10-02-2012, 08:21 PM | #29 | |
Drives: 2013 FRS - Whiteout
I should be covered quite well without all the excess metal floating around still. In fact, here's what went in/on the car during the change (Well, not all 6 liters, but about 5-ish filled it to level):
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified |
10-02-2012, 09:09 PM | #30 |
Drives: LR BRZ Ltd, 06 STi
really only 5? I put in 5.5 then added a bit more after running the engine. easily the 5.8 in the manual.
I tried finding something reliable on the factory oil but I can't find anything. If only some of those peeps doing oil changes after a few hundred miles would do a UOA ...cough, cough, hint hint... whoever reads that :P Couple days and I should get an email from Blackstone, luckily I'm close so shipping is quick. |
10-03-2012, 07:40 AM | #31 |
It's not that easy to tell since I used around a little more than half of the 2-liter can on the last one. so it's more than 5 quarts for sure. 2 liters = 2.11338 quarts. So 5 liters = 5.28344 and I put in a little more than 5. So it's probably pretty close to 5.5 quarts.
10-03-2012, 04:39 PM | #32 | |
We have noticed overall lower engine temps with this oil too. Keep in mind that this is a Racing oil and lacks detergents. |
The Following User Says Thank You to Touge Factory For This Useful Post: | lordtakuban (10-04-2012) |
10-04-2012, 09:03 AM | #33 | |
Usually with a thicker oil, there's still a thin layer of oil slowly draining off the bottom of the pan, but with this 0W-20, almost all of it drains off completely really quick. Not sure if newer engines these days are made for this thinner kind of oil, but this 0W-20 just seems like it doesn't lubricate as well.? I switched to 5W-30 now and might even go with 10W-30 in the future. Screw the 1-2% hit on MPG.. I'd rather have my engine better lubricated/protected. |
10-04-2012, 09:09 AM | #34 | |
10-04-2012, 12:33 PM | #35 | |
Besides, the Owner's Manual even states: "An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions..." Also, these guys used Torco 10W-30 oil: |
10-04-2012, 12:33 PM | #36 | |
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2619245 I understand that the new forumla coming out, Estercore, will have slightly reduced levels of detergents, but will still be able to be safely used on the street. The ester basestocks also have natural detergent abilities. -Dennis |
10-04-2012, 12:51 PM | #37 | |
-Dennis |
The Following User Says Thank You to bluesubie For This Useful Post: | rice_classic (10-04-2012) |
10-04-2012, 12:55 PM | #38 | |
10-04-2012, 01:05 PM | #39 |
Drives: 2013 Subaru SWP BRZ Limited 6AT
I know this is on a tangent, but I just did my first oil & filter change this past week at 1950 miles. The factory oil looked quite dirty (was really black). Maybe it's because I do 95% bumper to bumper driving. For the refil I used Royal Purple 0w20 (please hold personal comments about this choice, I'm trying different oils and hopefully will find one that works for me through trial & error/advice/data/etc). I was quite surprised that the guys used all 6 qts of oil. I told the guys that other guys have reported that the car takes 5.3 qts in actuality rather than the stated 5.8 qts, but the car took all 6 qts so go figure.
In either case, the car has been running fairly smooth and good since. I have another 6 qts of the RP 0w20 left so I'll do another change with it probably around 7000 mile mark. On another note, I purchaed 4 Subaru OEM filters at the dealership and received 4 bluish/purple filters (sorry don't have the #'s with me at work), but noticed that the OEM was a black one when I got to the shop. It fit and seems to be working, but did I get the correct filter? Or should I go raise hell at the dealership for selling me the wrong filters?
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
10-04-2012, 01:10 PM | #40 |
I'm surprised your oil was that beat up. Mine looked fine at 4500 but I'm easily 80% highway miles, maybe higher. I've had two oil changes and both are between 5.8-6 qt.
They gave you the wrong filter. The BRZ has a specific filter no other Subaru uses anymore and is black. I doubt there is much difference but could have less filter area or a different spring bypass. The blues I get for the older subarus are much smaller diameter than the black for the brz. Do a uoa when you change your rp! |
10-04-2012, 01:14 PM | #41 | |
Yeah, I might send my RP 0w20 to Blackstone when I get around to changing out the oil/fitler again. I had the guys install a Fumoto valve during the change and should make changes a breeze. Thanks for your reply. :happy0180:
10-04-2012, 01:17 PM | #42 |
No, sorry I meant I use the black ones for the brz. I use the blue ones for my older STi.
I don't know any of the details around the black filter but my guess is the blue doesn't have as much filter media and shouldn't be used for long interval oil changes. The STi has a max of 3750. |
Similar Threads | ||||
DIY BRZ / FR-S Oil Change | RallySport Direct | DIY (Do-It-Yourself) Guides | 169 | 09-01-2018 02:42 AM |
First Oil Change | Jehuty77 | CANADA | 14 | 08-09-2012 11:54 PM |
When to do your first oil change, and why... | MrBodyMassage | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 07-17-2012 07:43 PM |
Do you change your own oil? If so, why? | SteelReign | Other Vehicles & General Automotive Discussions | 77 | 04-16-2012 10:12 AM |
