GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
12-12-2023, 03:23 AM | #1 |
Drives: 2022 GR86
Early announcement for the 86BUTTDROP lowering brackets for OEM seats
If you're taller than 6' and/or have a long torso and/or drive the car with the helmet on, you've likely experienced various degrees of issues with the headroom.
As a 6'4" guy with a tall torso myself, I always struggled a bit with my seating position during track days and autox. I had to sacrifice either the legroom, neck comfort or arm position. Every time after a track day my upper back would be tired, and every once in a while I literally needed a chiropractor appointment. I decided I had to figure out a solution. Some people just switch to aftermarket seats. I'm a believer of the "either full OEM, or full race car" approach to the safety systems, so losing the airbag was not acceptable to me. Additionally, I wanted to keep the seat back adjustable. The great news is that after some research I found a solution! I designed and made a prototype mounting bracket for the OEM seat that drops the seat by 15 mm. (I believe it's possible to achieve 20 or even 25 mm below OEM, I'm currently working on a revised design to confirm.) A couple of days ago I went to a track day where I tested the new seat position and immediately felt an improvement. I was able to improve my arm position and move my head more freely, my "look ahead" vision improved, and best of all I had no discomfort in my upper back the next day! To lower the seat beyond the OEM range, I had to remove the sliders. There's still a bit of legroom adjustment through the height adjustment mechanism that is retained, in case another tall-ish person needs to drive the car. The kit doesn't require any cutting or drilling of the OEM parts, and can easily be un-installed. Installing the kit is not harder than installing a bucket seat (I'd argue it's actually easier), and much easier than installing ND Miata Seat Lowering Brackets from Paco Motorsports. I'm exploring the idea of offering a small batch of these brackets for sale.
Follow the build thread for my GR86!
The Following 3 Users Say Thank You to timurrrr For This Useful Post: |
12-12-2023, 03:30 AM | #2 |
Drives: 2022 GR86
If you're interested in buying one, please post a response, including:
This is still cheaper than any aftermarket seat + mounting bracket combo that I'm aware of.
The Following 2 Users Say Thank You to timurrrr For This Useful Post: | alphasaur (02-29-2024), Ultramaroon (12-12-2023) |
12-12-2023, 03:31 AM | #3 |
Drives: 2022 GR86
Forgot to mention: this kit is designed for gen2 seats only.
A similar product for gen1s might be possible, but I don't have time to look into that yet.
12-12-2023, 07:48 AM | #4 |
Drives: GR86
12-12-2023, 04:15 PM | #5 |
I have a Gen 1 but would be interested in testing if development ever begins to include 2013-2020 cars.
2nd Gen seats fit in the 1st Gen but I understand the rails might be different enough to make a difference. Also located in the Bay Area. |
12-14-2023, 12:10 AM | #6 | |
Drives: 2022 GR86
The Following 2 Users Say Thank You to timurrrr For This Useful Post: | Ultramaroon (01-26-2024), Wally86 (12-14-2023) |
01-06-2024, 10:32 AM | #7 |
Drives: Dodge Patitas
Another subscribed hopeful.
01-26-2024, 11:08 AM | #9 |
Drives: 22 BRZ limited
Interest here as well.
1. Fancy, heated. 2. 3. Willing to test. 4. No ME background, Aviation based mechanic. 5. See ↙.
01-26-2024, 11:50 AM | #10 |
義理チョコ
Every little bit helps us freaks. In 4 drop.
01-26-2024, 04:01 PM | #11 |
Drives: '23 BRZ Limited
I'm not a tall guy, but I feel "on" the car in the 2nd gen vs "in" the car like my 1st gen.
Have you had a chance to see if you can more than 15mm yet? Heated seat, '23 BRZ Limited.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
01-30-2024, 12:15 PM | #12 | |
Drives: 2022 GR86
I think I might be able to eventually get to ~30 mm... But beyond a certain point the more you drop, the more compromised other things get, such as ease of installation, structural rigidity and necessity to start cutting OEM stuff. Absolutely!
The Following 2 Users Say Thank You to timurrrr For This Useful Post: | Ultramaroon (01-30-2024), Wally86 (01-31-2024) |
01-31-2024, 09:26 AM | #13 |
FWIW I have 40mm drop seat rails on my 1st gen with Recaro SR7 seats (which I think also drop your butt a little) and the difference while driving is definitely awesome.
It is also definitely a compromise in terms of getting in and especially getting out. Parallel parked next to a curb requires some dexterity. Luckily I'm limber as heck but passengers sometimes complain. 15-25mm seems like a good compromise (though I regret nothing). - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Ultramaroon (01-31-2024) |
01-31-2024, 01:09 PM | #14 |
義理チョコ
My headliner resembles an old floor mat.
Similar Threads | ||||
Braum Elite X Seats With Sliders and Planted Seat Brackets | Jstyle | Interior Parts (Incl. Lighting) | 1 | 02-23-2022 11:03 PM |
Lowering Stock Seats/Aftermarket Seats. Headroom Needed! | RobGT86 | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 01-17-2019 05:53 PM |
Rear seats brackets Wanted!!!! | Klassickk1 | Want-To-Buy Requests | 3 | 05-02-2018 01:46 PM |
Possible to mount BRZ seats to Planted brackets? | fafaforza | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 12-18-2017 10:03 AM |
Seat lowering brackets/rails | Ashikabi | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 06-28-2016 08:15 AM |
