Old 08-27-2012, 08:01 PM   #15
gmookher
I tried the mt-90 in my e36 m3
I prefer factory fill:
my m3 tranny gets this
http://pentosin.net/pressreleases/CR...nto_MTF2_2.pdf
same as factory
that liqui moly gl4 is good stiff too
in a pinch absent the toyota fluid, I'd use either the liqui or pento gl4
my brz rear diff = motul 300v 75w90
gmookher is offline   Reply With Quote
Old 09-03-2012, 11:40 AM   #16
MattR
Running in the 90s
MattR's Avatar
Drives: 2014 Scion FR-S Monogram
How's that working for you? Any noticeable differences from OEM? I've been considering Motul 300v or Motylgear when I get past break-in.
藤原とうふ店(自家用)
MattR's Tofu Runner
MattR is offline   Reply With Quote
Old 09-03-2012, 11:59 AM   #17
#87
I usually post drunk
#87's Avatar
Warranty repair to transmission? Are you allowed to say what the issue was?
#87 is offline   Reply With Quote
Old 09-06-2012, 05:47 PM   #18
gmookher
Dont be skeptical of the pentosin, it FIXes 2nd gear, and makes them all feel better
http://www.ft86club.com/forums/showthread.php?t=16604
do NOT use the MT 90 its not gonna give you the 100% improvement that can be had
Old 09-07-2012, 10:52 PM   #19
DookDookDGM
BR-Zizzle
DookDookDGM's Avatar
Drives: 2013 BR-Z, 1985 AE86, 1986 AE86
Send a message via AIM to DookDookDGM
Jeff, I can look into this for you on Monday.
A little addiction goes a long way...
2013 Dark Grey Metallic Subaru BRZ
1986 Toyota Corolla GT-SR5
1985 Toyota Corolla SR5
DookDookDGM is offline   Reply With Quote
The Following User Says Thank You to DookDookDGM For This Useful Post:
Jeff Lange (09-08-2012)
Old 09-19-2012, 04:47 PM   #20
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Originally Posted by BMWDavid View Post
Waiting for someone to try the Redline MT90. It looks to be a perfect application.
I've got the same AZ6 6MT in my Altezza & I run Redline MT-90 in it. It's the perfect oil for this transmission IMO, much better than the factory fill. Amsoil MTG is another worth looking at.
I don't have any issues with cold shifting but the coldest it gets here on a winters morning is @ 35°F
SXE10 is offline   Reply With Quote
The Following User Says Thank You to SXE10 For This Useful Post:
Brzce (09-19-2012)
Old 09-19-2012, 04:55 PM   #21
bluesubie
Originally Posted by SXE10 View Post
I've got the same AZ6 6MT in my Altezza & I run Redline MT-90 in it. It's the perfect oil for this transmission, much better than the factory fill. Amsoil MTG is another worth looking at.
A Subaru tech over on another BRZ forum runs MT90 and has good results with it.
It's going to be easier to find a GL-4 oil since the API considers GL-3 obsolete.
-Dennis
bluesubie is offline   Reply With Quote
Old 09-19-2012, 08:52 PM   #22
roddy
roddy's Avatar
Drives: '13 Ultramarine
I've had good luck so far with the MT-90. I've got about 4000 miles on this fluid. It gets pretty cold here over the winter and I suspect cold enough that I may need something a little less viscous. I have a quart of MTL (it is thinner-like a honda fluid) here that I could add to the trans if things start to get crunchy or otherwise unruly. Failing that, I will try the Pentosin fluid. I found a local shop that deals with CRP and they can get it. Pricey stuff, but worth it if it does the trick.
The Following User Says Thank You to roddy For This Useful Post:
gmookher (09-20-2012)
Old 09-20-2012, 08:09 PM   #23
Skye
Drives: TR2,CooperS,BRZ
Anyone used eneos GL 5 gear oil in their transmission?
Skye is offline   Reply With Quote
Old 09-21-2012, 12:44 AM   #24
SXE10
SXE10's Avatar
It's not advisable to use a GL-5 in these transmissions. Supposedly it is harmful to yellow metals/brass. Stick to GL-3/4 as per the factory specs. Redline, Amsoil & Pentosin all make suitable GL-4 75w-90.
Old 11-16-2012, 09:33 AM   #25
Ben_G
Drives: Blue BRZ
Sorry to bump an old thread, but did you ever end up figuring out how to get the fluid, or did they just get a GL4 after all?
Ben_G is offline   Reply With Quote
Old 11-16-2012, 09:46 AM   #26
gmookher
gl3 standard was replaced by gl4
simple
you want a gl4 oil
sae weight means nothing
its all about cst
unless you know the oe fluid cst, you need to make an educated or scientific guess, or shoot in the dark for what aisin specs
not sure why there is so much experimentation when there are one or two fluid specs that seem to work
I'm having success with 75w oils that flo 100c cst 8.0 or lower in my 6MT
honda and miata dealers are stocking oils that are also low cst oils fwis on cars that have dealer fluid support and use our trannys
Good luck to thos of you searching for something else, lmk what you find
Old 11-16-2012, 10:09 AM   #27
Ben_G
Drives: Blue BRZ
Hey man,
I know you're quite passionate about this topic, but I was more interested in what happened with this since it was warranty work.
simple
you want a gl4 oil
its all about cst
Old 11-16-2012, 03:27 PM   #28
bluesubie
Originally Posted by Ben_G View Post
Hey man,
From a company that supplies additives to the major oil companies:
* API Categories GL-1, GL-2, GL-3 and GL-6 were declared inactive by SAE Technical Committee 3 in 1995, even though oils may be marketed with these designations. Similarly, ASTM does not plan to maintain the performance tests associated with these categories, as in a number of cases these tests can no longer be run because parts or test installations are not available.
http://www.lubrizol.com/DrivelineAdd...arOil/GL5.html
You won't have a problem with the warranty since GF-3 has technically been obsolete since 1995.
-Dennis
subaru brz navigation system wire diagram? watching movies usb works !! SgtBolt Audio/Visual, Electronics, Infotainment, NAV 3 06-21-2012 11:31 PM
Subaru BRZ Earns 9 of 10 in Top Gear Magazine First Drive Review Spaceywilly BRZ First-Gen (2012+) -- General Topics 43 05-12-2012 07:11 AM
On the road: Subaru’s new BRZ (Top Gear) Mr Franky BRZ First-Gen (2012+) -- General Topics 4 03-29-2012 07:58 AM
Top Gear Magazine Review of Subaru BRZ and Toyota GT86 davey90 BRZ First-Gen (2012+) -- General Topics 122 01-09-2012 11:15 AM
Top Gear Online Subaru BRZ review - if you enjoy driving, this is the car for you Hachiroku BRZ First-Gen (2012+) -- General Topics 54 12-13-2011 06:32 PM
