Old 02-16-2019, 03:33 AM   #85
Zer0
Drives: 2015 frs
Originally Posted by Colin86 View Post
Great work, and incredible project. Thanks so much for sharing with the forum!
Thanks for the kind words. I'm glad people are checking it out and showing interest. Hopefully it's a little insight for people who need a smog legal swap.
Zer0 is offline   Reply With Quote
Old 02-27-2019, 05:42 AM   #86
Zer0
Drives: 2015 frs
My ECU came in, and I started building the jig for the front crossmember.
Old 02-27-2019, 11:21 AM   #87
JCW 86
JCW 86's Avatar
Drives: 2013 Raven FR-S
I don't know what it is, but that ECU and those cooling fins are so sick to me. Such an awesome build, I could only wish I had this type of know how and abilities
JCW 86 is offline   Reply With Quote
The Following User Says Thank You to JCW 86 For This Useful Post:
Zer0 (02-27-2019)
Old 02-27-2019, 04:40 PM   #88
DIY
DIY's Avatar
Drives: BRZ, WRX
Nice work with the jig, that will make things easier for you.
Follow me on Instagram: @brzdiy
My Build Thread
DIY is offline   Reply With Quote
Old 02-27-2019, 07:25 PM   #89
Zer0
Drives: 2015 frs
The ECU is a OEM GM E92 ECU. I love the way it looks too. Just get a project and lern as you go, or take some classes that challenge you and pushes you to develop new skills, and you will be right up there with the best of them over time.
Old 02-27-2019, 07:31 PM   #90
Zer0
Drives: 2015 frs
Thanks. Now I'm deciding between 1.75" Dom round or 2.5 square tubing. I like the look of the round, but either one would work.
Old 02-27-2019, 09:50 PM   #91
DIY
DIY's Avatar
Drives: BRZ, WRX
Round tubing would be better if you have the tools to work with it. I'll be using 1.75" for most of my front crossmember.
My Build Thread
Old 02-28-2019, 12:21 AM   #92
Zer0
Drives: 2015 frs
What wall thickness are you using? I have .095 available I was thinking to use that. I have the tools. Watching your build. I like it a lot. I want to do a similar rear subframe to the one you did, but for a Winter's quick change diff. Mine would be a bolt in unit.
Old 02-28-2019, 03:16 AM   #93
DIY
DIY's Avatar
Drives: BRZ, WRX
All my tube is 0.102 wall, I mostly use 1.5" but the main hoop and part of the front crossmember is 1.75"
My Build Thread
Old 02-28-2019, 06:56 AM   #94
Zer0
Drives: 2015 frs
The jig is completed. I made it two pieces that bolt together.
The Following User Says Thank You to Zer0 For This Useful Post:
DustinS (02-28-2019)
Old 03-08-2019, 06:32 AM   #95
Zer0
Drives: 2015 frs
I have begun working on the crossmember. What work has been done is mostly tacked up my welding machine is acting up. Hopefully I get it completed next week.
Old 03-08-2019, 10:14 AM   #96
Thedishdoc
Drives: 2015 Scion FRS
Very nice sir!
2015 Red FRS
Enkie LC5 18" Rims/Michelin 225-45 18 Super Sports
Perrin resonated catback exhaust
FT86 UEL catted header
Stage 2 OFT tune
Thedishdoc is offline   Reply With Quote
The Following User Says Thank You to Thedishdoc For This Useful Post:
Zer0 (03-08-2019)
Old 03-17-2019, 06:30 AM   #97
Zer0
Drives: 2015 frs
Out of the jig, but not finished yet. Needed to weld it in it's current state of build, then back to the jig to add the final parts
Old 03-22-2019, 03:42 AM   #98
Zer0
Drives: 2015 frs
I have gotten further along with the crossmember. It weighs 30 lb. My stock one weighs 26lb with the two connectors that bolt below / behind the firewall and to the crossmember. This weight is also without motor mounts and the mount tabs cut off. I still need to add the two connectors that are on my stock crossmember but not on the one I made yet. I'm thinking 36lb when it's complete with motor mounts. It's a little heavier, but I think it will be stronger, and most important I will have more clearance.
Andy0323's Back To Basics Build Thread <Long Term Project> andy0323 Member's Car Journals 15 02-02-2018 12:16 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Long term Bt216 Scion FR-S / Toyota 86 GT86 General Forum 3 06-06-2013 11:58 PM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
