Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
08-13-2013, 12:04 AM | #1 |
Drives: 2013 Black BRZ Limited
Rear Parking Brake Guard Rub (Meaty Rear Tires)
So I'm running +45 offset 18x9.5" wide wheels with 255/35/18 tires and I am having a slight issue with my wheels rubbing against the parking brake guards during high G cornering. If anyone hears a very slight metallic rub noise from the rear during cornering, I would be fairly sure it is this. I am considering bending them out of the way, but there doesn't seem to be much room there. Has anyone else had this problem when running larger wheels? I've got an autocross this weekend and would like to get this fixed before (by bending or such) then. I'll be glad to take some photos tomorrow if anyone is interested. Thanks!
08-13-2013, 10:16 AM | #2 |
NASA SpecE30 Racer
I looked at those when I installed my 18x9.5 +40 265/35/18, and I removed them and bent them with my vice. Since you are running 5mm less offset, it does not surprise me that you are rubbing them.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following User Says Thank You to King Tut For This Useful Post: | console_cowboy (08-13-2013) |
08-13-2013, 10:34 AM | #3 |
Drives: Toyota GT86
May i please know what is a rear parking brake guide rubber ? do you have any photo of it ? Thanks
08-13-2013, 10:35 AM | #4 |
Thanks
What tire are you running? Stock height?
I run 9.5 +45 rear with continental 255/35/18 no rub but they run narrow and im stock height. |
08-13-2013, 11:08 AM | #5 |
Drives: 2013 Hot Lava FR-S 6 MT
I had the same issue with my TE37SLs 18x9 +45 with Dunlop Direzza ZIIs 255/35. Rubbed on the right rear wheel (grrrr). I also took the brake line guard off and bent it.
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
The Following User Says Thank You to TrogDor the Burninator For This Useful Post: | console_cowboy (08-13-2013) |
08-13-2013, 11:19 AM | #6 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
interested in pics showing exactly what to bend, too. haven't had the issue yet, but good to know what to bend if i encounter it.
08-13-2013, 11:49 AM | #7 |
NASA SpecE30 Racer
It mounts to the rear lower control arm with one bolt and the parking brake line on each side kind of rests on it. The bracket has a loop on top of it to keep the parking brake line from getting into the wheel/tire. You simply remove the bracket and bend that loop to get more clearance. It is easy to see if you have clearance by looking under your car from the rear.
- King Tut
The Following 3 Users Say Thank You to King Tut For This Useful Post: |
08-13-2013, 02:39 PM | #8 |
I am running 255/35/18 tires with RCE Yellow springs. I had no trouble before lowering, so I am sure that is part of the issue. I'm using Kumho Ecsta LE Sport tires, and I am honestly not sure if they run thin or wide. The actual rubbing seems to be on the wheels themselves, so I will try to bend those tomorrow if the weather agrees. Good to know several other people have had to do this. I'll take photos when I bend them for anyone who wants to see. Thank you for the replies.
EDIT: They don't rub at all unless I am doing some hard cornering. Its quite easy to avoid rubbing them unless autocrossing or something of that sort. |
Similar Threads | ||||
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
rear brake pads | donutfilling | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 04-05-2013 10:43 PM |
rear brake light in the rear fog light section | FR-Shadow | Cosmetic Modification (Interior/Exterior/Lighting) | 34 | 12-13-2012 10:52 AM |
FR-S Rear brake light... | MF_DEUCE | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 70 | 05-05-2011 03:53 PM |
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
