 10:30 AM |
Supra...killing the 86/BRZ? | jrb363 | Scion FR-S / Toyota 86 GT86 General Forum | 238 | 02-08-2019 11:44 PM |
FS (GA) 15 BRZ Stock Wheels + Tires + TPMS + stock lugs & locks (tires 10k miles) | GTHachiRoku | Wheels and Tires | 15 | 07-30-2016 11:51 AM |
Would 23 lb wheels (Miro) offset the advantages of upgrading to grippier tires? | Meanderchap | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 01-07-2016 08:28 PM |
I guess i'm killing people... | Darryljr11 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 09-06-2013 12:54 PM |
