Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-08-2012, 10:11 PM | #1 |
Drives: '13 FR-S 6MT / '14 Prius-C
Engine Speed vs Vehicle Speed for 6MT
Maybe I'm crazy, but I did the math and thought this would be a helpful graphic for understanding when to shift and how to rev match. Its helpful for me anyway to think about it. You could easily change the ratios for the 6AT, but since it rev matches for you, it might only be for academic interest. PDF and XLS (as ZIP) files are attached. |
The Following 15 Users Say Thank You to DetroitJake For This Useful Post: | -DK- (04-29-2013), Alias (07-10-2012), ArgentoAtl (01-28-2014), aristo (10-04-2014), chulooz (07-08-2012), cmspooner (07-10-2012), ducks (07-09-2012), frslee (04-27-2013), Guff (07-10-2012), Kwaziekeller (07-08-2012), Lee358 (07-08-2012), LeeMaster (04-27-2013), prest1ge (07-08-2012), sinigang_guy (04-28-2013), Zach (07-09-2012) |
07-09-2012, 09:43 PM | #2 |
DADA
Drives: 2013
8000 rpm and 40 mph 1st gear? What?? Do you want to blow up that engine ?
07-09-2012, 09:48 PM | #3 |
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
He extended the graph to show what is possible, no you do not want to shift at 8000RPM in first, but if you do, you will be at 4950 RPM in second, that is why he posted this....
07-10-2012, 12:57 AM | #4 | |
I'm thinking it would be a bad idea to pull past red line very often (if at all). But if you are keeping the tac around 3-4k for regular driving vs revving it up to 6-7k for fun driving, you can see the spacing to match revs is a little different. I'm sure this becomes natural with practice, but it seemed a useful tool to help visualize how the ratios sync together. |
The Following User Says Thank You to DetroitJake For This Useful Post: | SkAsphalt (04-28-2013) |
07-10-2012, 01:03 AM | #5 |
Drives: Attitude
Much appreciated.
07-10-2012, 01:27 AM | #7 |
Re-member
Drives: Toyota camry
Shift everything right just slightly. My reasoning is that none of the car mags that I know of got to 60 at the top of second. There is something with the tire size and resulting gearing that make the car need to shift to 3rd to get to 60 even though It was apparently designed to hit 60 at the top of second.
Nothing decays like progress, and nothing preserves like neglect.
07-10-2012, 02:22 AM | #8 |
Drives: GT86 DGM
And here you can see the reason it's "slow" to 60. Shifting from 1st to 2nd @ 7k lands you squarely in the torque dip.
07-10-2012, 02:34 AM | #9 |
Tall guys fit, too.
Drives: BRZ Premium 6MT (SWP)
You should actually land at about 5k from a 7200 rpm shift.
The thing is, the MT only hits 57mph at redline in 2nd, so most people shift to 3rd before hitting the barrier.
07-10-2012, 07:54 AM | #10 |
Grip>Slip
07-10-2012, 12:44 PM | #11 |
Tall guys fit, too.
I'm just going by what I experience on the road. I can definitely avoid that dip by shifting hard at close to redline.
I do it pretty much every day, and you can basically hit right around 5k with a fast shift.
07-10-2012, 09:00 PM | #12 | ||
If you changed your tires, this stuff would need to be re calculated. There could also be some other deformation affects I'm not aware off (non belted tires grow in diameter at high speed, but I would guess this affect is small or non existent due to the radial belting, etc). Its also possible I made some kind of units conversion mistake, but I'm pretty sure all that stuff is good. At least the graph seems to follow what I see when I drive. |
07-10-2012, 09:18 PM | #13 | |
Tall guys fit, too.
/shrug EDIT: I suppose it's also possible that I land right at 4500 (which is out of the torque dip) and at WOT I'm past 5k so fast I don't even notice. I can try to hook up a go-pro to analyze that when I get my car back.
04-27-2013, 01:39 AM | #14 |
Updated
I flipped the axes as I have realized its easier to think about it this way.
Similar Threads | ||||
BRZ top speed | speedracer38 | BRZ First-Gen (2012+) -- General Topics | 66 | 07-08-2012 03:37 PM |
speed | eindio | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-27-2012 10:59 AM |
Depth of speed | DIG1992 | Other Vehicles & General Automotive Discussions | 6 | 05-22-2012 01:13 PM |
Speed TV FR-S review | Sport-Tech | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 05-09-2012 11:41 AM |
Need For Speed Shift 2 | Dragonitti | Other Vehicles & General Automotive Discussions | 12 | 04-09-2011 10:49 PM |
