05-21-2017, 05:01 PM | #15 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Now for the install spent all day yesterday on this 6am till 8pm with adjustments. Started off in the rear since that would be the most time consuming with the LCA install
Mine has the leveler for the headlights here with Racer x has a hole for. However the stock bolt is not long enough to get a good bite. The zipties were temporary, drilled out the stock bolt this morning and replaced with a longer bolt with lock washers. Eventually got to the front I screwed up a little with the front endlink as I height set it Before I lowered it on the drivers side. Fixed that later on as well. The moment you've been waiting for eyeballed the alignment for now have an appointment Wed. Stock height measured from the ground to center fender was 26 6/16" front, and 26 10/16" rear. Set it at 24 13/16" front both sides, Rear 25" DrR, 24 15/16" PasR. It seemed like the Dr R side too a lot more turns that the others to get lower was getting close to running out adjustment.
05-21-2017, 07:27 PM | #16 | |
Drives: 2013 Subaru BRZ
The sound tube is a resonator as well, it dead ends at a flexible diaphragm which actually generates the intake rasp that is fed into the small hose going down to the right hand footwell. Whether this does more than make noise is impossible to tell without taking it off. When I took mine off it was to fit a Supercharger. Intake resonance becomes pretty much irrelevant with a Supercharger as Edelbrock deletes both the factory intake resonator as well as the sound generator. |
05-21-2017, 08:10 PM | #17 |
Killed Scion
Drives: 2013 FR-S Whiteout
Loving your build so far. The new 17 interior is leaps above the 13 interior. Really like what you did with the brushed metal wrap makes the whole interior look that much better Curious to where you found that TRD badge for your steering wheel and have any more pics of it? Keep up the good work
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
The Following User Says Thank You to MisterSheep For This Useful Post: | SuperTom (06-07-2018) |
05-21-2017, 08:22 PM | #18 | |
My original research came from someone on corvetteforums who made a mufflerless exhaust with just different length Jpipes capped off. At certain RPMs the bad droney sound waves would cancel out leaving the higher pitched exotic. I'm sure similar knowledge is used and tested on our intakes. Sometimes the factory does get it right.
05-21-2017, 08:24 PM | #19 | |
The Following User Says Thank You to SuperTom For This Useful Post: | MisterSheep (05-21-2017) |
05-24-2017, 10:20 PM | #20 |
Nothing major went to get my alignment done at NTB but there computers were updated to read the '17 obdii. So they are having a tech update I will go back on Tuesday.
I like finding fun things on aliexpress for like a $ dollar shipped. Got these door bolt covers. Before After
The Following User Says Thank You to SuperTom For This Useful Post: | ERA (06-07-2018) |
05-30-2017, 09:58 PM | #21 |
Another couple bucks mod from Aliexpress
Also put my order in for Konig Hypergrams 17x8 +40 16.3lbs , Hankook evo tires that are 19lbs stock size. Should take about 6 lbs of rotating mass per corner and look good enough to DD
06-07-2017, 09:29 AM | #22 |
Wes
I just got the Meisterr coilovers too, hoping to install them soon. How are you liking that blitz filter? I was eyeing it, just not sure if it's worth the moula. Coupled with the uprated tube you must feel a bit of a difference?
06-07-2017, 09:44 AM | #23 | |
Really love the MeisterR coilovers highly recommend for street use haven't done any track yet. Cant say Ive felt much difference with the intake but I don't have a sensitive butt dyno. I will be installing lightweight pulleys today stay tuned!
The Following User Says Thank You to SuperTom For This Useful Post: | StraightOuttaCanadaEh (06-07-2017) |
06-07-2017, 03:54 PM | #24 |
Here are godSnow pulleys installed.
Stock Pulley set up weights 6.25 lbs New pulleys weight 1.3lbs To get the old pulleys off I kept the belt on first to get the bolts on the Alt, And Water loosened. I did not need air ratchet on the Alt bolt using this method. I need my trusty 4ft Iron Pipe over my breaker to get the Crank loose. Pulled so much I got the wheels to move slightly then it finally broke Forgot to take pic with air intake out of the way. Great way to save nearly 5lbs reciprocating mass. And I don't see the need to spend any more on namebrand pulleys. Overrall quality was very good some slight nicks on the outer edge but everything on the belt drive areas where smooth.
06-07-2017, 05:49 PM | #25 |
My day is not over just installed these Perrin Control Arm Braces got them on the Perrin Garage Sale on ebay $35. Otherwise I wouldn't spend big money on something like this.
Perrin 10.3 oz Stock 15.2 oz Simply jack up front. Unbolt old ones, Slide on new ones, Red Threadlock, bolt to spec Don't know if they will do much but seem more robust and 5oz lighter at the same time.
The Following User Says Thank You to SuperTom For This Useful Post: | RuyGuy2 (04-21-2020) |
06-07-2017, 06:06 PM | #26 |
Sneak Preview For Tomorrow
Konig Hypergrams 17x8 showed up. Slightly Heavier than advertised about 16.8 lbs vs 16.3 advertised according to this scale. And tires are here and nice and light as advertised 19.3lbs will be 36.1lbs total good for an honest 5.4lb rotating mass loss!!!!! Cant wait to get them mounted
The Following 2 Users Say Thank You to SuperTom For This Useful Post: | korhun (12-19-2019), StraightOuttaCanadaEh (06-07-2017) |
06-08-2017, 03:55 PM | #27 |
Drives: FR-S 10 series
drooling over your center console wrap job.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 |
06-08-2017, 07:16 PM | #28 |
The Following User Says Thank You to SuperTom For This Useful Post: | HachiRokuX (06-10-2018) |
Similar Threads | ||||
mothespaceman: 14' Satin White BRZ Build! | mothespaceman | Member's Car Journals | 25 | 09-19-2014 05:30 PM |
White BRZ Limited Build Thread | NoFlush | Member's Car Journals | 4 | 05-10-2014 02:04 PM |
white trd 2013 build | Pcharliep04 | Member's Car Journals | 0 | 04-24-2014 01:25 AM |
Build-thread White Wasp FR-S by Mit_Peid | mit_peid | Member's Car Journals | 7 | 01-05-2014 07:47 PM |
White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-01-2013 11:45 PM |
