Forced Induction Turbo, Supercharger, Methanol, Nitrous |
06-03-2019, 09:58 PM | #15 |
Drives: 14 BSP Edelbrock BRZ
Seriously? You write some shit like that with a guy speaking a second language and then you misspell 'weep'?
The Following 6 Users Say Thank You to toast For This Useful Post: | 86MLR (06-04-2019), 86TOYO2k17 (06-04-2019), B T (06-07-2019), DarkPira7e (06-06-2019), Irace86.2.0 (06-03-2019), Joesurf79 (06-06-2019) |
06-03-2019, 09:59 PM | #16 |
And coherent...
The Following 5 Users Say Thank You to toast For This Useful Post: | 86MLR (06-04-2019), 86TOYO2k17 (06-04-2019), DarkPira7e (06-06-2019), Irace86.2.0 (06-03-2019), Turbo (06-06-2019) |
06-03-2019, 11:18 PM | #17 |
Drives: scion frs 2015
sounds like the tuner is doing a safe tune for you not to blow plus your still running oem fuel pump
06-04-2019, 04:52 AM | #18 |
FAIL
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
06-04-2019, 10:56 AM | #19 |
You sure you're in dyno mode (ie pedal dance)?
06-04-2019, 12:05 PM | #20 |
Drives: Q5 + BRZ + M796
A fuel pump upgrade isn’t necessary. I’m running E85 at 12psi with 770cc injectors, and I have a Dw300c, yet the pump isn’t necessary; it was just an upgrade I did along with injectors, but the stock pump wasn’t close to its limits.
06-04-2019, 12:27 PM | #21 |
Unless the traction control came on then the pedal dance shouldn’t effect power. More of a safety thing. Just turning off traction control with the buttons is enough.
06-04-2019, 01:06 PM | #22 |
Ah, I thought all the nannies had to be off in order to have stationary front wheels and spinning rears.
06-04-2019, 01:14 PM | #23 |
If that was the case then burnouts would be impossible without the pedal dance.
06-05-2019, 05:43 PM | #24 |
Drives: turbo frs
At Saturday I'll try dyno jet and I'll c what well happen
I'll update u soon Thank for all |
The Following User Says Thank You to gt7877 For This Useful Post: | 86TOYO2k17 (06-05-2019) |
06-05-2019, 05:48 PM | #25 | |
Drives: turbo frs
Let him speak what he wants I do not care about such people at all my mother language is Arabic English is the second language and I try hard to communicate in the best way with you |
06-05-2019, 07:03 PM | #26 | |
Some people are just idiots. Run a 1/4 mile mate and post your MPH ET and the weight of your car with you in it. Dynos are tuning tools, apps are toys. Rock and Roll
The Following User Says Thank You to 86MLR For This Useful Post: | gt7877 (06-05-2019) |
06-06-2019, 12:35 AM | #27 | |
Drives: FR-S Turbo
Is there another dyno shop you can try? Perhaps one that uses a Dynapak dyno? It would also be good to have the tuner map your AFR ratio and boost level to verify what numbers you're seeing there. I've also been told it can be a good idea to write down the calibration/setting parameters and also record the ambient temperature in the garage that day, but that might be overkill. |
The Following User Says Thank You to Turbo For This Useful Post: | gt7877 (06-06-2019) |
06-06-2019, 08:49 AM | #28 | ||
Drives: 2017 toyota 86
But yes depending on calibration you can have ridiculously high or low numbers. Quote:
Also i don't see you mentioning octane? these cars having such high compression really benefit a lot from higher octane, or hurt a lot more from lower octane. you also live in a very hot climate year round. IF you have access to E85 i would make the switch ASAP, if not i would look into water meth, that will help a lot with keeping intake temps down and give you more power, but also give you more consistent less prone to heat soaking power. |
