Old 02-18-2018, 07:36 PM   #29
Code Monkey
Drives: Subaru BRZ
Got STi transmission and motor mounts installed. With the header removed, the install process was easy and enjoyable.
Had the wife crawl under the car to show her things and she says 'Dumbass, you should have waited until you got the header, now you have to remove it again.' And then it clicked.
Code Monkey is offline   Reply With Quote
Old 02-18-2018, 07:43 PM   #30
Code Monkey
Drives: Subaru BRZ
While the mounts were bolted to the engine and transmission, but not the frame, installed the ACE 350 header, ceramic coated in and out. The install was a breeze, everything fits perfectly with plenty of clearance. Waiting for my Delicious tune now.
The Following 2 Users Say Thank You to Code Monkey For This Useful Post:
SuperTom (06-08-2018), tehShirt (02-18-2018)
Old 02-18-2018, 08:15 PM   #31
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Love the car and all the mods. The STI mounts are great at firming up the driveline with little to no NVH increase.
tehShirt is offline   Reply With Quote
The Following User Says Thank You to tehShirt For This Useful Post:
Code Monkey (02-18-2018)
Old 02-18-2018, 10:51 PM   #32
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Sweet build, it looks like we have a similar thought process (focus on handling before power and keep it NA). I'm looking forward to seeing how the ACE header works out for you, as that's the one I'm considering for some point in the future as well.
I saw you had an alignment result above, did you find a shop that does performance alignments? I'm still trying to figure out where I'm going to go here in South Texas. Only place I know of is Soulspeed in Austin, doesn't look like there's anything here in San Antonio.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
Old 02-18-2018, 11:02 PM   #33
Code Monkey
Drives: Subaru BRZ
I still have to upgrade the suspension, it just happened the headers came first. Soulspeed is good; I thought Rich was closer to or at Harris Hill but guess not. I have my alignments done at Mansel's in Bryan, it is an old school shop, they let me put weights in the driver seat to account for my weight, etc, can't beat that for $75 + tip.
The Following User Says Thank You to Code Monkey For This Useful Post:
Tristor (02-21-2018)
Old 02-18-2018, 11:28 PM   #34
Tristor
Tristor's Avatar
Can Mansel's do corner balancing? If so, I may be road-tripping to Bryan/College Station when I do suspension replacement next year. Soulspeed closed in the Harris Hill location in 2012 and then reopened sometime afterwards in Austin proper. I have never been in there, but it seems to be the best regarded place to go according to folks I've asked around here, but it's quite a hike. I guess Mansel's would be quite a hike too. I wish San Antonio had a proper alignment shop.
Old 02-18-2018, 11:36 PM   #35
Code Monkey
Drives: Subaru BRZ
pm'd
Old 02-21-2018, 03:54 PM   #36
Code Monkey
Drives: Subaru BRZ
Finished my Delicious tune. The car is pulling very smoothly and in a linear fashion throughout the entire rev range which makes me very very happy. Totally worth it.
Old 02-21-2018, 04:19 PM   #37
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
So its a nice improvement from the stock 2017 tune? I have DT on the way as well!
mistople is offline   Reply With Quote
Old 02-21-2018, 04:26 PM   #38
Code Monkey
Drives: Subaru BRZ
It will not push your head into the headrest so to speak, not enough hp for that but you bury the gas pedal and have a nice, smooth, consistent pull from 3000 rpm to 7800 rpm. The torque dip is gone, gone, gone.
Old 02-21-2018, 04:48 PM   #39
mistople
mistople's Avatar
That's all I care about! For the street, this car is plenty fast at redline. No problems with the power up top as far as I'm concerned. Glad to hear it.
The Following User Says Thank You to mistople For This Useful Post:
Code Monkey (02-21-2018)
Old 02-24-2018, 09:28 PM   #40
Code Monkey
Drives: Subaru BRZ
Installed the Essex harness bar and Schroth Rallye Cross harnesses.
The harness bar in the lowest position is a must to keep the harnesses parallel with the ground or at a slight angle. A 255 tire still clears but you cannot fold/unfold the rear back rest, you need to take out the two lower bolts behind the back rest to disengage it from the brackets and then the back rest just slips in under the bar.
Eye balled the location of the harness bar on the side panels (official name is "luggage compartment trim covers") and drilled a 2" hole in the panels, which I later expanded a bit to better match the actual bar location. Put a rubber trim from a Miata around the holes for a cleaner look.
It is possible to re-use the b-pillar covers ("center pillar garnish") but you have to trim them a bit and gut all the plastic ribs on the inside.
The Following 6 Users Say Thank You to Code Monkey For This Useful Post:
JeremyR (03-01-2018), JRitt (03-02-2018), mistople (02-24-2018), MrSkubi (04-25-2018), RJasonKlein (02-26-2018), Tristor (05-25-2018)
Old 03-01-2018, 05:33 PM   #41
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
WOW that harness bar looks great! Where did you get the miata grommet? for those of us who would like to replicate this
JeremyR is offline   Reply With Quote
Old 03-01-2018, 06:24 PM   #42
Code Monkey
Drives: Subaru BRZ
Look for a "door sill pinch weld moulding" for Miatas or you can get a universal one, something like this.
Berzerk's 2017 CWP 'Slow and Steady' Build Thread Berzerk Member's Car Journals 12 07-24-2017 04:57 PM
Rodie's slow '13 FR-S build rodie Member's Car Journals 0 06-14-2015 08:05 PM
Slow Progression FRS Build dgerny Member's Car Journals 1 04-15-2014 06:48 PM
Tkalz slow build! Tkalz Member's Car Journals 15 10-13-2013 05:35 PM
Slow Build by Jooks jooks Member's Car Journals 4 07-03-2013 10:53 PM
