04-19-2013, 12:18 AM | #254 |
Seņor Member
Drives: 2013 Raven, Drifty things
Any plans on doing some heat wrap or even a vented hood? Seems like with the current design your intake temps will be high. Looks awesome though, and the fact that you did it yourself is even more amazing
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris '13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross. |
The Following User Says Thank You to 6-Shift For This Useful Post: | Silverdub (04-19-2013) |
04-19-2013, 06:06 AM | #255 |
Boostin'
Drives: FRS-T
No vented hood thats for sure. And the air inlet is in the stock location so im not worried about air temps
04-20-2013, 05:23 PM | #256 |
Boostin'
Drives: FRS-T
Today i built this wiring harness for my gauges. I cutted out the 12volts plug in the glove compartment and soldered a harness and connector. Then another harness splits the power in two and then onto the gauges. This way both gauges can be removed easily. I also installed a 10amp fuse on each gauge harness like AEM suggests.
[IMG]http://i65.photobucket.com/albums/h219/silverdub/507E9EB5-B893-44E5-95CA-A8175D10D42B-314-00000022151489E1_zps50f***42.jpg[/IMG] First test... Yes its got power with the key on! Both gauges working with the car running Now i just need to make some kind of holding bracket
04-21-2013, 10:09 AM | #257 |
Boostin'
Drives: FRS-T
I just unplugged the maf and the car is running a better afr!
The Following User Says Thank You to Silverdub For This Useful Post: | Sportsguy83 (04-23-2013) |
04-22-2013, 10:20 PM | #258 |
Boostin'
Drives: FRS-T
finally boosting and having fun but i need more power.. dyno comming soon, give or take a week or two!
04-22-2013, 10:26 PM | #259 |
Boostin'
Drives: FRS-T
After the first night of fun!
04-23-2013, 12:28 AM | #260 |
Drives: 2013 Asphalt FR-S
I think he was referring to the cold side charge pipe being near the hot side when talking about intake temps.
Looking good so far.. I take it your driving it on the Visconti base map?
~Namaste~ |
The Following User Says Thank You to mad_sb For This Useful Post: | Silverdub (04-23-2013) |
04-23-2013, 06:02 AM | #261 |
Boostin'
Drives: FRS-T
Yes exactly
04-23-2013, 08:12 AM | #262 |
I can't tell if your kidding about 12.3:1 at idle (based on the vacuum reading) being better than 14.4 or serious lol. Of course 12.3:1 under load is better than 14.4 any day of the week but at idle it is needlessly rich
I'm sure visconti will have your tune sorted out in short order... In for dyno sheet.
~Namaste~ |
04-23-2013, 10:16 AM | #263 |
Boostin'
Drives: FRS-T
Car was pinging a bit this morning with minimal load... Waiting on new tune and then dyno. I might give him s call and drive diwn to his place if he wants
04-23-2013, 01:17 PM | #264 | |
anyway.. if the maf is not scaled yet the calulated load will be lower than it should be and you will be running more timing than desired as a result. May be best not to drive it until you get some more updates from visconti... and make sure he knows your on a larger maf housing.
~Namaste~ |
04-23-2013, 03:03 PM | #265 |
Boostin'
Drives: FRS-T
Yeah he knows about it and i sent some idle logs! Waiting on the update frim him!
04-23-2013, 06:51 PM | #266 |
Boostin'
Drives: FRS-T
Having fun with TechStream at work! Idle logs...
The Following User Says Thank You to Silverdub For This Useful Post: | AJPG (07-30-2014) |
Similar Threads | ||||
Silverdub firestorm 6mt | Silverdub | Member's Car Journals | 26 | 07-23-2012 05:13 PM |
86-X project | phenom86 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-11-2012 02:57 PM |
Project continue | 4agze | Other Vehicles & General Automotive Discussions | 37 | 11-15-2011 02:55 AM |
New Project x2 | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 9 | 10-25-2009 11:17 AM |
