Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
03-26-2019, 12:50 AM | #1 |
Drives: --
Noob Fitment Question
Hey guys,
First time modding a car but i want to do it right. Searching the forum didn't bring up what i needed or my searching skills are crap. I want to run 17x9 +35 rims on 245/40/17 tires with Tein Flex Z coilovers lowered about 1.2-1.5 in. Would there be any issues with rubbing? I've seen threads on people running stock suspension and having rubbing issues but i know aftermarket coilovers could be different. I would of course have aftermarket LCA's and camber adjustments made to compensate for the drop. Anyone running a similar setup who can tell me if i need to make changes? Thanks |
03-26-2019, 01:46 AM | #2 |
Drives: Crapcan
Common setup, it will fit fine. I only had rubbing issues with the stock struts and lowering springs with that tire wheel setup. I'd recommend running less drop if your car is your DD. My car is a little more than -1.5 and it is a bit too low on the street, I also rub the front fender liner under hard cornering. Your rear camber should be fine without any aftermarket LCA's and the Flex Z's will have adjustable top hats.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | VOSS (03-30-2019) |
03-26-2019, 05:41 PM | #3 | |
Drives: --
In regards to the fenders, would rolling them help? As for the top hats, whats the benefit of adjustable top hats? Tried searching but didnt come up with much. It helps with shock travel? |
03-26-2019, 05:53 PM | #4 | |
Drives: 2015 BRZ
03-26-2019, 06:10 PM | #5 | |
Drives: --
As for camber, so camber plates can adjust front camber while LCAs control back camber? |
03-26-2019, 06:33 PM | #6 | |
Drives: 2015 BRZ
Yep, on these cars you can either get camber plates or camber bolts to adjust camber in the front. For rear you would need LCAs to adjust camber. Also, you can try and dial in some front camber so you dont rub the fender if you do get rubbing that is. |
The Following User Says Thank You to Vital For This Useful Post: | VOSS (03-26-2019) |
03-26-2019, 06:44 PM | #7 | |
Drives: Crapcan
Sent from my Moto E (4) Plus using Tapatalk
03-26-2019, 06:45 PM | #8 | |
Drives: --
Thanks for all the help. |
The Following User Says Thank You to VOSS For This Useful Post: | Vital (03-26-2019) |
03-26-2019, 06:46 PM | #9 |
Drives: --
How much camber are you running? I heard having some negative camber like -0.5 to -1 is good for handling?
03-26-2019, 07:09 PM | #10 |
Drives: 2014 GT86
Handling wise depends on during what kind of driving and on what kind of pavement. Static negative camber is used to compensate tire sidewall flex during turns to make tire contact patch more even and grip better. Also some add more negative camber to front to change grip bias vs grip bias of stock alignment to make car less understeery.
On dry track where turns are taken fast with high side-Gs, so lot of flex, so car there benefits from lot of negative camber of eg. -3 to -4 degrees depending on tires. When driving on public roads within speed limits or not overcoming them too license-loosing much and without endangering self and others at too high rates, there are no high side loads, tire doesn't flex much, so for optimum contact patch and most grip optimum camber is way less. When on low grip pavement, such as in wet, or even more so, on gravel, snow, ice, tire looses grip very soon, again before lot of sidewall flex happens, and again here less camber is better. Stock camber for twins is ~0degrees front, -1.2dg rear. For only street driven car, if some change it for handling, then only slightly, eg. upping front camber (eg. -0.5 to -1.5 front, same -1.2 rear). Such modest camber amount should work well during wet and in winter too. If you track your car .. or in other words, most of your tire wear happens on track (eg. 5-10 or more trackdays should wear out most of tire set even if daily driven mileage is way way higher), then it's worth to go with track oriented alignment (eg. -3 front, -2.5 rear). If driving pattern, how tires are worn, is somewhere in between, eg. just 1-3 trackdays per year, maybe somewhere in between (eg. -2F, -1.5R). I wouldn't single out "spirited canyon runs" from daily driving. If it's still within speed limits, not going 1.5-2x faster then those, sideloads won't differ much from daily driving, unlike on track, where one pushes much closer to own, car and tire grip limits. |
03-26-2019, 07:20 PM | #11 |
Drives: 2015 BRZ
This all depends on what you are going to do with your setup. Is this purely DD and occasionally tracking/autoX or canyon runs? If you are just daily driving you can just get camber bolts up front which will be much cheaper than getting camber plates. For track use you definitely want camber plates so you can run more camber. Yes you want to run some camber in the front for better handling and grip. The main thing to remember is toe is what kills your tires you want 0 toe up front and 1/16th toe-in rear.
03-26-2019, 07:22 PM | #12 | |
Drives: Crapcan
Similar Threads | ||||
Wheel noob here, need help on fitment! | Sufficial | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-04-2015 06:18 PM |
I need help on fitment (noob) | nearvincent | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 08-11-2014 04:48 PM |
Noob question | dro | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 07-05-2013 09:33 AM |
Noob question | fitcious | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-02-2012 11:18 PM |
