Old 09-18-2019, 09:22 PM   #15
wparsons
wparsons's Avatar
Originally Posted by Spacemane969 View Post
Alignment is buttoned up really nicely, I make sure that it's better than factory but still within OEM ranges. I think about placebo alot, I might have to do a swap drive with something stock, but I know something just doesn't feel right.
I'm also still having creaking and clunking in the end links although it's not as severe ,as I've adjusted it after install. I've seen so many different opinions on install, some say that the lengths don't have to be equal left to right, some say they have to be absolutely perfect. I noticed the other day that somehow my right wheel measures up to 5/8" higher than my left wheel on completely flat ground(measured to fender). Not sure if that is acceptable or normal.
5/8" difference left to right is pretty huge, I'd look into what's happening there. Was it on perfectly flat ground with no extra weight in the car?
The end link lengths should be set to remove any preload/twist on the bar at resting height. The easiest way to do that is to have the car resting on flat ground with both links disconnected, adjust one link to get the arm of the sway bar horizontal, then go to the other side and adjust the link so that it easily connects to the sway bar without any force. Chances are very slim that the lengths will be the same, even if the ride height is perfectly even left/right.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Spacemane969 (09-19-2019)
Old 09-19-2019, 03:42 PM   #16
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Great info. Thanks.
Spacemane969 is offline   Reply With Quote
Nuts for Front Sway Bar End Links. oldlostcory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-27-2019 07:25 PM
ISO Front sway bar and end links vladniko86 Want-To-Buy Requests 0 05-30-2019 02:59 PM
WTB/ISO: stock front sway bar and end links 8RZ Want-To-Buy Requests 2 05-01-2017 03:55 AM
Front Sway bar end links rick s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-09-2015 11:33 PM
WTB: Whiteline Front sway bar Links. Filipino Royale Brakes, Suspension, Chassis 0 08-06-2014 02:46 AM
