Forced Induction Turbo, Supercharger, Methanol, Nitrous |
04-29-2019, 06:04 PM | #29 |
Drives: 1996 ST204, Series 10 FR-S
@CSG_Mike
I'm curious to know what happens if the unit is older than 3 years. Do you know what Rotrex offers to those owners? It's something I didn't look into with KW. |
04-29-2019, 06:14 PM | #30 |
I finally got to replacing every bearing with NSK bearings which Rotrex also uses from the factory. Luckly, all but one of the bearings I purchased locally were made in Japan. Not sure if that makes any difference (likely not) but it's JDM yo.
Rotrex made all of the bearing bores a little big to make assembly easy I assume. Unfortunately, the bearings are not seated properly and slowly enlarging the bore as time goes on. I noticed that there was some signs of wear in very bearing bore but less severe compared to bearing #2 in the previous photos. I decided to use some Loctite 660 retention compound on all of the bearing outer races to prevent them from spinning. Hopefully this will be the last time I see the inside of this thing. Mated the two parts back together using Ultra Black RTV and red Loctite where needed. It feels good to have it back together |
The Following 3 Users Say Thank You to projek_01 For This Useful Post: |
04-30-2019, 11:52 AM | #31 | |
Drives: frs
04-30-2019, 07:25 PM | #32 |
Drives: Ae86
Thank you for the write up, very good info.
Did you have much trouble pressing the drive unit back together? How did you press the compressor wheel on and off without snapping the shaft or damaging the drive unit? |
The Following User Says Thank You to Frantic For This Useful Post: | projek_01 (05-02-2019) |
04-30-2019, 07:26 PM | #33 |
Drives: 2017 Toyota 86
So is the JRSC not a good long term option for FI? My understanding is that it’s been a very reliable kit for most people but it seems like it has some design flaws..
05-01-2019, 11:56 AM | #34 | ||
With heat, reassembly was a breeze. Heating both the "ring gear" and compressor assembly at 400F for 10min allowed them to be re-assembled with hand strength. Quote:
The hardened and therefore brittle sunshaft is probably the Achilles heal of the Rotrex blower. It wouldn't take much for Rotrex to improve it and I hope they have already done that. |
The Following 2 Users Say Thank You to projek_01 For This Useful Post: | HachiRokuX (05-01-2019), wparsons (05-03-2019) |
05-01-2019, 04:15 PM | #35 | |
pessimistic skeptic
Rotrex offers them to buy a new unit. My C30 is still working just fine after 25K miles (2 years). A new C30 is $2200 and I would just order another unit when/if there is a problem after 3 years. Simple, right? Whatever you are trying to prove here, my experience is that Rotrex compressor is a good and reliable product. And by the way, I really doubt that compressor you are trying to fix will ever work or be reliable again. Thanks for the pictures though. |
The Following User Says Thank You to mrg666 For This Useful Post: | HachiRokuX (05-01-2019) |
05-01-2019, 05:47 PM | #36 |
The JRSC is very reliable, both on the track and for street use.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
05-01-2019, 06:26 PM | #37 | |
Wow, what makes you so sure that my unit will never work or be reliable again? Do you have a mechanical or engineering background to explain why it wouldn't?
I'm glad your unit is good and reliable. I'm not trying to prove anything. I have nothing to gain from showing the flaws in my Rotrex C30. I spent my hard earned money to buy this supercharger just like everyone else but mine was starting to fail. It's not like I'm trying to sell people turbo kits and steering them away from a Rotrex. Just like the FA20 engine, the Rotrex is a decent unit. Many people have put lots of miles and track time on it without a single issue. However, I'm just merely pointing out it's flaws and showing places where it can be improved in my opinion. This is equivalent to someone doing a FA20 teardown/rebuild from a spin bearing or thrown rod. I feel like some people are getting a little offended when I jab at some design flaws. The blower is fairly reliable for most people but we also can't ignore the fact that a fair amount of people have experienced failures with the KW AND JRSC (less often). We are lucky that our FA20 doesn't rev to the moon like the F20C or K20 in the Honda world. Type in Rotrex failure in a Honda forum and you will see what I mean. Either way, my opinion IS biased because I own a failed unit. I admit that for sure. As a retailer of the JRSC or owner of a working unit, you are entitled to your own opinion. Quote:
The Following 2 Users Say Thank You to projek_01 For This Useful Post: | BigFatFlip (05-02-2019), toast (05-02-2019) |
05-01-2019, 07:32 PM | #38 | |
pessimistic skeptic
That unit is sealed and not serviceable for a reason. Engineering tolerances get pretty tight to function reliably at 100K rpm. You have no idea about those tolerances and material specs. And, yes, I am an engineer and wise enough not to share credentials on public forums.
Thank you again for the teardown; that was interesting. But I don't take your design criticism too seriously. If you want to risk more of your "hard-earned" money by installing that unit again Sure that is my opinion and it is your car. Good luck. Quote:
05-01-2019, 09:39 PM | #39 | |
In other words, the engine's RPM + gearing determines rotrex RPM, not just the engine RPM. |
The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (05-03-2019) |
05-01-2019, 10:26 PM | #40 | ||
Either way, what's done is done and I am confident enough to run this blower. I will run some nylon filters on the hot side pipes before the intercooler for some added protection. Best of luck to me! No more arguing on my end - what's done is done. I wrote this thread to help people understand what is potentially happening inside their blowers. |
The Following 5 Users Say Thank You to projek_01 For This Useful Post: | CSG Mike (05-02-2019), new2subaru (05-01-2019), sroby (05-01-2019), toast (05-02-2019), wparsons (05-03-2019) |
05-02-2019, 07:32 AM | #41 |
Drives: Ae86
I hope the little rotrex goes for years to come.
05-02-2019, 10:19 AM | #42 |
Drives: 14 BSP Edelbrock BRZ
Thanks for this thread projek_01. Always nice when someone tries to help out the community by showing what is going on inside a unit.
Here's hoping your unit outlasts the one belonging to the Simpsons character from upstate NY. |
Similar Threads | ||||
Shopping cars today, test drove an fr-s..my thoughts and I'd like more opinions plz. | maybebrz | BRZ First-Gen (2012+) -- General Topics | 55 | 11-04-2015 09:49 AM |
Thoughts on Kraftwerks C-Type Rotrex Supercharger | Piper606 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 07-31-2015 09:59 AM |
FS:CA Brand new never opened KW INOX V3 for sale | stiboost08 | Brakes, Suspension, Chassis | 6 | 07-31-2014 01:18 PM |
FS/FT: Apple tv! Brand new never opened! | Duthebarber | Miscellaneous | 0 | 10-07-2013 02:34 PM |
18x8 Drag DR 38 +35 Never opened | Tdooley | Wheels and Tires | 2 | 02-09-2013 11:42 PM |
