08-08-2015, 05:03 PM | #57 | |
Time Traveller
08-08-2015, 10:06 PM | #58 | |
BOXER FR
Drives: WRB BRZ Limited
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
08-08-2015, 10:47 PM | #59 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
08-09-2015, 04:44 PM | #60 |
Drives: 2015 BRZ
Have you seen our build thread? It's full of graphs!
http://www.ft86club.com/forums/showthread.php?t=90384 |
The Following 3 Users Say Thank You to GSpeed For This Useful Post: |
08-09-2015, 05:33 PM | #61 | |
Drives: 2005 Toyota Camry
For 99% of car owners, alignment is key. My point is about the weight distribution part and how it should be properly considered in the context of aero mods IF one is serious about adjusting weight distribution to maximize performance. -alex |
The Following 2 Users Say Thank You to mav1178 For This Useful Post: | OkieSnuffBox (08-11-2015), Ultramaroon (08-09-2015) |
08-09-2015, 06:04 PM | #62 | |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | GSpeed (08-09-2015) |
08-10-2015, 01:34 PM | #63 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I haven't read this thread, so I don't know if it was mentioned, but I think there are a few options for brake booster delete kits now. I don't have one, but apparently they shed ~20 pounds off the front. So an AC delete, lithium battery, and that are probably going to be your three most effective things for the front. A flywheel might be next after that.
The Following User Says Thank You to Anthony For This Useful Post: | mokinbird87 (08-11-2015) |
08-06-2018, 11:06 AM | #64 | |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Did you ever come up with anymore ideas. I hear everyone say just adjust your corner weights and alignment. But I would rather do that AFTER I have removed as much weight as possible off the front. Here are what I have done so far: Remove Front Bumper Beam AC Delete Lightweight Pulleys DI mounts delete Empty Windshield Bottle ACE headers Removed useless shield thing driver side firewall Coilovers Lighter wheels/Tires Lightweight WRX Wilwood brakes Considerations -Mishimoto slim Fan kit. Waiting on actual weight numbers of stock setup to see if worth it. May only run with passenger fan as Driver Fan is extra for AC. -Was looking for aluminum radiator. All of them are larger capacity any weight savings would be added back in with fluid. - There is Aluminum Oil pan- Again adds in more fluid capacity - Cusco makes a sway bar 2mm smaller than stock, but its still solid not hollow like the rear. -Dry carbon hood - but want in stock design and would paint it stock Not going to do: Flywheel - Already have driveshaft, pulleys. Heard its not good for all 3, plus don't want drivability issues. Chase bays brake boost eliminator- Not ready to tear up braking system on street car.
08-06-2018, 03:48 PM | #65 | ||
Drives: 2014 FR-S
You don't really *need* fender liners, right? Take off some of the underbody plastic bit clips. You don't need all of them. Do the headlights need to have bulbs? Do they even need to be there? Seats? Airbags? Does water + water wetter weigh less than coolant in equivalent volumes? Ooh! Run less oil. Cut 1/4" off the hood. All the way around. Know what weights less than a lightweight sway bar? No sway bar at all. Take the mounts out while you're there. What about your diet? Beer guts are forward-bi-assed. Yanking out the rear seats will still pull some weight off the nose. Anything between the wheels will have a measurable weight on the front wheels. Then strip the wiring harnesses/looms of any items that are simply no longer in the car. Just start taking off parts one at a time until it either won't start, or develops some really bad handling traits. When it does, put that last thing you removed back on, but only use half the screws. Not all of the above is serious. But, it could be.
-Mike
#24 CS/CSR |
The Following User Says Thank You to TrqlessWonder For This Useful Post: | SuperTom (08-06-2018) |
08-06-2018, 04:21 PM | #66 | |
Haha good stuff not looking to strip the car like Anthony but I like your outside the box creativeness. Just looking for replacement parts that are lighter than stock. Car will be stockish to the naked eye. Carbon Fiber seats are coming in this week, Removed door speakers but kept small dash ones and rear ones. Already did a rear seat delete. Ive done all the common weight loss mods. Really its phase II things that may be lighter but overlooked parts like Front LCA's Considering if I go with a aftermarket steering wheel removing the rest of the airbags. Ive been 10+ years in my C5 with no airbags, all my cars have had aftermarket steering wheels. I Did consider Headunit is 4 lbs if there was a way to run an aux wire directly to the stock 2lb amp off my phone. Since I just use apps like Pandora and radio.com 99% of the time anyway. There is a post about people not having the front sway bar. Some debate if its dangerous or not. I do have coilovers which maybe enough to compensate for stiffness especially on a car that is almost 400lbs lighter. Will pass on that and just go a lighter since I will be doing HPDE in this
08-06-2018, 09:32 PM | #67 | |
Only happy when it rains.
Drives: series.blue
When it comes to the brakes, what size wheels can fit over them?I'd love to get lighter brakes but being forced to buy heavier wheels and tires will just offset any actual weight loss. |
08-06-2018, 10:06 PM | #68 | |
I already have the light Wilwood WRX brakes that shaved 30lbs off the front using my scales. I have 17x8 konig hypergrams at 16.5lbs and stock size Hankooks evo 12's at 19lbs for about 5.5lbs total savings per corner. The wilwoods can fit inside 16's but I'm happy with my setup. Ive done a lot already I'm just looking for whats next, especially off the front. A lot of the originators of the forum did things in the beginning but it looks like many are banned. They hold the secret key to unlocking more weight reduction knowledge. The reason why I'm bumping older posts to see if anyone is still active. |
08-06-2018, 10:34 PM | #69 | |
Weight Weenie
Drives: 15 FR-S
Tom, after reading your posts I think you've done just about everything. If you want to go any further you're going to have to get hard core Don't know if you've sen this build but good and there are many others mentioned in the first post. http://www.ft86club.com/forums/showthread.php?t=71806 Did you get the firewall insulation? It's worth about 6lbs and free. It adds a bit of engine noise but nothing extreme. Last edited by new2subaru; 08-06-2018 at 10:53 PM. |
The Following User Says Thank You to new2subaru For This Useful Post: | SuperTom (01-05-2020) |
08-07-2018, 05:14 AM | #70 |
Huge E85 fan!
Drives: 2016 Scion FRS
No airbags and no crash beam... on a road car.
Good luck and make sure you increase the limits on your life insurance. |
Similar Threads | ||||
Making the BRZ ever lighter | Alabang BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 04-16-2014 08:57 AM |
Are dry carbon fiber front 1/4 panels lighter than OEM? | Superhatch | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-27-2013 03:47 AM |
Better to go wider or lighter? | BRAWL | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 08-02-2012 09:48 PM |
Increased whp by having lighter wheels | mechaghost | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 07-03-2012 12:46 AM |
What return from going with lighter wheels? | bazguitarman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 06-01-2012 09:35 AM |
