Old 10-01-2017, 12:34 AM   #15
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Do different pads provide a different feel? Like do organic pads feel firmer or softer than semi-metallic or ceramic or whatever?
I have a Wilwood kit with semi-metallic pads. I've bled my brakes with a mechanic friend twice on two separate occasions and there is no air in the lines, but the pedal feels like I can bottom it out if I push hard enough. The pedal feels to have less bite unless I slam it when braking abruptly. My friend's M2 has huge brakes, but I never expected them to be so on and off. I figured mine would be better than stock in endurance (heat management), stopping power and modulation/feel. I really can't remember what my car felt like stock, so it is hard to tell how the car compares. I guess I am looking for firmer feel.
Old 10-01-2017, 10:04 PM   #16
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
It was the rear pads, they had only a few mm of pad left. Fronts are good for a few more years.
Old 10-02-2017, 02:09 PM   #17
LotsaMiles
Drives: Scion FR-s, xB, iA, Silverado Z71 4
Originally Posted by Capt Spaulding View Post
My wife's Camry did the same thing. The pads were fine and disc runout didn't seem to be the problem. I bet on the hunch it was a bedding issue. Took the car out to a back road and did threshold level 65-15 mph stops until the brakes faded just a bit. Problem solved.
What do you mean by "bedding"?
Never mind. I googled it. Who knew?!
LotsaMiles is offline   Reply With Quote
Old 10-02-2017, 02:21 PM   #18
Racecomp Engineering
Yup! Lots of cars with EBD will go through rear pads more quickly than fronts for those that do mostly easy-ish street driving.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
B-R-Z (10-02-2017)
Old 10-02-2017, 02:59 PM   #19
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I pulled my stock pads off at 35k because I got a great deal on my favorite spirited DD pad, the stoptech sports. I was shocked that there was barely any wear. I've been doing mountain runs, up and down, and DD'ing on backroads the cars whole life.
The brake dust was hardly evident before I swapped the stoptechs on...
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 12-11-2017, 09:57 AM   #20
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
I am up to 115k miles on my 2013 BRZ (bought new in 2013 with 5 miles). I drive 100 miles per day for work 5 days a week, hitting heavy stop and go traffic each way. In addition to that, I drive a decent amount for personal use. Probably ~26k/year
Last week I started hearing a squeak when I applied the brakes and thought I was finally due for new pads so I go out to my local dealership yesterday to pick up pads. I flipped up my caliper today to find my current pads have almost half of pad meat left; both sides have identical wear. Has anyone else had pads this long? On my prior cars (Integra GSR, S2000) I've replaced pads twice within similar mileage.
Put nearly 200k on my truck before I replaced the factory pads
Sent from my Pixel using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 12-11-2017, 11:23 AM   #21
Darth Khan
I think therefore.....
Darth Khan's Avatar
Drives: Toyota 86 860 Halo White (Manual)
In my commuter cars I used to do a lot of engine breaking, because of that my pads used to last a very long time. After some research I discovered the general recommendation is NOT to use engine breaking when you should be using breaks.
The logic is simple: Its cheaper and easier to replace break pads than to replace a clutch. I still take my foot off the gas to slow but if I need to change gear I use the breaks.
I would suspect people with high mileage break pads instinctively do the following:
  1. Keep a good distance between you and the car in front allowing you to slow without the need to break constantly.
  2. Do not over accelerate in traffic causing excessive breaking (and fuel consumption).
  3. Use engine breaking a lot.
  4. Do not race to the next set of traffic lights.
  5. Do a lot of freeway driving. (This is major).
People with low mileage break pads are doing the following:
  1. Accelerate hard.
  2. Break Hard.
  3. Race to the next set of traffic lights.
  4. Ride peoples butt/ass on the freeway.
  5. Get less than 25 mpg.
Having said all of the above there are days where I go back to my old pattern of engine breaking all the time. Its hard to break old habits.
P.S.
I have excluded people who autocross/race. If your breaks are lasting your doing it wrong.
May the N.A. force be with you.
Darth Khan is offline   Reply With Quote
Old 12-11-2017, 11:38 AM   #22
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
I try not to break my engine nor my brakes.
On a serious note, I'm at 60,000 miles, and my pads are only down about 1 mm from when I bough the car w/ 23,000 miles on it. And here I thought I was special....
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 12-11-2017, 12:02 PM   #23
ermax
ermax's Avatar
I've seen this before where people think that engine braking wears out the clutch. If the clutch is fully engauged then it will no longer be slipping. If it isn't slipping then it isn't wearing. The only extra wear I can think of from engine braking is if you downshift through each gear in which case you would put a little wear on the clutch and the syncros.
I don't engine brake to save pads though. I just do it because it's fun. It's part of driving a manual. The extra wear would be hard to measure so who cares.
Old 12-11-2017, 12:28 PM   #24
driggity
Drives: Silver Coupe with a Boxer
I know this is an old post, but yes pads can give a different feel but I don't think that's the case for your pads. Does the pedal feel change much from when the pads are cold vs. when you've been putting a lot of heat into them?
What are the size of the pistons in the Wilwoods compared to stock?
driggity is offline   Reply With Quote
The Following User Says Thank You to driggity For This Useful Post:
Irace86.2.0 (12-11-2017)
Old 12-11-2017, 12:40 PM   #25
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I made it 70,000 miles with my stock brakes. Just bought new rotors and pads all around. Should be a fun install next week.
I LIKE TIRES!
Ultramaroon (12-11-2017)
Old 12-11-2017, 02:43 PM   #26
  1. Accelerate hard.
  2. Break Hard.
P.S.
I have used engine braking (not so much into engine breaking) on every car I have ever owned. Never had to replace a clutch yet. When you figure in how many times you shift during driving then the total amount to do it to brake becomes meaningless as far as wear is concerned. Even if slowing down by using the brakes you still need to downshift so the gains are minimal at best.
ermax (12-11-2017)
Old 12-11-2017, 03:35 PM   #27
Darth Khan
Darth Khan's Avatar
MMMM, I knead to pruf reed better.
I agree, the one thing I don't do any more is shift down the gears to slow down. I just hit the breaks and go direct the lowest gear I think I will "knead".
The Following 2 Users Say Thank You to Darth Khan For This Useful Post:
Tcoat (12-11-2017), Ultramaroon (12-11-2017)
Old 12-11-2017, 04:17 PM   #28
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Yes, different pads will feel different. My Winmax W5s feel very spongy and vague when cold but simply swap in my EBC Yellows and I get consistently solid feel from stone cold in -20c up to 32c being pounded around on track.
Edit: Feel I should clarify, I'm not talking up the EBC Yellows against the Winmax W5. The W5 is a dedicated track pad and isn't designed to be run cold but it is amazing once it's hot and the EBC Yellows don't compare in terms of bite or feel once they're hot.
Lynxis is offline   Reply With Quote
The Following 2 Users Say Thank You to Lynxis For This Useful Post:
Irace86.2.0 (12-11-2017), Tcoat (12-11-2017)
Search this Thread:
Advanced Search
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
swapping brake fluid: taking FOREVER to bleed the air!! snuff58 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 11-02-2015 03:09 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
