Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-15-2015, 03:50 PM | #15 |
Any sound clips?
10-15-2015, 05:01 PM | #16 |
Canada Eh!
Drives: '13 FRS
Nice! If I had the skills, I would have probably done the same. Wishing I took pictures, but the gutted cats definitely don't promote smooth laminar flow. The transitions in the header/FP after the cat is terrible. But if you're in the business of paying someone to remove your header/fp, cut out, and replace your cats with pipe, then you may as well buy a budget header/fp. It'll probably cost the same. The car will benefit from slightly bigger diameter tubing as well. That being said, I'm out a couple hours worth of work and my wallet is untouched, but I've netted a couple ponies and a few ft-lbs. Worth it in my books... |
The Following 2 Users Say Thank You to Joe-G For This Useful Post: | sroby (09-23-2018), Timmy_Jones (02-08-2018) |
10-15-2015, 05:03 PM | #17 |
Canada Eh!
Drives: '13 FRS
I'll try and get some later today if that helps? But I find recordings don't really come close to what most exhausts sound like in person.
11-14-2015, 07:19 PM | #18 |
Drives: 2013 Scion FR-S-white out
11-14-2015, 09:04 PM | #19 |
Canada Eh!
Drives: '13 FRS
I used a Hero 3 to try and record the sound just now... It doesn't sound as good as it does in person...
Custom muffler delete, and both cats are gutted. Video shows cold start, idle, minor blips, and banging off 4k launch control. [ame="https://www.youtube.com/watch?v=IbA_jWi88ws"]FRS Exhaust - Gutted Header, Front Pipe, & Muffler Delete - YouTube[/ame] |
The Following 2 Users Say Thank You to Joe-G For This Useful Post: | guybo (12-19-2016), Plxdjake89 (11-14-2015) |
11-14-2015, 11:21 PM | #20 |
Good looks bro, I haven't heard it yet but I'll take a listen a little later.
The Following User Says Thank You to Plxdjake89 For This Useful Post: | Muchikori (07-11-2018) |
03-14-2017, 02:34 PM | #21 |
Drives: 2017 manual BRZ
Wonder how the 2017 revised manifold will do if gutted.
Sent from my Pixel XL using Tapatalk |
03-15-2017, 12:25 PM | #22 |
Drives: 2017 BRZ WR blue PP
Gutted Header & Front Pipe - Dyno Inside
is it possible to weld a high flow cat on stock header?
03-15-2017, 12:38 PM | #23 |
Drives: 2014 GT86
Yes, but why? Unlike with just gutting it you'll get smaller performance gains, and added costs of buying cat and paying for welding work will nullify cheapness bit. And even if primary cat in header is HF one, you won't be 100% safe from seeing cat readiness CELs. If you are ok with doing something to stock cats, aftermarket header with HF cat or even catless aftermarket header will be better choice (one stock secondary cat should be sufficient to pass smog tests, if those don't include visual checks).
The Following User Says Thank You to churchx For This Useful Post: | Andyxin (03-15-2017) |
03-15-2017, 02:13 PM | #24 | |
Drives: 2013 FR-S Argento
The Following User Says Thank You to bfrank1972 For This Useful Post: | Andyxin (03-15-2017) |
05-17-2017, 01:59 PM | #25 |
Stiggasaurus Rex
Drives: '14 WRB Subaru BRZ 6MT
I plan on doing this, but have sourced a cheap OP and Berk HFC FP to go along with the gutted stock header. I am a complete noob in terms of tuning, would it be safe to assume an OFT OTS EL 93 octane tune would be a good starting point for this setup?
My primary use would be for autocrossing
meh.
05-17-2017, 03:02 PM | #26 |
Drives: 2014 GT86
I guess you can use OFT Stage 2 EL tune with gutted stock header, which, while not completely, is EL header, and Stage 2 tunes are for catless headers.
05-17-2017, 07:52 PM | #27 |
Huge E85 fan!
Drives: 2016 Scion FRS
I've been gutted on Stage 2 OTS 93 tune since last summer. No probs
09-18-2017, 08:56 PM | #28 | ||
Huge E85 fan!
I just found this article. Interesting read on gutting the cats.
http://www.circuitmotorsports-blog.c...-fr-s-86s.html Quote:
The Following User Says Thank You to guybo For This Useful Post: | lazyluka (09-18-2017) |
Similar Threads | ||||
Best Catback/Front Pipe/Over Pipe/Header Combo for the BRZ? | O.Z. BRZ | Engine, Exhaust, Transmission | 22 | 04-17-2019 09:44 AM |
Ceramic coating header only vs header/over pipe/front pipe | pixel67 | Forced Induction | 8 | 08-18-2015 02:39 PM |
FS: OEM FRS/BRZ Header w/ Gutted Cat | malubawla | Engine, Exhaust, Bolt-Ons | 10 | 06-06-2014 11:29 AM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
