07-28-2015, 08:44 PM | #1443 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
also could people please stop quoting photos, its frustrating as hell. if you want more pm the person or click their name --> statistics --> search threads started by said person. yes it will fit. you will pull camber at the top hats to gain the clearance you need at the strut and should be okay. i know people running RS05RR's at +42 with a 265 and they are just fine. what is the reason you don't want more than -1 in the rear. i would tell you to go at least -1.4..... mcs, great suspension--what spring rates? |
The Following 3 Users Say Thank You to Jive Turkey For This Useful Post: |
07-29-2015, 11:31 AM | #1444 |
I Love custom Turbo kits
Drives: Limited BRZ
I don't know about anyone else, but I love MEATY....
@Jive Turkey Volks ZE40 18X10 +40 Michelin PSS 275/35/18. I think this is as big as you can fit in the front basically with stock fenders. I barely can fit a finger between the tire and the coilover.
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post: |
07-29-2015, 11:35 AM | #1445 | |
Drives: 4 wheels
Did you have any rubbing in the rear
Pekingduck's Build thread http://www.ft86club.com/forums/showthread.php?t=5717
07-29-2015, 11:57 AM | #1446 |
Drives: Limited BRZ
I still haven't been able to take them through the paces, as I have two TPMS sensors clunking around inside the wheels and need to wait for the new ones.
I had done a mild fender roll to fit 265 MPSS on 9.5 wheels with +40 offset. I have driven this setup a bit, and have not rubbed yet front or back. The fronts are not rolled at all, completely stock. Rubbing will hugely depend on camber and ride height too. I run right now -2.3 in the front and -1.8 in the back. I raised the car a bit before rolling fenders last time. I had almost no fender gap before, now about 1 finger in front and two tight in the back (insert pink/sink finger jokes).
07-29-2015, 03:54 PM | #1447 |
Lots of good lookin cars/wheels/meats in here. hit us up if you are looking for anything for your ride!
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post: | manualmotive (08-04-2015) |
07-29-2015, 04:05 PM | #1448 |
any 16" wheels?
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
07-29-2015, 04:25 PM | #1449 |
07-29-2015, 10:23 PM | #1450 |
Drives: '14 BRZ Todoroki/OriginLabo
Ended up going with the 245/40 federal SS595 on my 17x9 +35 vordovens. Here's some shitty phone pics of the first test fit; Haven't driven on them yet as I haven't gotten a post-coilover-install alignment yet, but they look pretty meaty for 245's. Fits the rear fender a lot better than I expected Planning to go lower in the front a tad with less camber but Imma see see how much it rubs first. The rear will be lower after I get RLA's as well.
07-31-2015, 12:12 AM | #1451 |
Drives: Toyobaruion
Gramlights 57DR 18x9.5 +38 255/35/18 Rear camber: -3.2 Front camber: -3.5 Toe: zeroed |
The Following 2 Users Say Thank You to c4lvinnn For This Useful Post: | Argento_86 (08-08-2015), Metabrz (07-31-2015) |
07-31-2015, 12:50 PM | #1452 |
Drives: FR-S Whiteout
Any fitment issues running 17x9 +45 wheels with a meaty tire?
Intent > Content
cowardice is the mother of cruelty. |
08-01-2015, 06:44 PM | #1453 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I run 275/40 out back. Sent from my iPhone using Tapatalk
08-02-2015, 03:05 PM | #1454 |
With a +45 offset? How about the front?
Intent > Content
08-02-2015, 03:15 PM | #1455 |
245/45 front 275/40 rear Will be rolling/pulling most likely as I haven't driven much on it yet but it looks like it'll rub.
The Following User Says Thank You to slicktop For This Useful Post: | solidONE (08-02-2015) |
08-03-2015, 04:01 PM | #1456 |
That Striped FRS
Drives: 2013 Ultramarine FR-S 6MT
Heres my new setup, only meaty by definition in the rear.
Enkei Kojin 18x8 Front 18x9.5 Rear Michelin Pilot Sport A/S3 225/45/18 Front 255/45/18 Rear Even on stock suspension no rub or issues at all! |
The Following User Says Thank You to JellyForSale For This Useful Post: | VMRamos (12-17-2015) |
Similar Threads | ||||
Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
