05-07-2019, 07:28 PM | #20777 |
Weight Weenie
Drives: 15 FR-S
Went on a drive with the Ohlins set at 12F&R. Interesting experience. Cushy but not "sporty"
05-07-2019, 07:35 PM | #20778 |
Drives: 2017 BRZ PP , 2005 Saab 97X
05-07-2019, 07:38 PM | #20779 |
Weight Weenie
Drives: 15 FR-S
The Following User Says Thank You to new2subaru For This Useful Post: | Clutch Dog (05-10-2019) |
05-07-2019, 07:40 PM | #20780 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | qcbaker (05-08-2019) |
05-07-2019, 07:41 PM | #20781 |
05-08-2019, 04:14 PM | #20782 |
Drives: Asphalt FR-S
Had mobile installer throw on my new enkei ts9's
Sent from my Pixel 2 XL using Tapatalk |
05-08-2019, 10:45 PM | #20783 |
05-08-2019, 11:05 PM | #20784 |
The one that I dealt with was hands down amazing. I bought new wheels because the TSP6 wheels I have were scratched up by last tire shop. These guys were top notch. Came in a box truck, they have a generator too. Swapped the tires to new wheels, road force balanced, and nitrogen filled. All done where I live.
05-10-2019, 07:37 PM | #20786 |
Drives: RS
Installed my Titan 7 Wheels 18X9.5 +40 today finally. BFG Comp 2 A/S tires. 235/40/18 front with a 3MM Spacer. 255/35/18 Back. So close on that stock perch. |
The Following 3 Users Say Thank You to Karfield For This Useful Post: |
05-10-2019, 10:58 PM | #20787 |
Drives: Halo
Installed the Nameless 5" Muffled Track Pipe and Perrin Crank Pulley
--------------------------------------------------------------------------------- Notes: 95 dbA is the legal limit for vehicle exhaust noise in California. Standard Sound Test Procedures: 45Degrees 17.5-20 inches away from exhaust tip. 50% or 75% RPM Band. --------------------------------------------------------------------------------- OEM Crank Pulley: 5lbs OEM Bolts: 70.3g OEM Exhaust Hanger: 65.7g OEM Muffler: 28lbs Idle: 65.6dba 3700rpm: 79.2dba 5550rpm: 87.6dba -------------------------------------------------- Perrin Crank Pulley: 1.2lbs Nameless Bolts: 79.6g Nameless Muffled Track Pipe: 5.5lbs Idle: 73.6dba 3700rpm: 87.2dba 5550rpm: 100dba FT86SpeedFactory Exhaust Cover: 142.1g -------------------------------------------------- Total Savings: 22.5lbs + 3.7lbs + 3x(65.7g) + 9.3g -142.1g = 25.9lbs + 64.3g. Final Thoughts: The Perrin Crank Pulley alone wasn't much, but paired with the rpf1's at -5lbs/corner does make it feel more responsive and zippy. The exhaust sounds sporty, very much alive, and daily drive-able. I couldn't get any tests past 5550rpm due to the OFT's launch control settings, but if you are worried about the noise limit you should pass in an event of a citation.(depending if they use the 50% or 75% RPM test). I doubt an uncatted UEL/EL will pass so stick with the stock setup or get a catted one to be safe. OEM bolts are lighter so I will reuse them. |
The Following 2 Users Say Thank You to orz For This Useful Post: | MJones_RB (05-13-2019), new2subaru (05-13-2019) |
05-13-2019, 10:51 PM | #20788 |
Weight Weenie
Drives: 15 FR-S
Drove it at 7C in the rain on summer tires. I felt like I was driving on hockey pucks! Tomorrow promises 14C
05-13-2019, 11:09 PM | #20789 |
Wes
Really? Is this on 215s and stock wheels? I’m in ontario too and unless there’s snow on the ground, summer tires feel super planted. MPSS in 225 on a 8” wide wheel were planted but still playful and I could kick the back end out at will, but now Firehawks in 255 on a 9” wheel result in immortal grip basically no matter the weather
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | Feistyfrog (05-13-2019) |
05-13-2019, 11:25 PM | #20790 |
Weight Weenie
Drives: 15 FR-S
"Really? Is this on 215s and stock wheels? I’m in ontario too and unless there’s snow on the ground, summer tires feel super planted. MPSS in 225 on a 8” wide wheel were planted but still playful and I could kick the back end out at will, but now Firehawks in 255 on a 9” wheel result in immortal grip basically no matter the weather"
Firehawks 225/50 R16. They def don't feel planted...there's a major difference when it warms up more. I'm very careful when driving in the wet, especially when cool. |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
