BT, dpfarr
Old 10-06-2016, 02:41 PM   #1695
ajc209
Drives: GT86 Cosworth
Originally Posted by Kodename47 View Post
Using an ideal mix of distilled water and antifreeze might help. Cosworth recommend 25% ethylene glycol I believe.
It's something like that. The key is to not sure too much antifreeze as it lowers the specific heat capacity of the fluid. So use as little as you need but enough to help against corrosion.
ajc209 is offline   Reply With Quote
Old 10-06-2016, 02:47 PM   #1696
Kodename47
Kodename47's Avatar
Drives: UK GT86
It was your post I went and looked up to find that
.: Stealth 86 :.
Kodename 47 DJ:
ajc209 (10-06-2016)
Old 10-06-2016, 04:08 PM   #1697
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Originally Posted by shiumai View Post
I'm seeing about the same IATs as you; typically 30 deg F over ambient (based on my vent gauge plugged into the OBD2 port). i was kicking around the nutty idea of 'what would happen if someone reroutes the passenger-side air conditioning vent into the air intake?' if you normally drive with the AC on.
like this? Super Chiller
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
shiumai (10-06-2016)
Old 10-06-2016, 04:33 PM   #1698
armstrom
Drives: none
diverting AC air to the intake would do nothing. A more interesting (but more involved) hack I've actually seen done is to re-route your AC lines into a water tank to chill the A/W intercooler water supply. If you are getting IAT's that are too high during street driving one of the best things you can do is add a reservoir/tank to increase the total water volume of the system. Water has a very high specific heat capacity. Adding extra water allows you to absorb more heat energy per degree of water temp increase. This gives you the net effect of distributing the heat dissipation out over a longer time so any quick spikes due to spirited driving can be absorbed.
This behavior is what makes air to water intercoolers so great for street cars. It also makes things more challenging for race cars since they tend to be dumping heat into the system at a more constant rate rather than in spikes like you see on the street. The water can eventually become heat-soaked leading to higher IATs
armstrom is offline   Reply With Quote
The Following 2 Users Say Thank You to armstrom For This Useful Post:
BigFatFlip (10-06-2016), shiumai (10-06-2016)
Old 10-06-2016, 05:37 PM   #1699
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Would it be 'nothing' or 'negligible'? I'm assuming it'd be the same as people installing a CAI - to get the coolest air going into the intake. however, if the AC air isn't cold enough to make a difference when it's compressed going into the SC, that makes sense.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
CSG Mike (10-06-2016)
Old 10-06-2016, 08:18 PM   #1700
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
And there it goes :
Face to face on the graph :
Mxp4in1el header, mxp overpipe,invidia catless front pipe, and invidia q300 98ron tune
Ace type a 350 header, fujitsubo double resonated catless front pipe and invidia q300 98 ron ace tune.
+15hp +15nm !
Car feels so smooth ! That torque <3
One more time thanks to delicious tuning for their amazing tune ! I'm so happy with it!
Thanks to ACE for this amazing header !
And thanks to FRSport for the fast delivery and this amazing product the fujitsubo double resonated catless front pipe !
Next mods :
5.125 cusco final drive (i'm AT)
And maybe delicious flex fuel kit
Paulo86 is offline   Reply With Quote
The Following 6 Users Say Thank You to Paulo86 For This Useful Post:
8686 (10-08-2016), ajc209 (10-07-2016), CSG Mike (10-06-2016), GhostOp86 (12-04-2016), tirespin782 (10-15-2016), TofuJoe (10-06-2016)
Old 10-14-2016, 11:15 PM   #1701
Im_SPEED
Drives: FRS hot lava
Any one leave the cover off the left side injectors? The big heavy shield looking thing looks like it's mostly for noise I'm guessing. Opinions?
Im_SPEED is offline   Reply With Quote
Old 10-15-2016, 12:01 AM   #1702
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
It's also part of the ground for the fueling ECU. You can ditch it if you make a bracket.
The Racers Line is offline   Reply With Quote
Old 10-15-2016, 12:14 AM   #1703
Im_SPEED
The fueling ecu is on the right side. Talking about the left side.
Old 10-15-2016, 12:37 AM   #1704
The Racers Line
Oh my bad. That cover only fits on with modification anyways. You are supposed to leave it off.
Old 10-15-2016, 04:06 PM   #1705
Im_SPEED
Need help asap just installed and no start. Not running a tune. But you would think it would still fire up. I have fuel everything is connected.
Old 10-15-2016, 04:33 PM   #1706
The Racers Line
It will not start. The T-MAP sensor is very different then stock. You need the tune.
Old 10-15-2016, 04:46 PM   #1707
Im_SPEED
that is 100% you know form experience?
Old 10-15-2016, 05:31 PM   #1708
shiumai
shiumai's Avatar
Not running a tune.
Why would you do that?
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 10:09 PM
