03-25-2014, 06:31 PM | #15 |
Drives: 2013 Silver Toyota 86
From what I understood at the service centre, the buzzer is inside the meter console. So you need to remove the console from the car Dash and open up the assembly.
I was hoping for a fuse or something that would disable it. P.S. - This is on the list of things to do. Can someone help with the approximate pricing of a new meter console for the 86? |
12-15-2014, 03:47 AM | #16 |
Drives: Hot Lava 86 MT
Ok, this took my over 18 months to get around too, but in a matter of 30 minutes all speed chimes are removed. very simple process actually.
No more beeping while at the track!!!
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
The Following User Says Thank You to RevoG For This Useful Post: | AZOOZ_95 (12-17-2014) |
12-17-2014, 10:58 AM | #17 |
Middle Eastern 86
Drives: RED GT86
PLEASE EXPLAIN
12-17-2014, 12:13 PM | #18 | |
Drives: 2013 Asphalt Fr-S
Revo, where do our american cars start chiming? I've broken 105 mph (168 kph) and it's never chimed on me. On a side note, the AE85 and AE86 both chimed at speed too. I kind of found it endearing on the track and wouldn't mind so much if Emi did the same.
12-18-2014, 03:57 AM | #19 |
Celadrielas, this seems to be a Middle East region thing. Japanese 86's chime from 100km/h, our do it from 120km/h. Problem is you can drive at 140km/h on the highways so the chime is going all the time.
Azooz, actually quite simple. Take the instrument cluster out, take it apart, remove needles, take face off, remove about 8 screws, and open. Then just taped up the speaker with ductape and problem solved. The whole process took about 30 minutes.
04-01-2015, 10:01 AM | #20 | |
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
I'm planning to buy a BRZ in Saudi Arabia so I also need to disable this speed chime once I buy my car. I'm assuming the chime speakers will be the same as GT86's. I have one question... will disabling the overspeed chime also disable other chimes and/or sounds? Is this speaker in the instrument cluster responsible for only overspeed chime? |
04-11-2015, 02:48 PM | #21 | |
The Following User Says Thank You to RevoG For This Useful Post: | Rookie84 (04-11-2015) |
04-11-2015, 03:18 PM | #22 | |
07-08-2015, 11:31 AM | #23 |
Guys
Any fix for this ? |
07-08-2015, 12:16 PM | #24 |
Yes, just take the instrument cluster out, take it apart and tape up or disable the speaker.
09-15-2015, 10:09 AM | #25 |
Bringing this one back to life. Does anyone know if swapping instrument cluster from another region's 86 or BRZ will solve the problem? I don't want to tape up the speaker because I want to be able to hear the shift warning beep.
05-21-2023, 03:54 PM | #26 |
insta: LastoBRZ
I DID IT!!! After 7 years of owning my BRZ I finally did it!!
Open dashboard/instrument console with YT help Find the speaker/beeper YANK IT OUT!! Literally Put everything back in Voila! Freakin hell |
Similar Threads | ||||
How to disable DRL in FRS | whitefrs | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 12-13-2016 02:11 PM |
Disable NAV Safety Features | slizoth | Electronics | Audio | NAV | Infotainment | 4 | 01-22-2014 03:53 AM |
Dealer won't disable Ecu features? | DBacon1052 | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 01-09-2014 08:30 AM |
Dealer refusing to disable DRL's? | zaptorque | Scion FR-S / Toyota 86 GT86 General Forum | 64 | 09-17-2013 04:20 PM |
Is there a way to disable the immobilizer? | schtebie | Issues | Warranty | Recalls / TSB | 5 | 09-22-2012 06:09 PM |
