06-12-2019, 02:59 PM | #295 | |
1st86 Driver!
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
06-12-2019, 03:22 PM | #296 | |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | OwlDance (06-12-2019) |
06-12-2019, 04:13 PM | #297 | |
Pavement Grey
Drives: 2020 Toyota 86 GT, 2017 BMW X1
-Getting in and out is a chore for even a short person (the car is tiny). Its like getting and sitting inside a bathtub through a window opening that is as high as your waist. -Once inside its got pretty comfortable but thin seats, and hardly any if at all amenities, so everything's exposed. -Its probably loud as hell inside...but I think the 2ZZ motor makes up for it. -It has a trunk...that fits stuff....but its not very big. -depending on how wide you are you are most likely going to be intruding into the passenger shoulder space. You'd have to compromise a lot to make it work as a daily driver. Occasional fun car? hell yeah. Trying to daily it? hell naw. Or you could get a BRZ or the like and half nearly the same experience with vastly more comfort, and quite frankly much less money. With that said i'd love an Exige/Elise with the 2ZZ, not the later ones with the supercharged 1ZZ Hell i'd even look at an Evora if I want something a bit more "exotic'y" |
The Following User Says Thank You to Sasquachulator For This Useful Post: | Rampage (06-12-2019) |
06-12-2019, 04:17 PM | #298 | |
TRACKBREAD
This is why an NA FA24 would make a lot of sense. You can make it a bit less high strung while still getting 230hp (95.8hp/l vs 102.5hp/l). This will help with efficiency a bit. Combine that with increased highway mpg by making top gear a bit longer, and we might see very similar fuel economy out of a bored or motor. |
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post: |
06-12-2019, 04:19 PM | #299 | |
Drives: 2017 Toyota 86
Subaru Toyota Collab on Next Gen 86 Stopped
Less high strung = lower redline, right? Kinda like how the AP2 S2K’s 2.2l engine’s redline was 700ish rpm lower than the original car while delivering more HP/torque at a lower rpm? Sent from my iPhone using Tapatalk |
06-12-2019, 05:12 PM | #300 | |
TRACKBREAD
It doesn’t HAVE to have a lower redline, it can have lower compression, different valve timing, etc. |
06-12-2019, 09:20 PM | #301 | |
義理チョコ
...I think... I'm going one what I've read here in the past. I pretty much lurk/skim these more speculative threads.
The Following User Says Thank You to Ultramaroon For This Useful Post: | JohnJuan (06-13-2019) |
06-12-2019, 09:29 PM | #302 |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Does the UK , certain European countries impose extra taxes on engines that are over 2L ? Sorry, I should google that one
Math is like Love, simple idea at first that quickly gets complicated
06-13-2019, 12:47 AM | #303 |
Drives: 2014 BRZ Limited
06-13-2019, 01:51 AM | #304 | |
The Dictater
Drives: '13 Red Scion FRS
There's no such thing as a one-off design any more. Yes, it looks different to us than every other Subaru out there, but to a computer it's quite similar to Subaru's other cars. Im convinced that the design of this car was really a low-risk experiment prepping for the recent Subaru updates. I'm sure Toyota got something out of the exchange on the back end too. Now what would that mean for a future generation? Well, it means that the model has already been developed and then improved further, so Subaru should be able to crank out a new "design" fairly quickly and inexpensively. Yes, yes, certification is always expensive, but having a model you know works significantly reduces risk on that which results in needing less integration and test time beforehand. And I am an engineer, but also throwing my speculations into the wind. |
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
06-13-2019, 02:17 PM | #305 | |
TRACKBREAD
Exactly. Similarly it should be fairly low risk to take the FA24 and design a new header, an intake manifold with port injectors for it, and spec some hotter cams and positions for it. A good point was raised about European taxes over 2 liters. Maybe we’ll get 2 engines like the Miata? Maybe they’ll say that’s tough Europe? Maybe they’ll squeeze the 2.0L for even more than 102.5hp/l? Maybe a mild hybrid setup for torque? |
06-13-2019, 02:51 PM | #306 | |
Drives: '15 BRZ RA
I wouldn't expect much more power in a 2.4L either. Probably 220-225bhp and a much better torque in mid rev range which is what most people love ... |
06-13-2019, 04:49 PM | #307 |
Drives: Scion Frs
06-13-2019, 05:11 PM | #308 | |
The Following User Says Thank You to funwheeldrive For This Useful Post: | Tokay444 (06-14-2019) |
Similar Threads | ||||
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling | Hachiroku | BRZ Photos, Videos, Wallpapers, Gallery Forum | 113 | 11-21-2020 01:02 PM |
Supra (Toyota/BMW) vs. FT86 (Toyota/Subaru) | GrantedTaken | BRZ First-Gen (2012+) -- General Topics | 150 | 01-29-2019 02:19 PM |
STI ~ Subaru | TRD ~ Toyota | JDM Lanyards & Toyota Emblem Overlay for Scion FR-S! | KI_ZN6 | Groupbuys | 173 | 01-15-2016 01:56 PM |
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 94 | 09-15-2013 08:55 PM |
Subaru/Toyota Coupe spotted in Socal with Subaru Plates | owsiu | Scion FR-S / Toyota 86 GT86 General Forum | 150 | 05-25-2011 10:27 PM |
