Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-03-2015, 12:02 AM | #15 | |
The Following 2 Users Say Thank You to steve99 For This Useful Post: | kch (10-03-2015), Shiv@Openflash (04-15-2016) |
12-28-2015, 09:18 AM | #16 |
Drives: 2013 Subaru BRZ
I'm glad this is normal. I also experienced this after flashing the Stage 1 OFT tune to my BRZ and was hoping this new sound wasn't something wrong.
12-28-2015, 12:42 PM | #17 |
Senior Misanthrope
Well there's some dispute and no one can actually explain what (specifically) is causing the noise. Everyone seems to just be ok with the "it's the variable valve timing, bro" explanation, but I've never seen anything more specific than that.
04-15-2016, 10:31 AM | #18 | |
Drives:
The vibration is hideous, in that very narrow band around 4K. Obviously the alignment of something changed in the removal and refitting. I wonder if it's related to the mid pipe hanger, it seems to be coming from right under my seat (RH drive). I undid that at the pipe end to get the over pipe out. Has anyone hunted down what this was? I'm not really looking forward to getting back under the car and looking for it. |
04-15-2016, 11:21 AM | #19 |
Drives: n/a
For me the sound changed over time and after about a week it was clearly the VVT. It actually became harmonious and pleasing to the ear lol.
However your description is more a vibration and not a sound onlu, so I'd say it's probably not from the VVT Sent from my HTC One M9 using Tapatalk |
04-15-2016, 06:38 PM | #20 | |
try this, undo the midpipe hangar bolt completly, move the bracket with hole in it aboce the bolt hole and replace bolt so bracket is now above bolt, this will loft mid pipe and overpipe slightly. Put large washer on bolt and tichten with bracket still above bolt. see if that helps |
04-15-2016, 07:12 PM | #21 | |
Drives: Toyota 86 GTS
04-15-2016, 08:48 PM | #22 |
Drives: '13 SSM BRZ Limited 6MT
Is it advisable to try to remove this noise from the Stage 2 EL E85 tunes? I installed a Perrin CAI and ran the stock tune. The intake sound is absolutely awesome.
Then I installed the Stage 1 EL 91 tune, the 4k rasp just completely overshadowed the CAI noise... I can only hear it at 3000-3500rpm, then from 3500-4000 it's just a high shrieking noise lol. Went to the Stage 2 EL E85 tune and absolutely love the smoothness of the car now. Absolutely wonderful.... until 3500rpm again. Ideally I'd love to be able to run E85 and NOT have the rasp. I can live with the torque dip. |
04-16-2016, 05:16 AM | #23 |
Drives:
Hissing/rattle from 3.5-4k RPM after OFT
@Wayno @steve99 thanks guys. I do have the slip joint on the bottom - so looks like the way I can choose between the two scenarios would be to remove the alloy tray and take it for a drive. Does anyone know if the rear fibrous tray is secure without the alloy tray - or should I remove that before driving as well?
Assuming it's the slip joint is there something I can put between the tray and pipe that will survive heat and abrasion or am I taking a dremel tool to the plate to make a new window? |
04-16-2016, 05:58 AM | #24 | |
you might just be able to just dent the tray. look for the rub mark and put a dent in that area |
The Following User Says Thank You to steve99 For This Useful Post: | dratom (04-18-2016) |
04-16-2016, 05:13 PM | #25 |
Drives: N/A
The heat shields on my o2 sensors rattled because the sensors were not seated all the way. Always rattled around 3500 rpm. I could watch them spin while someone else revved the car.
2014 BRZ, SWP, OFT, Kosei K4R 17x7 with ZII SS
04-17-2016, 03:03 AM | #26 |
Exactly. Use a hammer. The metal isn't that hard. Don't drive without the skid plate
The Following User Says Thank You to Wayno For This Useful Post: | dratom (04-18-2016) |
04-17-2016, 06:29 AM | #27 | |
This means sensors not screwed in all the way, this can cause incorrect reading as sensor tip not in exhaust flow or leaks. Best to remove sensors, run a M18 by 1.5mm pitch thread tap/chaser through 02 bungs in header then sensors will seat properly |
04-18-2016, 10:19 AM | #28 | ||
Drives:
Not any more. Last edited by dratom; 04-18-2016 at 05:43 PM. |
The Following User Says Thank You to dratom For This Useful Post: | Cheeky (10-30-2021) |
Similar Threads | ||||
Anyone else's 6MT a rattle box at low RPM? | Silver Ignition | Scion FR-S / Toyota 86 GT86 General Forum | 81 | 05-29-2014 11:56 PM |
Rattle above 5k rpm | trippinbillies40 | Issues | Warranty | Recalls / TSB | 1 | 05-28-2014 02:55 PM |
AC Rattle | AVodka14 | Issues | Warranty | Recalls / TSB | 8 | 05-21-2014 12:08 PM |
Anybody Have this Buzz/Rattle? | Gary in NJ | BRZ First-Gen (2012+) -- General Topics | 8 | 10-07-2013 12:36 PM |
A/C Rattle? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-17-2012 07:46 PM |
